rehn(at)rockisland.com Guest
Posted: Sun Mar 25, 2007 7:41 am Post subject: ceramic coated exhaust |
Has anyone ceramic coated their exhaust system? Jet Hot www.jet-hot.com is
suppose to reduce temperatures about 200 F. Apparently is widely used among
high performance racing. Could this help reduce cowl temps without causing
other isues?
Jerry
cptimm(at)telus.net Guest
Posted: Sun Mar 25, 2007 9:11 am Post subject: ceramic coated exhaust |
Hi Jerry,
I had my exhaust pipes ceramic coated before taking the aircraft into
service, since I had bought the 912S for my classic mono, and knowing, that
the 912S runs much hotter than the 912. I don't know what the difference
would have been , but have had no problems in 350 hrs , some of the flying
in very hot conditions in Arizona. I would recommend it.
Peter Timm
# 110, C-GIET
on 07/3/25 8:40 AM, Jerry Rehn at rehn(at)rockisland.com wrote:
other isues?
Jerry
Hi Jerry,
I've had my exhaust pipes ceramic coated before taking the aircraft into
service. My Europa is a Classic with a 912S and has 350 hrs on it . I could
not tell if it made a difference, but things get pretty hot under my cowl,
with everything being so tight. It was not very expensive, as I recall
Peter Timm
# ll0 , C-GIET
Posted: Sun Mar 25, 2007 1:21 pm Post subject: ceramic coated exhaust |
Hello Peter
"I had my exhaust pipes ceramic coated before taking the aircraft into
service"
Who did the coating?
What type and what color?
Thx.
Ron Parigoris
I was planning on using:
http://www.performancecoatings.com/
For 914 exhaust and also their thermal dissipating/protective coating for
aluminium intercooler and water radiator
william(at)wrmills.plus.c Guest
Posted: Sun Mar 25, 2007 9:07 pm Post subject: ceramic coated exhaust |
Does anybody know if ceramic coating increases the durability of the pipes?
In my experience, they seem to last for only about 450 hours. (Classic
exhaust)
William
Posted: Sun Mar 25, 2007 11:56 pm Post subject: ceramic coated exhaust |
Jerry Rehn a écrit :
| Quote: | Has anyone ceramic coated their exhaust system? Jet Hot
www.jet-hot.com is suppose to reduce temperatures about 200 F.
Apparently is widely used among high performance racing. Could this
help reduce cowl temps without causing other isues?
We had the exhaust pipes coated in the US (regular Rotax 914 pipes).
Nice black coating, looks great when new. After 120 hours, the look is
still correct, but some scales are peeling off in some area.
200 F seems somewhat optimistic to me.
Considering physics, it sure should improve temperatures a bit, but the
pipes still run dull red when running up at night, and I would not rely
on it to significantly reduce cowl temps.
FWIW,
Gilles
http://contrails.free.fr
karelvranken(at)hotmail.c Guest
Posted: Tue Mar 27, 2007 12:04 pm Post subject: ceramic coated exhaust |
Peter,
You are talking about the pipes that are coated. And the muffler? Can it be
done as well?
Karel Vranken # 447 F-PKRL
| Quote: | I had my exhaust pipes ceramic coated before taking the aircraft into
that
Peter Timm
# 110, C-GIET
> is
> among
> causing
> other isues?
> Jerry
Hi Jerry,
could
cowl,
Peter Timm
# ll0 , C-GIET
Mijn Postvak In wordt beschermd door SPAMfighter
0 spam-mails zijn er tot op heden geblokkeerd.
Download de gratis SPAMfighter vandaag nog!
Posted: Tue Mar 27, 2007 2:39 pm Post subject: ceramic coated exhaust |
Did they coat the inside of pipes as well? If so is there any possibility of
coating coming off on inside and causing issue with turbo? Thanks
Jerry
Posted: Wed Mar 28, 2007 1:08 pm Post subject: ceramic coated exhaust |
Gottfried,
Thank you for the quick answer. Tomorrow I will expedite the whole exhaust
system to England.
Mit freundlichen Grüssen,
