Clem Nichols
Joined: 10 Jan 2006 Posts: 88 Location: Munfordville, Ky
Posted: Fri Apr 13, 2007 6:21 am Post subject: loctite on spinner bolt |
Personally I have never used any type of loctite on my spinner bolt, and it has never been a problem. My prop is also a left-turning one. If you feel that you must use loctite, then use the blue rather than the red. Once it's set up the red can be loosened only by heating it, and I don't think you want to put a torch to your spinner.
Clem Nichols
davef(at)cfisher.com Guest
Posted: Fri Apr 13, 2007 6:32 am Post subject: loctite on spinner bolt |
I am pretty sure UHS calls for blue locktite on the spinnersi have installed.
http://uhsspinners.com/index.html
Don't have the sheet in front of me though.
They do make a class spinner and are locally near me .
That being said , I have not used loctite on some other spinners and never had an issue.
Dave
kitfoxmike
Posted: Fri Apr 13, 2007 11:01 am Post subject: Re: loctite on spinner bolt |
If this is the spinner that has a single bolt on the front, I would say yes indeedy you need locktite on the bolt. I have that type on the IVO prop that I just put on and the instructions say locktite and torque to 35inch pounds, right, no way, I went to 100 inch and used red locktite. Oh and if you haven't had a spinner come off, wait until one does come off, I personally have had this happen, thought it was a bird and until I landed and found the spinner gone and two blades wiped. Locktite and torque and check regularly. After all anything that is bolted on the airplane needs to be installed as best as can be. After all you are up in air not on the ground traveling along.
