TELEDYNMCS(at)aol.com Guest
Posted: Sun Apr 01, 2007 6:34 am Post subject: The long pin |
In a message dated 4/1/2007 3:01:45 AM Eastern Daylight Time, europa-list(at)matronics.com writes:
| Quote: | | If it does not work, using a hammer usually helps! |
Jos,
Those are referred to as "calibration mallets" in the engineering world......
John Lawton
Dunlap, TN (TN89)
N245E - Flying - about to take on Mod 72
DO NOT ARCHIVE
See what's free at AOL.com.
josok-e(at)ukolo.fi Guest
Posted: Sun Apr 01, 2007 9:08 am Post subject: The long pin |
Thanks for that John,
Now i do not have to fear using a hammer on delicate things like a bearing any more.
I will use a "calibration mallet" instead!
Jos Okhuijsen
Visit - www.EuropaOwners.org
n914va(at)bvunet.net Guest
Posted: Sun Apr 01, 2007 2:18 pm Post subject: The long pin |
Please note that if you are driving a bearing into a tight recieving area, a
piece of pipe or a socket must be placed over it, so that you are only
appling force to the outer race of the bearing. Otherwise you will damage
the bearing with your calibration mallet.
Vaughn
