gottfried.komaier(at)gmx. Guest
Posted: Tue Mar 27, 2007 1:36 pm Post subject: AW: ceramic coated exhaust |
Karel,
Yes you can do.
The coating on my Rotax 914 exhaust system was done here in Europe. All the pipes, the muffler and the hot side of the turbocharger for ~ € 400.-
Have a look at:
http://www.zircotec.com/exhaust.html
I hope this helps,
Gottfried Komaier
Vienna, Austria
-----Ursprüngliche Nachricht-----
Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von karelvranken
Gesendet: Dienstag, 27. März 2007 22:11
An: europa-list(at)matronics.com
Betreff: Re: ceramic coated exhaust
--> <karelvranken(at)hotmail.com>
Peter,
You are talking about the pipes that are coated. And the muffler? Can it be done as well?
Karel Vranken # 447 F-PKRL
| Quote: | I had my exhaust pipes ceramic coated before taking the aircraft into
service, since I had bought the 912S for my classic mono, and knowing,
that the 912S runs much hotter than the 912. I don't know what the
difference would have been , but have had no problems in 350 hrs ,
some of the flying in very hot conditions in Arizona. I would
recommend it.
Peter Timm
# 110, C-GIET
on 07/3/25 8:40 AM, Jerry Rehn at rehn(at)rockisland.com wrote:
> Has anyone ceramic coated their exhaust system? Jet Hot
> www.jet-hot.com is suppose to reduce temperatures about 200 F.
> Apparently is widely used among high performance racing. Could this
> help reduce cowl temps without causing other isues?
> Jerry
Hi Jerry,
I've had my exhaust pipes ceramic coated before taking the aircraft into
service. My Europa is a Classic with a 912S and has 350 hrs on it . I
could
not tell if it made a difference, but things get pretty hot under my
cowl,
with everything being so tight. It was not very expensive, as I recall
I would recommend it.
Peter Timm
# ll0 , C-GIET
Mijn Postvak In wordt beschermd door SPAMfighter
0 spam-mails zijn er tot op heden geblokkeerd.
Download de gratis SPAMfighter vandaag nog!
Posted: Tue Mar 27, 2007 3:06 pm Post subject: AW: ceramic coated exhaust |
Jerry,
only the outside of the exhaust system and the turbo is coated. So you have
not the problem that coating coming off.
Gottfried
[mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Jerry Rehn
Gesendet: Mittwoch, 28. März 2007 00:38
Did they coat the inside of pipes as well? If so is there any possibility of
coating coming off on inside and causing issue with turbo? Thanks Jerry
