kkinney
Posted: Thu Apr 12, 2007 10:32 am Post subject: Exhaust spacing |
Pardon me if this is a stupid question, what are the design considerations for routing the exhaust system stubs?
Bingelis says the obvious stuff like don't route them too close to anything, I'm hoping for something more specific.
How close is too close to the fiberglass cowling? Or too close to the firewall?
How much stub do we hang out in the wind?
Any thoughts are welcome.
Thank you,
Kevin Kinney
agustafson(at)chartermi.n Guest
Posted: Thu Apr 12, 2007 1:29 pm Post subject: Exhaust spacing |
Good questions. I'm waiting for the answers too!
Aaron
Quote: | Pardon me if this is a stupid question, what are the design considerations
firewall?
Posted: Thu Apr 12, 2007 1:48 pm Post subject: Exhaust spacing |
Kevin,
The exhaust system should have at least half an inch clearance between
fiberglass parts and air should be directed in
a way that allows flow between these items. On the firewall, you need
to keep exhaust as much as 3 inches or more off
it so that any electrical pumps, lines or hoses aren't affected by
radiated heat. Another good item is wrapping the exhaust
to contain radiated heat to where it leaves the pipes. It's very
effective. You may, depending on the horsepower output
and rpms you run, require a bit more than the half inch for fiberglass.
I replaced fiberglass that was that proximate with
aluminum pieces that are less affected. They cool better and don't
conduct as much heat into the fiberglass that they blend
with. First link shows the fiberglass that ultimately browned by the
heat. Second link shows the aluminum inserts
and the third link shows how paint tends to blend the aluminum and the
fiberglass parts so they're not noticed.
http://www.macsmachine.com/images/cowling/full/lowercowl1.gif
http://www.macsmachine.com/images/cowling/full/cowlfairingsinside.gif
http://www.macsmachine.com/images/completion/full/601ezclosefrtrt.gif
More pictures on the site if you're curious,
Good luck,
Thank you,
Kevin Kinney
http://forums.matronics.com/viewtopic.php?p=106539#106539
n801bh(at)netzero.com Guest
Posted: Thu Apr 12, 2007 5:30 pm Post subject: Exhaust spacing |
The best way to explain this is to remember your EGTs will be showing 1400+ degrees f. Now turn on your electric stovetop to high, see the burners glowing nice and orange, and HOT.. That is about 1375 degrees. Hold your hand close and see how long you can stand it. Now build your firewall forward components keeping that in mind.. Radiant heat is nothing to fool around with. It can and will start fires..
Ben Haas
N801BH
www.haaspowerair.com
-- "kkinney" <kkinney(at)fuse.net> wrote:
--> Zenith-List message posted by: "kkinney" <kkinney(at)fuse.net>
Thank you,
Kevin Kinney
http://forums.matronics.com/viewtopic.php?p=106539#106539 [quote][b]
