a.s.elliott(at)cox.net Guest
Posted: Thu Apr 19, 2007 11:39 am Post subject: Running electrical cables |
Gang:
I am approaching (slowly) the point where I need consider where and how I will run the electrical connections from the panel back on my 601XL. I am looking for some comments from you all that have passed this point.
It seems that in my dual-stick plane, there are three pathways immediately obvious:
1. under left canopy rail
2. under right canopy rail
3. through control tunnel
3a. up top on the sides out of the way of the cables
3b. down low though the spar hole out of the way of the cables
I am thinking that the wiring to the wings, for lights and pitot heat, would be rightly run under the respective canopy rails, then down between the fuselage side and the interior panel, then out through the fuselage side in the wing root area.
Similarly, the wiring for the comm antenna, transponder antenna, ELT control wires (if installed) and beacon, plus the autopilot would be good candidates for the 3a. route (which is not really available in center-stick planes). This would also be the location of the wires from the trim on the stick to the trim relays behind the seat, and for the coaxes for the remote gyro (mounted under the console cover) and remote compass (mounted under the baggage floor) for my EFIS.
The flap control wires could also run through the 3a. path if the switch is on the console, or alternately under the left rail if the switch is on the panel.
Any comments about this routing plan?
Andy Elliott, Mesa, AZ
N601GE (reserved)
601XL/TD/QB, Corvair, building...
bryanmmartin
Posted: Thu Apr 19, 2007 12:03 pm Post subject: Running electrical cables |
I ran the GPS and VOR antenna cables under one canopy rail and the
Com 1 antenna under the other because those antennas are all mounted
up high in the rear fuselage. I didn't want to run the transmitter
cable real close to the two receiver cables for any large distance,
which is why I ran them on opposite sides. I installed half inch poly
tubing under the canopy rails to use as cable ways. I ran pretty much
every thing else through the tunnel on either side of and at the same
level as the torque tube (3c). With the center stick, that puts them
out of the way of any moving parts.
On Apr 19, 2007, at 3:38 PM, Dr. Andrew Elliott wrote:
| Quote: | Gang:
passed this point.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
VideoFlyer(at)aol.com Guest
Posted: Thu Apr 19, 2007 12:25 pm Post subject: Running electrical cables |
I enclosed the channel that runs underneath the cabin from the front nose wheel to the spring gear with a slightly wider piece of channel. A couple of holes in the floor with heavy duty rubber grommets allowed me to run all my cables underneath the spar in the newly enclosed channel. They re-enter the plane behind the spar. I ran all of my wiring...plus the pitot and static tubes...plus tubes for the LRI ....with plenty of room. Keeps thing out of the way by your feet and inside the cabin. I'll send a pic if you're interested.
Dave
601XL/Corvair
See what's free at AOL.com.
dredmoody(at)cox.net Guest
Posted: Thu Apr 19, 2007 12:50 pm Post subject: Running electrical cables |
A very cool idea Dave. Thanks for the insight.
Dred
---- VideoFlyer(at)aol.com wrote:
| Quote: | I enclosed the channel that runs underneath the cabin from the front nose
Gig Giacona
Posted: Thu Apr 19, 2007 1:31 pm Post subject: Re: Running electrical cables |
I had thought of doing the exact same thing. Do you have any photos?
| VideoFlyer(at)aol.com wrote: | I enclosed the channel that runs underneath the cabin from the front nose wheel to the spring gear with a slightly wider piece of channel. A couple of holes in the floor with heavy duty rubber grommets allowed me to run all my cables underneath the spar in the newly enclosed channel. They re-enter the plane behind the spar. I ran all of my wiring...plus the pitot and static tubes...plus tubes for the LRI ....with plenty of room.� Keeps thing out of the way by your feet and inside the cabin. I'll send a pic if you're interested.
Dave
601XL/Corvair
601XL Under Construction
Jaybannist(at)cs.com Guest
Posted: Thu Apr 19, 2007 4:02 pm Post subject: Running electrical cables |
Don't forget that you will probably have a big, fat battery cable to run as well as pitot & static tubing.
Jay in Dallas
"Dr. Andrew Elliott" <a.s.elliott(at)cox.net> wrote:
| Quote: | Gang:
N601GE (reserved)
Float Flyr
Posted: Sat Apr 21, 2007 5:55 pm Post subject: Running electrical cables |
I personally like to keep my radio Coax separate from potentially noisy
wiring like the lines to the strobes... On aircraft the ERP is quite small
and the coax generally has enough shielding to protect from cross
channelling. The rest of the wires can be neatly bundled and tied. The
wires for your avionics aren't so much Coax as they are shielded cable.
Some will only have one conductor others will have multiple conductors. The
important thing is that the shielding only be grounded at one end.
Grounding the shield at both ends turns the whole wire into a big juicy
inductor similar to a capacitor. Generally if I put FR coax on one side of
the plane I will put the rest of the wiring on the other side. Some of the
equipment you mentioned can generate pulses that the radios could interfere
with or could interfere with the radios.
The routing of the cable if it were up to me would be well supported and not
close to any control cables or moving parts (Door latches) once properly
supported the wires can be clamped into position in the centre of lightening
holes. I've done my share of aircraft wiring and I can tell you there will
be times when you wonder if you are really wiring or knitting an electrical
system.
Regardless of which route/s you use the biggest favour you can do for
yourself is to draw a wiring interconnect diagram which shows the routing
and location of all the wires. This will be invaluable if there is any
trouble shooting to do...e.g. where is the wire for the light on the
transponder??? Remember some problems although minor just won't show for a
few years long after you've forgotten you decided to wire the transponder
lights directly off the instrument lights instead of the pin designated by
the transponder manufacturer because the light would go out when the
transponder was turned off and you decided you didn't want that. The wiring
diagram can also help you decide how many and what kind of cannon connectors
you will need if you decide to use them, How much and what kind and size
wires you will need. How many crimp connectors Etc.. Paper is cheap have a
good supply when drawing up your diagrams. You will find you will be making
lots of changes before you make your first crimp connection.
Remember Cannon/Moulenex connectors can be great if you decide to pull the
wings off to trailer the plane somewhere.
I just noticed the reference you made to the flap control. This is a
control that is general only used once or twice during a flight. For that
reason I like to place the flap control and or gear control in a place where
the pilot has to reach for it. That way there is less chance of accidental
activation. Other considerations may be children in the cockpit. When I was
a kid I loved to fiddle with just about anything that moved, my father's
Cessna had all the major controls safely out of reach of my little deft
fingers... You may want to consider such things when deciding where to place
certain controls.
Noel
| Quote: | From: "Dr. Andrew Elliott" <a.s.elliott(at)cox.net>
Subject: Running electrical cables
Gang:
where and how
my 601XL.
this point.
pitot heat,
through the
wires from
and remote
the switch
switch is
on the panel.
N601GE (reserved)
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Sun Apr 22, 2007 10:27 pm Post subject: Running electrical cables |
OK, so you run wires to the rear under the canopy rails. What do you do when
you reach the rear of the cockpit and hit 6B5-6, the upright channel? Have
others just drilled a hole it? And if you do that leaves you above the
luggage shelf. Do you route the wires back or up from that point?
Or do you route the wires from the rail down to pass through 6B6-5 below the
shelf?
Does anyone have any pictures?
-- Craig
tonyplane(at)bellsouth.ne Guest
Posted: Mon Apr 23, 2007 9:43 am Post subject: Running electrical cables |
Craig,
I thought I had some pics of the wires exiting under the canopy channels, but could not find them..What I did was at the exit points, I enclosed the wires/cables in split ribbed auto wire conduit and ran them up into the cargo area fuselage side (upper antenna/interior lights/ tail light/ elevator & aileron trim) or down into the area behind the seats (lower antenna, flaps, Xpndr antenna ), as required. The conduit provides chaff protection and the exit area is mostly hidden by the seat back upholstery. You may want to try it with only ribbed conduit to see what it looks like. Would not recommend adding a hole in the upright channel.
Tony Graziano
234 hrs
RE: Running electrical cables From: Craig Payne (craig(at)craigandjean.com ([email]craig(at)craigandjean.com?subject=RE:%20Running%20electrical%20cables&replyto=01af01c78570$47663360$8e01010a(at)northamerica.corp.microsoft.com[/email])) Date: [b]Sun Apr 22 - 11:27 PM[/b] | Quote: | | Quote: | OK, so you run wires to the rear under the canopy rails. What do you do when
shelf?
-- Craig
Gig Giacona
Posted: Mon Apr 23, 2007 11:25 am Post subject: Re: Running electrical cables |
We drill holes in supporting structures all over the aircraft. I don't see how a properly drilled hole in the upright would be of any great threat to the structure of the plane.
| tonyplane(at)bellsouth.ne wrote: |
Tony Graziano
234 hrs |
Posted: Mon Apr 23, 2007 11:48 am Post subject: Running electrical cables |
I'm with you Gig. While Im not advocating turning the semi-monococque construction into the aluminum equivalent of Swiss cheese. I think a small number of properly located, drilled and deburred holes won't cause us an early demise. I'm leery about drilling holes in the center spar, but the top of the seat back upright is not likely to be a problem down the line. If the hole is located down the upright about 70 - 100 mm, the wiring could pass into the area under the baggage deck. If the desired wiring run is toward the middle top skin for an antenna, I would go the route of using the spiral loom protection and looping out from under the cockpit side rail and over the top angle of the seat back.
Dred
---- Gig Giacona <wr.giacona(at)suddenlink.net> wrote:
> Tony Graziano
> 234 hrs
planes_by_ken(at)bellsout Guest
Posted: Mon Apr 23, 2007 4:12 pm Post subject: Running electrical cables |
I hope everyone would consider buying or downloading a copy of AC 43.13
1B & 2A Acceptable Methods of Aircraft Repair ISBN 0-89100-306-1 by
the FAA.
It can be downloaded from the FAA (warning: huge files)
http://rgl.faa.gov/Regulatory_and_Guidance_Library%5CrgAdvisoryCircular.nsf/0/99C827DB9BAAC81B86256B4500596C4E?OpenDocument
http://rgl.faa.gov/Regulatory_and_Guidance_Library%5CrgAdvisoryCircular.nsf/0/E533BB05389C90E486256A54006E47B2?OpenDocument
This book is essentially an A&P course all by itself. It gives guidance
for radio and wiring installation in addition to almost everything else.
On a non-high stressed bulkhead, I would think that a well deburred hole
that has a diameter of less than 1/4 of the web height should be OK.
Keep it in the middle of the web.
Of course, I could not find a reference for this in the 43.13.........
Ken Lilja
A&P
Instructor, Aviation Institute of Maintenance
Flange or cap
________
I
I
I
I
I
I Web
I
I
I
I
I
_______I
Flange or cap
We had a Beech Duke come through our shop that someone had sunk a # 6
sheet metal screw through the upper spar cap. Beech told us to dye
check it every 100 hours.
Ken Lilja
dredmoody(at)cox.net wrote:
Dred
Posted: Mon Apr 23, 2007 6:48 pm Post subject: Running electrical cables |
Thanks Ken. That sounds like good advice to me.
Dred
