Posted: Sat Apr 21, 2007 4:59 pm Post subject: Gotcha: SV-1 vents |
What the heck is a square flanged SV-1 vent. I am using the srandard Van's
panel and my installed vents seem to eminate just below the panel. About two
inches of tubing and an aluminum mount to the bottom cross member and it
should be fine. Am I missing something. My vents were not in the QB either
so I orderred them. WHere is the square flange.??
John
| Quote: | From: Deems Davis <deemsdavis(at)cox.net>
Subject: Re: Gotcha: SV-1 vents
Date: Sat, 21 Apr 2007 10:34:25 -0700
John, have you finalized the design of your instrument panel yet? I you
decided to use something other than the standard Van's panel )The reason
I'm asking is that there are several options (many options give more
depth/room) for terminating the vents at the instrument panel, and many of
them would NOT require the square flange on the SV-1. It may be that
depending on what panel you decided on you may be OK with what you have
installed.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
John Ackerman wrote:
>Here's a pretty minor "Gotcha" in my plans.
>Page 35-10 Step 3 has us install the two VENT SV-1 units to the forward
>side skin. These vents are not included in the QB fuselage kit, and when
>called,Van's had me buy them separately. Trouble is, what I bought didn't
>have the requisite square flange, and I didn't know that.
>Just got my finishing kit yesterday,and guess what? There are the vent
>units complete with square flanges. It's time to get out the heat gun and
>remove the previously installed units,I guess.
Deems Davis
Posted: Sat Apr 21, 2007 5:46 pm Post subject: Gotcha: SV-1 vents |
John, here's a link that will help.
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1177205964-300-624&browse=heatvent&product=ventilation-components
The Square part is actually the SV-2.
In my finish kit they came glued together SV- and SV-2 and I had to cut
the SV-2 portion off.
PS saw your frustration on the cabin cover, and I think you'll be
surprised just how much additional time you will spend on the fiberglass
parts. I installed my cabin cover last summer, and I'm STILL dealing
with fiberglass dust!!!!!!
Deems Davis # 406
Finishing - cough - choke - snort - itch ----
| Quote: | orderred them. WHere is the square flange.??
John
> you decided to use something other than the standard Van's panel )The
> reason I'm asking is that there are several options (many options
> give more depth/room) for terminating the vents at the instrument
> panel, and many of them would NOT require the square flange on the
> SV-1. It may be that depending on what panel you decided on you may
> be OK with what you have installed.
> Deems Davis # 406
>> forward side skin. These vents are not included in the QB fuselage
>> kit, and when called,Van's had me buy them separately. Trouble is,
>> what I bought didn't have the requisite square flange, and I didn't
>> know that.
>> vent units complete with square flanges. It's time to get out the
>> heat gun and remove the previously installed units,I guess.
