asarangan(at)yahoo.com Guest
Posted: Thu Apr 05, 2007 8:15 am Post subject: CNC foam cutter |
I built a CNC foam cutting machine some time back, so I was able to hot
wire nicely shaped aileron mass balance horns. I know it is just as
easy to make them with a sanding block, but I thought I would put the
word out in case anyone wants these horns. I already have the design
file, so it would take just two minutes to make additional parts. I
will send them to you for free. In fact, I am willing to offer my CNC
cutter for any other Europa foam cutting applications you may want to
try out.
Andrew Sarangan
http://www.sarangan.org
josok-e(at)ukolo.fi Guest
Posted: Thu Apr 05, 2007 12:43 pm Post subject: CNC foam cutter |
Sure Andrew,
What about the base for a battery tray for the bagage bay(to cover with
glass & epoxy) and seat- bottoms and backs?
If you cut the foam, i am willing to make mouldings to make the actual
things, to put on loan for everybody.
Kind Regards,
Jos Okhuijsen
workshopcam http://www.okhuijsen.org/plane
http://www.europaowners.org/kit600
