bldgrv10450(at)comcast.ne Guest
Posted: Sun Apr 08, 2007 4:31 pm Post subject: Tunnel access |
Gary
I was considering access panels on the sides of the tunnel.
I contacted Van's about the option and they said: "What do you want that for, you can remove the tunnel cover?"
I am planning for a molded dash / console and wanted to be able to service the tunnel without removing seats and other trim.
Are you planning something like this?
Has anyone put access panels on the sides of the tunnel?
I called Van's with concerns about compromise of the structural panels.
Paul Grimstad
RV10 40450
Portland, Or.
speckter(at)comcast.net Guest
Posted: Mon Apr 09, 2007 5:36 am Post subject: Tunnel access |
I am using the standard setup per Vans Plans. Did they tell you how you can remove the cover with the seats in?
Gary
40274
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Paul Grimstad
Sent: Sunday, April 08, 2007 8:31 PM
Subject: Tunnel access
Gary
Paul Grimstad
RV10 40450
Portland, Or.
Vern(at)teclabsinc.com Guest
Posted: Mon Apr 09, 2007 6:33 am Post subject: Tunnel access |
How about cutting the front tunnel into two section right in front of the fuel selector? A slicer plate could then be added across the inside, much like the way the front and back tunnel covers join. This way the front section of the tunnel could be uncovered without removing the section between the seats or the seats. This could be modified as needed if an armrest was planned.
Vern (#324 fuselage)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gary
Sent: Monday, April 09, 2007 6:36 AM
Subject: RE: Tunnel access
Gary
40274
Gary
Paul Grimstad
RV10 40450
Portland, Or.
[/b]http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com[/b]01234567890
scottmschmidt(at)yahoo.co Guest
jjessen
Posted: Mon Apr 09, 2007 8:22 am Post subject: Tunnel access |
Hey, Scott, I think that panel looks a little sparse. You should think about adding a DVD player or something! My goodness....! Nice.
John (envious) Jessen
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt
Sent: Monday, April 09, 2007 8:42 AM
Subject: Re: Tunnel access
I am going to cut access holes in the side for sure because of the throttle quadrant. It is ALOT of work to remove that quadrant and it would be so nice to take a plate off to check the fuel filter and have access for anything else.
Abby at Flightline Interiors made the stick covers. I ran my wire on the outside of the stick and this covered it nicely.
Scott Schmidt
----- Original Message ----
Sent: Monday, April 9, 2007 7:31:21 AM
UNKNOWN { FONT-FAMILY: Tahoma; panose-1: 2 11 6 4 3 5 4 4 2 4 } P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } A:link { COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline } A:visited { COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlinkFollowed { COLOR: blue; TEXT-DECORATION: underline } PRE { FONT-SIZE: 10pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Courier New" } SPAN.EmailStyle18 { COLOR: navy; FONT-FAMILY: Arial } SPAN.EmailStyle19 { COLOR: navy; FONT-FAMILY: Arial } UNKNOWN { MARGIN: 1in 1.25in } DIV.Section1 { }
Gary
40274
Gary
Paul Grimstad
RV10 40450
Portland , Or.
5 [quote][b]
Posted: Mon Apr 09, 2007 9:38 am Post subject: Tunnel access |
Scott,
After seeing your counsel, I’d go with side plates too.
By the way where did you get the carpet set?
Vern (#324)
Scott Schmidt
Gary
40274
Gary
Paul Grimstad
RV10 40450
Portland , Or.
Posted: Mon Apr 09, 2007 11:55 am Post subject: Tunnel access |
Abby at Flightline Interiors did the carpet kit. Tim Olsen has a nice write up on his website about it.
http://www.myrv10.com/N104CD/interior/20051230/index.html
Her website is:
http://my.execpc.com/~erdmannb/
Out of every single vendor I have had to deal with to build this plane, Abby gets the number 1 spot by far!!! She is accurate, on-time, and fairly priced.
The interior fits great, was easy to install and looks great.
Scott Schmidt
mritter509(at)msn.com Guest
Posted: Mon Apr 09, 2007 1:32 pm Post subject: Tunnel access |
I'll second that on Abby. Great interior and fun to work with.
Mark
N410MR
[quote]From: Scott Schmidt <scottmschmidt(at)yahoo.com>
Date: Mon, 9 Apr 2007 12:55:19 -0700 (PDT)
Her website is:
priced.
Scott Schmidt
Posted: Mon Apr 09, 2007 2:16 pm Post subject: Tunnel access |
Thanks for the testimonial and contact info.
Vern (#324)
Sent: Monday, April 09, 2007 12:55 PM
Her website is:
Scott Schmidt
papadaddyo(at)tampabay.rr Guest
Posted: Mon Apr 09, 2007 6:14 pm Post subject: Tunnel access |
Hey Scott, I really like the looks of your panel. Any chance of getting some more photos?
Rick Leach
40397
Sent: Monday, April 09, 2007 11:42 AM
Scott Schmidt
Gary
40274
Gary
Paul Grimstad
RV10 40450
Portland , Or.
LloydDR(at)wernerco.com Guest
Posted: Tue Apr 10, 2007 12:37 pm Post subject: Tunnel access |
I would also chime in here, she has been great to work with and ensures her customers are happy.
Dan
N289DT
DAVELEIKAM(at)wi.rr.com Guest
Posted: Tue Apr 10, 2007 5:10 pm Post subject: Tunnel access |
I will be using Abby, due mostly to all the positive comments and her shop
is about 3 miles from my shop!
Dave Leikam
40496
