MJKTuck(at)cs.com Guest
Posted: Sat Apr 14, 2007 11:22 am Post subject: EFIS thoughts |
Hi Folks,
I'm thinking (dreaming I think at this stage) to upgrade my panel to EFIS.
I like the combined EFIS/EMS by the likes of Dynon. Anyone got any panel shots of an EFIS equipped Europa as I'm interested to see how the water temp as well as oil temps and pressures are displayed.
Also I figure just a VFR panel is all I need.
I'm not so keen on having all your primary instrumentation in one box. If the box gets a fault in flight you loose everything so I figure some kind of mechanical backup (or secondary EMS of some kind) is necessary.
Any thoughts on what instrumentation should have backup and how?
Martin Tuck
Europa N152MT
Wichita, Kansas [quote][b]
Trevpond(at)aol.com Guest
Posted: Sat Apr 14, 2007 12:05 pm Post subject: EFIS thoughts |
Hi Martin,
Saw your note on the Europa Web and thought you would like a picture of my panel. Note that I also have a complete set of miniature guages - I feel that they are essential. The EFIS is a Blue Mountain Lite plus Gen 4 and it is pretty good although the earlier ones were very troublesome.
kind regards
Trev Pond
G-LINN
Description: |
Filesize: |
53.17 KB |
Viewed: |
271 Time(s) |
EuropaXSA276(at)aol.com Guest
Posted: Sat Apr 14, 2007 1:01 pm Post subject: EFIS thoughts |
Hi Trev.
I'm looking very close to your same setup. But using the large Dynon in place of the Blue Mountain.
What is that back up instrument between the Airspeed and the Altimeter? It's not an electronic miniature horizon is it?
It is not clear to me if full size ASI ALT and AI will fit in the panel under a Dynon D100. It looks too tight.
There are a number of option for 2 1/2" AS and ALT but few Attitude indicators. The only one I have found is from Mid West Instruments. They offer a small trio pack. ASI ALT and AI
The 2" trio backup set from Mid West is unbelievably expensive. I would like to consider options to that same setup
Brian Skelly
Europa XS TriGear #A276
North Texas USA
You can see my build photos at:
http://www.europaowners.org/BrianS
See what's free at AOL.com.
keithhickling(at)clear.ne Guest
Posted: Sat Apr 14, 2007 4:19 pm Post subject: EFIS thoughts |
Hi Trev,
I also have the BM EFIS lite plus G4 - I think one of the early ones they shipped. Not yet installed, but on bench testing it seems fine apart from the GPS terrain display, which breaks up into quite large white triangles around the coastline, and shows only red and white. I'm not sure if this is a problem with the New Zealand terrain software or with the unit itself. I have emailed BM several times and sent them photos of this and have had no response.
What are the problems with the early units that you mentioned? Any suggestions about this problem? Does anyone else have a BM EFIS lite G4, and is it working OK?
Could someone going to Sun ' Fun please ask BM about this problem and why they haven't responded to my emails - many thanks.
Keith Hickling,
New Zealand,
XS mono kit 613.
Posted: Sat Apr 14, 2007 5:22 pm Post subject: EFIS thoughts |
Hi Trev,
Here is a photo of my BM EFIS GPS terrain display, showing only red and white and breaking up round the coastline.
Keith Hickling,
New Zealand.
Description: |
Filesize: |
493.9 KB |
Viewed: |
252 Time(s) |
paul.mcallister
Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
Posted: Sat Apr 14, 2007 7:48 pm Post subject: EFIS thoughts |
Hi Martin,
I installed the GRT Sport and I am delighted with it. I already had the GRT EIS engine monitor so it made the decision a bit easier. I liked the Dyon but despite the manufacturers claim it isn't very readable in the sun light. The Dyon has a bigger display, and although bigger is better I couldn't have done the panel layout that you see in the photos, which is really what I wanted to do.
The EFIS Sport worked perfectly right out of the box with the minimum on fuss. I intend to exchange the T&B for a 2 1/4 ADI from TruTrack when it becomes available. The ADI is a and AH + digital heading, almost like an AH & a DG in one instrument. Nice box but it is a bit expensive.
Contact me off forum if you would like to know more.
Regards, Paul
Description: |
Filesize: |
98.01 KB |
Viewed: |
252 Time(s) |
Description: |
Filesize: |
97.25 KB |
Viewed: |
201 Time(s) |
gcrowder2
Joined: 09 Jan 2006 Posts: 136 Location: Golden, Colorado USA
Posted: Sat Apr 14, 2007 8:49 pm Post subject: EFIS thoughts |
Just talked to a guy tonite at the EAA meeting who was finishing up an RV7 and has had
nothing but problems with the Dynon engine monitoring system. (The Dynon flight instrument
system has been good tho) He says even their downloadable updates don't work. Very unhappy customer!
Glenn
Date: Sat, 14 Apr 2007 16:58:13 -0400
Subject: Re: EFIS thoughts
Brian Skelly
North Texas USA
| Live Search Maps – find all the local information you need, right when you need it. Find it!
Posted: Sun Apr 15, 2007 3:58 am Post subject: EFIS thoughts |
Hi Brian,
Yes, it is a little solid state Horizon.
Trev
Posted: Sun Apr 15, 2007 4:02 am Post subject: EFIS thoughts |
Hi Keith,
I had an original EFIS Lite that was upgraded with a remote screen. The Horizon continually toppled and BMA replaced the unit with the latest G4 Sport. BMA are good to deal with and you need to speak to Larry Romig about any queries you may have. Map is very good and everything works as on the Tin but earthing is a problem as the unit generates quite a lot of "noise". I have put ferrites on all of the cables coming out of the plugs on the EFIS and this has certainly helped along with a separate earth strap to the case of the unit to the Earth Bus.
Trev
G-LINN
Posted: Sun Apr 15, 2007 4:03 am Post subject: EFIS thoughts |
Keith,
Definately speak to Larry Romig at BMA!!
Trev
Posted: Sun Apr 15, 2007 5:16 am Post subject: EFIS thoughts |
In a message dated 4/15/2007 6:59:27 AM Central Daylight Time, Trevpond(at)aol.com writes:
Thanks Trev. Brand name please?
Brian Skelly
North Texas USA
Posted: Sun Apr 15, 2007 7:34 am Post subject: EFIS thoughts |
Hi Keith,
Yes, it's: http://www.pcflightsystems.com/.
regards
Trev
n914va(at)bvunet.net Guest
Posted: Sun Apr 15, 2007 7:52 am Post subject: EFIS thoughts |
Hi Martin,
I have purchased the Grand Rapids Technology dual screen Efis and EIS. Unfortunately, I have not wired it all up yet. I'm severly challanged when it comes to sparks. Their drawings and instructions are easy to follow and they are extremely responsive if I call with a question. I'm just having trouble withe the wiring of a second 40 amp alternator as my primary source of power. I have the GPS built into the unit and though not IFR certified, all who have used it love it. With two screens, there is no limit as to how you can display attitude, engine and GPS info. Since I bought the unit, they have added terrain, weather, and mode s traffic. Anything that they add can be added to my set-up, but weather and mode-s info is an additional cost (also when purchased new). You can buy a single screen system and upgrade to dual screen later for the same cost as buying dual screen initially. I can also add dual AHRS and Magetometers if I want electronic redundancy. What really made the sale for me was the brilliance of their screen, especially since their booth at Sun n Fun faced the big open hanger doors. Some of the units yhat I looked at were not as clear even thouht they were in a dark corner of the booth. Here is a link to their web site. Check it out if you have not already.
http://www.grtavionics.com/
Vaughn Teegarden
XS mono, 914 with Airmaster planned
wdaniell(at)etb.net.co Guest
Posted: Sun Apr 15, 2007 8:18 am Post subject: EFIS thoughts |
It might seem a little unsophisticated but I have had one of these pcflight systems egyro connected to an iPaq as a portable backup for rentals and latterly in my own Zenith. I bought on spec thinking that the price was sufficiently low for it not to be a disaster if it didn’t work. In the event it has worked very well. Craig Sellers has always responded rapidly to questions and he quickly replaced a unit which did not “talk” to my GPS.
Will
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of EuropaXSA276(at)aol.com
Sent: Saturday, April 14, 2007 15:58
Hi Trev.
Brian Skelly
North Texas USA
peter.rees01(at)tiscali.c Guest
Posted: Sun Apr 15, 2007 10:01 am Post subject: EFIS thoughts |
Thats a big surprise - we've updated the firmware on our Dynon EFIS about 4 times (not through necessity - they keep adding new features for free!). Always goes seamlessly and takes about 2 minutes.
We have never found the screen brightness on our Dynon unreadable even in direct sunlight.
Have to say that I'm a very happy Dynon customer - the D10A is a really great product and I've always found them to be very responsive to queries / suggestions.
Peter
hdwysong(at)gmail.com Guest
Posted: Sun Apr 15, 2007 11:04 am Post subject: EFIS thoughts |
Hello Keith,
Sounds like you're seeing a lack of terrain data (white, or red/white checks). BMA had issues around the US coastline, too, but the recent terrain database (Feb 07) "fixes" the problem and it doesn't look as bad. You might try a software update to see if the "fix" applies to the NZ coastline, too. I wouldn't bet on it... but it's worth a shot.
It shouldn't affect the operation of the unit at all, but it will certainly be annoying seeing all of that checkerboarded terrain! If the software update doesn't change things, send notes to both Greg and Ross directly (greg(at) and ross(at)bluemountainavionics.com (ross(at)bluemountainavionics.com)) to see if they can work the problem. They're busy, but it's uncommon for them not to respond at all.
Good luck!
D
[quote]Time: 05:19:53 PM PST US
From: Keith Hickling < keithhickling(at)clear.net.nz (keithhickling(at)clear.net.nz)>
Hi Trev,
Keith Hickling,
New Zealand,
XS mono kit 613.
UVTReith(at)aol.com Guest
Posted: Mon Apr 16, 2007 1:58 am Post subject: EFIS thoughts |
Hi All, looking for an EFIS like Dynon.
As the smart-Brabus engine has no connection for vauum pump I sold that stuff and bought an Dynon D100.
Yes- it's true, you have to pay in advance without security.
With my big other instruments still in hand, I simply made a new panel layout for the monowheel.
The four 80 mm (3 1/8") instruments ASI - VSI - ALT will go on top (from left to right) and the electr. turn c. will go left beside the D100. Then I have two 57 mm (2 1/4") holes - one for prop setting and one still free - maybe for S-code Transponder.
PLease see attached picture.
Good building and flying to all,
Bruno
Description: |
Filesize: |
37.58 KB |
Viewed: |
243 Time(s) |
jodel(at)nildram.co.uk Guest
Posted: Mon Apr 16, 2007 6:50 am Post subject: EFIS thoughts |
I’ll second that. We have a D180 in our Europa. Never had a problem with either the “flying” or “engine” side of it or updating it.
Reading some of the questions on the Dynon forum I would not trust some of those builders to wire up a household plug let alone an EFIS.
The D180 has over eighty connections (if all inputs are used) so I would recommend using their colour coded harnesses.
Simon
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Peter Rees
Sent: 15 April 2007 18:58
Peter
