		flyinggpa(at)comcast.net Guest
				 Posted: Tue Feb 07, 2006 4:54 pm    Post subject: fitting doors |
				Jos
 I did not like the big gaps in the door tangs either.  I talked to Andy when I was building and he did not know why they were built the way the are, SO ,  I redesigned the tangs and the recesses in the top of the fuselage. I have just a small crack around the tangs the same as around the rest of the door.  The hinge line was keep the same.
 To do this I had to make new recesses to fit the new tangs. The tangs are squared off and the recesses are squared off too. It really is not a hard job.  (just takes tine! ) I started by dremal-grinding the old recess away. Then put foam blocks in place and layers up 4 layers of bid on the inside of the top.  The tangs were much harder to build.  I used a little bid and a lot of flox and trial and error to get them squared off. (the hinge surface is not changed)
 There are pictures some ware in my Europaowners page.
 Good luck
 Cliff Shaw
 1041 Euclid ave.
 Edmonds, WA 98020
 425 776 5555
 http://www.europaowners.org/WileE
		SPurpura(at)aol.com Guest
				 Posted: Tue Feb 07, 2006 6:11 pm    Post subject: fitting doors |
				It varies depending on hinges are set,trim to fit.
