nfivesl(at)yahoo.com Guest
Posted: Sun Feb 05, 2006 7:31 pm Post subject: 601 Canopy Latches |
601 Plans-builders:
I have been unable to find a source for the canopy
latches for my 601 canopy frame.
If anybody has a source and part number I'd really
appreciate it.
Thanks in advance,
Scott Laughlin
www.cooknwithgas.com
tshank(at)megsinet.net Guest
Posted: Sun Feb 05, 2006 8:05 pm Post subject: 601 Canopy Latches |
Which canopy?
TIm Shankland
N5SL wrote:
601 Plans-builders:
appreciate it.
Thanks in advance,
Scott Laughlin
webmaster(at)upac.ca Guest
Posted: Mon Feb 06, 2006 5:35 am Post subject: 601 Canopy Latches |
Scott, those can be sourced from Spaenaur in Kitchener Ontario (it's
where I got mine after looking all over the place including McMaster)
http://www.spaenaur.com/contact.asp
The part number is 099-324 and 099-325 (right and left sides)
Catalog page is here : http://www.spaenaur.com/view_pdf.asp?Page=L70
If I remember correctly I cut off the latch and welded a new once in
the correct position
Trev Page
C-IDUS 601HD R912
On Feb 5, 2006, at 10:23 PM, N5SL wrote:
601 Plans-builders:
appreciate it.
Thanks in advance,
Scott Laughlin
Larry McFarland
Joined: 10 Jan 2006 Posts: 36 Location: East Moline, Illinois
Posted: Mon Feb 06, 2006 7:16 am Post subject: 601 Canopy Latches |
*Scott,
I purchased my latches from Zenith, but they can be possibly purchased
from the company below.
Also, if you're going to use the same latches, welded to the frame, you
want to be cautious about welding in proximity to springs in the mechanism.
I welded short segments and used a hose to dampen and protect the springs.
SPAE-NAUR company, Toronto. They can be purchased from the Windsor
| Quote: | > >Factory Supply 519-966-2202. The part numbers are 099-031 for the left
hand
> >one and 099-030 for the right hand one. They cost $36.40 Canadian each.
Larry McFarland - 601HDS
N5SL wrote:
601 Plans-builders:
appreciate it.
Thanks in advance,
Scott Laughlin
_________________ Larry McFarland - 601HDS - Stratus |
