peterc(at)pipcom.com Guest
Posted: Mon Mar 12, 2007 8:16 am Post subject: float rigging |
Is anyone aware of any significant document that goes into detail on the various aspects of hanging floats on an aircraft?
I've heard the assorted rules of thumb about step placement and angle and have successfully mounted floats before but I'm curious about what is behind some of the ideas and the affects of deviating from them.
For example one formula says mount the step 1/4 (or 1/3) of the WIDTH of the float behind the cg. Where does this come from? How does float width affect this?
Another says mount the step so as to intersect a line drawn 6 degrees aft of the cg. This imples that height of the rigging affects step placement.
What are the factors affecting height above the floats?
Why is loading never mentioned? In other words wouldn't the step position be of more interest to the cg at gross than empty cg?
Surely there is a reference book on this somewhere. I was not successful with google searches.
Peter
| - The Matronics Seaplane-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Seaplane-List |
Float Flyr
Posted: Mon Mar 12, 2007 10:29 am Post subject: float rigging |
the recipe I use for locating the installation point for floats is:
*Obtain one float
*Obtain a small body of water .
*Put the float in the body of water.
*Start filling the front compartment of the float and continue until the float floats level.
*Remove the float from the body of water.
Now it gets tricky
*Obtain a stick about two feet long and 4'-10' in diameter ( about the size of a nice stove billet )
*Rest the float on the stick so the stick supports the keel of the float and roll it ahead until the float is balanced.
*Measure the distance back from the front of the float the stick is.
*drain the water out of the float.
*Mount the floats so the CG of the plane is the same distance back from the front of the floats as the measurement tow steps ago.
Install the float so the AOA of the plane is about 1-3deg up.
No mixing required
No oven stove or refrigerator
Also no ballast required to get the plane up on step.
Weakness of recipe:
For planes that are tandem seating the overloading of the back seat will cause the tails of the floats to sink. For such planes put the CG over the balance point of the floats when the plane has a medium load...with the landing gear removed.
The whole idea is to get the plane to float more or less level at rest in the water.
There are some who intentionally float planes like the super cub with too much weight forward. These planes require carrying ballast in the back seat to enable the plane to get up on step. They also enable the plane to carry a whopping big load behind the pilot.
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
cathyboone(at)softcom.net Guest
Posted: Wed Mar 14, 2007 8:25 pm Post subject: float rigging |
Not aware of any document, but you might try to contact the folks at Kemore Air Harbor in the state of Washington.
Posted: Fri Mar 16, 2007 11:07 am Post subject: float rigging |
Larry I tried Kenmore but thay had nothing.
Noel's method sounds interesting and I plan to try it when the ice goes out.
After asking around I now have five approaches for locating the step relative to the cg: One was a fixed distance for my particualar plane (which has worked in the past but puts the step closer to the cg than the other methods); another used the 50% chord point (and was argued strongly by a long term aircraft and float designer); another puts the step on a line 5 degrees aft of the cg. another used 1/3rd the width of the float; and , finally, Noel's method to calculate the center of bouyancy of the float. There is likely a similar bases for Noel's and the 1/3 width method which may also be related to center of bouyancy.
No one that I have asked has ever seen any document on this.
Peter
d(at)cfisher.com Guest
Posted: Fri Mar 16, 2007 11:17 am Post subject: float rigging |
Peter, I had posted this on another list earlier and he has some downloads on that site wtih some info that might help you .
Dave
http://www.cfisher.com
more flying stuff ........
You glass guys have most likely run into a set of these floats, very
popular with the SuperCub guys.
Well a little big for Kitfox but these are my neighbour's product and
becoming very popular.
http://www.clamarfloats.com
It has been very popular so far and now a 3500 will be dressing up the
Murphy Mooses this year. Look for him as Sun n Fun if you are going.
After seeing the results,I would say that these have proven to be one of the
toughest floats on the market now.
I flew in there on Monday this week with 16 inches now - now it about 95%
gone.
And before you ask , he wil not be making anything under 2200s unless you
are willing to pay 25k for striaght floats. Personally I think there is
market for a 1400 to 1600 float for LSA stuff and there are some new ones to
surface in the next year or so.
That being said the Aerocet 1100s a decent float but could affoard to be a
little bigger displacement on the heavier Kitfoxes.
What would you pay for a set of floats ?
1400s straight or amphib ?
Dave
Posted: Tue Mar 20, 2007 4:52 pm Post subject: float rigging |
Peter, I'm glad you are putting some effort into the research. I only have about 200 hrs on floats and most of that is in Alaska flying for an outfitter. Half of the time (taking clients out) the plane was loaded very heavy and of course the weight was is the back. I can only think of two times I had to load the float compartments. By the way, I am putting together an S5 and eventually want to take it to Alaska on floats. I believe if I had a choice, I would favor the CG to the safest point forward on the floats because of the tendency to pile in gear to the aft. This includes long items tied on the floats. But I don't suppose you will be using the kitfox this way. Another consideration is how the plane actually handles forward and aft loading of the CG on wheels. Remember, I am used to maximum performance of the aircraft because of the generally cooler weather up there and I have not flown the kitfox in any configuration except for a demonstration flight with tricycle gear in Caldwell during the summer. Good luck and keep us informed!
Float Flyr
Posted: Tue Mar 20, 2007 5:47 pm Post subject: float rigging |
If I read the documentation on my modIII-A the weight is furthest forward at the lightest load. In my case that was empty tanks and a 140lb. pilot. I don't know any one who flies in this area and weighs in at 140.
Noel [quote]
Kitfox III-A
Posted: Tue Mar 20, 2007 8:43 pm Post subject: float rigging |
Yes, and that was my point. The cg should probably as far forward as safely possible when the aircraft is lightest. Then as the load gets heavier the cg moves aft. This affects the performance of the plane getting on step quickly. As a general rule, the quicker you can get on step the better.
Posted: Wed Mar 21, 2007 4:46 pm Post subject: float rigging |
The point about setting up for good performance with an aft cg is sounds reasonable. We have all likely experienced having to move forward in an outboard boat to help get it up on plane. However, a friend pointed out that perhaps the best route is to rig for the most common loading which may be one person and little baggage. Guess it all comes back to personal preference.
One thing I have noticed with two Rans S-7's I've owned which were both rigged with step just a little aft of empty cg is very little tendancey to nose down after touch down. With all ther other certified planes I've flown especially Cessnas is the need to be ready with up elevator after touch down; the Rans needed very little of this.
Peter
Malcolmbru(at)aol.com Guest
Posted: Wed Mar 21, 2007 6:31 pm Post subject: float rigging |
I really enjoy the chatter about float flying and such I have completed my zenair floats but don't expect to install them for a while. I still need to build a trailer and then reg them to my model 2. i have flown several plans on floats and also watch the kolb site, they are talking about Jim lee now and some of the paten's he had for float flying Please keep up the chatter I really enjoy it mal Michigan kit foxer
AOL now offers free email to everyone. Find out more about what's free from AOL at AOL.com.
Float Flyr
Posted: Wed Mar 21, 2007 7:01 pm Post subject: float rigging |
Come back next month when I get my 'Fox in the water!
Darned cold here tonight Blizzard this morning no float flying for a few weeks yet.
G' night all
Noel [quote]
Kitfox III-A
Posted: Fri Mar 23, 2007 8:56 pm Post subject: float rigging |
Peter,
I would encourage personal preference from the standpoint of being comfortable and cautiously confident. Do the floats you have in mind give you much leeway in rigging? Is there room for experimentation?
Posted: Sat Mar 24, 2007 5:55 am Post subject: float rigging |
Peter,
Hello Larry.
Yes, making changes to rigging is a pain and expensive. With the jig I'm building, Ill be able to set up a new set of struts without messing with the current set. Hopefully by starting out with a slightly higher and forward cg setup, I'll be able to modify (shorten) one set to get slightly lower and more aft cg. The streamline tubing I'm using has a thick internal flat which lends itself to changes to the angle at which it contacts the fitting.
This could all be talk once the flying gets started.
I did locata a naca report on some experiments from 1928 but I'm finding it difficult to make sense of.
I'll also be selling rigging to fit the Rans S7 (and maybe the S6 once I get dimensions and modify the jig).
Peter
raymondj(at)frontiernet.n Guest
Posted: Sat Mar 24, 2007 7:30 am Post subject: float rigging |
Peter,
I'm interested in getting the naca reports you mentioned. Where did you get them?
Raymond Julian
Kettle River, MN
[quote] --
Posted: Mon Mar 26, 2007 6:25 am Post subject: float rigging |
Raymond
Here is a one search although I haven't downloaded this one yet. If you search on flying boat or amphibian you will get some hits. http://ntrs.larc.nasa.gov/search.jsp?N=0&Ntk=all&Ntx=mode%20matchall&Ntt=%22small%2Bflying%2Bboats
The one I did get was by H Herrmann from 1938 on twin seaplane floats but the document is hard to relate to our situation (for me anyway)
Peter
Posted: Mon Mar 26, 2007 8:59 am Post subject: float rigging |
Peter,
Thanks for the link.
Raymond Julian
Kettle River, MN
[quote] --
