SteveD
Posted: Thu Apr 05, 2007 3:27 pm Post subject: Glue |
I am about ready to put in the cockpit module and my glue is way out of date - how much will I need to buy to do the cockpit module and finish up the plane? (I have both sets of wings.) Any guesses?
Gary Leinberger
A237
Lancaster, Pa.
Hi Larry,
Where to buy was just covered on the list look here:
http://www.europaowners.org/viewtopic.php?p=14490#14490
I used just under two kits of the stuff total, Cockpit module was the single largest user.
Andrew has the best archive search engine:
http://www.sarangan.org/~sarangan/mharc/html//europa-list/2007-04/index.html
Chat Later,
Steved
Visit - www.EuropaOwners.org
96victor(at)gmail.com Guest
Posted: Thu Apr 05, 2007 4:43 pm Post subject: Glue |
Hi Gary
Don't throw your old stuff out. It works years later if it doesn't harden and is useful for lots of non structural uses.
Tom
On 4/5/07, SteveD <Post2Forum(at)comcast.net (Post2Forum(at)comcast.net)> wrote: [quote]--> Europa-List message posted by: "SteveD" <Post2Forum(at)comcast.net (Post2Forum(at)comcast.net)>
Gary Leinberger
A237
Lancaster, Pa.
Hi Larry,
Chat Later,
Steved
DuaneFamly(at)aol.com Guest
Posted: Thu Apr 05, 2007 4:51 pm Post subject: Glue |
Gary,
And if the yellow portion starts to crystallize....simply place it in a pan of water (WARNING! Don't use one of your wife's good pots!) and heat it up to just below a boil and the crystals will be reabsorbed.
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300
Sensenich R64Z N
Ground Adjustable Prop
See what's free at AOL.com.
hagargs(at)earthlink.net Guest
Posted: Thu Apr 05, 2007 6:31 pm Post subject: Glue |
Make a lap shear test coupon of fiberglass bid the same number of layers or
strength of what you want to bond together. If the fiberglass breaks
before your lap joint debonds or pulls apart you can be confident that you
goo is still good.
Steve Hagar
A143
Mesa AZ
| Quote: | [Original Message]
Date: 4/5/2007 4:31:11 PM
Subject: Re: Glue
