dean.psiropoulos(at)veriz Guest
Posted: Sun Apr 01, 2007 9:24 pm Post subject: Poly pitot/static lines. |
Question on those plastic fittings that screw into the back of airspeed,
altimeter, etc to connect pitot and static lines. I'm using the paraflex
that came with Van's static port kit but I'm wondering about how much torque
to put on the fittings to get them to seal properly. I've installed the
fittings into the back of the Dynon EFIS and tightend them as tight as I
could by hand then put a wrench on them for about another quarter turn. I
figure that there is already A LOT of threads into the brass female fitting
and I didn't want to strip the threads in the plastic fitting. Is an extra
quarter turn enough? Is there a spec for tightening these types of
fittings? Please advise.
Also the paraflex (plastic/nylon) tubing that goes into these fittings,
after you hand tighten the nut enough so that the ferrule grips the tubing,
how much more should you tighten to ensure a good seal? Does this tubing
require the little inserts that go into the ends (of the tubing) in order
make a good seal or can it be achieved without them (these inserts did NOT
come with fittings I ordered from Gulf Coast avionics)? Thanks.
Dean Psiropoulos
RV-6A N197DM
Last details before windshield and prop.
jim jewell
Joined: 09 Jan 2006 Posts: 82 Location: Kelowna B.C. Canada
Posted: Mon Apr 02, 2007 12:23 am Post subject: Poly pitot/static lines. |
Hello Dean,
Google SMC fittings To view alternative fittings.
They cost a bit more But I think their system is a good alternative choice.
Jim in Kelowna - 1.3 hr
_________________ "I never make mistreaks" |
rv8iator
Posted: Mon Apr 02, 2007 5:43 am Post subject: Poly pitot/static lines. |
Dean...
Used these in first RV-8. Still waiting for first flight next month.
I use this tubing and these connectors at work to test our products. Typically hand tighten and then 1/4 turn for final snug. I am pressurizing these connections to 100 - 200 psi. No leaks.
All my tubing is Parker Parflex polypropelene. (The same stuff Van's sells) Fittings are Parker nylon w/O-ring, stainless steel grasp ring and nut.
Chris
RV-8 x 2
Dean Psiropoulos
RV-6A N197DM
_________________ C. Stone (RV8iator) |
mrobert569(at)hotmail.com Guest
Posted: Mon Apr 02, 2007 9:47 am Post subject: Poly pitot/static lines. |
Dean,
With the plastic fittings what you have described for the tightening should be good. hand tigh with about another 1/4 turn with the wrench. You will find out if they leak when you do the pitot static test .
Good to hear from you. How close are you to being done?
Mike Robertson
> Date: Mon, 2 Apr 2007 01:23:11 -0400
| Quote: | From: dean.psiropoulos(at)verizon.net
Subject: Poly pitot/static lines.
To: rv-list(at)matronics.com
--> RV-List message posted by: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Dean Psiropoulos
RV-6A N197DM
i'm making a difference. Make every IM count for the cause of your choice. Join Now.
