josok-e(at)ukolo.fi Guest
Posted: Thu Mar 29, 2007 3:18 am Post subject: 914 servo init |
Hi 914 folks,
This is a new engine, first try. After the TCU runs through it's checks, and runs the servo/waste gate back and forth, the servo keeps making a noise like not finding it's zero position. The servo is not really moving, not visible at least.
What could be wrong? I had to remove/attach the servo cable cause of routing, it it now too tight or too loose? Can't find real instruction in the manuals.
Visit - www.EuropaOwners.org
rehn(at)rockisland.com Guest
Posted: Thu Mar 29, 2007 9:36 am Post subject: 914 servo init |
The servo motor will make a slight buzz noise as it waits for the TCU to
start telling it something to do! You wont hear it when the engine is
running! The servo is likely fine.There are instructions for setting the
cable and waste gate in the installation manual. Switch on the TCU, the
servo motor runs with waste gate closed, slacken the adjustment screw on
servo cable support(located at turbo where cable first attaches to turbo)
and turn adjustment screw until wastegate is completely closed, proper
pretensioning of the servo cable is achieved by turning the adjustment screw
by one complete rotation.
All this is done at the factory in the course of the test run for the engine
but if disconnected it could be off. Hope this helps.
Jerry
Posted: Thu Mar 29, 2007 10:26 am Post subject: 914 servo init |
Thanks Jerry,
| Quote: | The servo motor will make a slight buzz noise as it waits for the TCU to
That's reassuring, nothing wrong then!
workshopcam http://www.okhuijsen.org/plane
http://www.europaowners.org/kit600
mono xs, plane at the painter, working on the panel.
