keithhickling(at)clear.ne Guest
Posted: Fri Apr 13, 2007 11:29 pm Post subject: brake hose routing XS mono |
Evening all,
Can someone please help me with the routing of the brake hose? The manual says to rout it from the brake caliper up the swing arm, forward of the LG08 retraction arms and over the top of the large horizontal tube of the LG mounting frame that the LG09 shaft goes through, up to the top of the tunnel and back to the master cylinder.
But my hose is 15 - 20 cm too short for that routing. It is 121 cm long from the screw fittings, and this is not long enough even to go directly from the master cylinder directly forward to the large tube on the LG mounting frame and directly back to the slave cylinder. Roger Bull tells me that 121 cm is the standard length. So have I misunderstood the manual? Has anyone else had this problem? Can someone with it accessible please measure the length of their hose for me?
Keith Hickling,
New Zealand,
Kit 613
NevEyre(at)aol.com Guest
Posted: Sat Apr 14, 2007 9:01 am Post subject: brake hose routing XS mono |
Hi Keith,
There was a batch of brake lines sent out by Europa [ the '' old '' Europa ] that were too short, guess you must have one of those ?
Get EO4 to supply you with a length to suit, tell them it is the BLACK line you need. You don't need the fittings [ cut them off the old one ] as the ends get flared the first time you fit the pipe.
Nev.
william(at)wrmills.plus.c Guest
Posted: Sat Apr 14, 2007 9:21 pm Post subject: brake hose routing XS mono |
Keith et al,
I know of at least two Europa Monos that lost all braking owing to a leak in the brake pipe, because the brake pipes were retained by plastic cable ties. Apparently the cable ties eventually wear through the nylon and release all the brake pressure when it is needed! I replaced mine before it happened, but this time I routed the pipe to cut the corner, i.e. the bend is inside the swinging arm pivot point. This way I can keep a check on the whole length of pipe and I also use rubber lined "P" clips to retain it in position and a sleeve of split silicone tube to protect it where it might rub on the walls of the U/C tunnel. If you consider routing yours this way, I would expect your pipe is long enough.
William
Posted: Sat Apr 14, 2007 11:39 pm Post subject: brake hose routing XS mono |
Thanks William. Did you route yours along the wall of the tunnel going forward from the master cylinder? I have considered this routing - forward and down from the master cylinder, crossing the rudder cable just behind the tufnol rubbing block and against the tunnel wall (my rudder cables are in nylaflow tubing anyway). Then a gentle curve passing a little behind the swing arm bearings, then back down the swing arm. As you say, my cable is just long enough for this route. And I'll avoid cable ties!
No problems with your redo?
Keith.
Posted: Sun Apr 15, 2007 1:31 am Post subject: brake hose routing XS mono |
Yes, that is the exact route. A nice gentle curve against the tunnel wall from the master cylinder forwards and down to the top of the swinging arm passing inside the rudder cables. Most Monos have rotated the slave cylinder rear-wards, so that it is horizontal when the U/C is retracted; inline with the forks. It is less vulnerable when on the ground and is out of the slipstream when retracted. No problems with the redo.
William
