OAT probe
drfred(at)suddenlinkmail.
PostPosted: Thu Mar 22, 2007 10:00 am    Post subject: OAT probe Reply with quote
Thanks for the info. Will put it in the wing root area. Will keep on
top away from the exhaust.
Fred Williams
Tim Olson
PostPosted: Thu Mar 22, 2007 10:22 am    Post subject: OAT probe Reply with quote
Nooooooooo....not the top. You don't want it affected by
the sun. It needs to be on the underside of the plane, in the shade,
outside of any warm airflows from the engine.
Fred Williams, M.D. wrote:
<drfred(at)suddenlinkmail.com>
Fred Williams
PostPosted: Thu Mar 22, 2007 11:02 am    Post subject: OAT probe Reply with quote
OK ..... not on top. Smile.
Thanks. I am in the process of getting the wiring diagram done with
Accuracy avionics. good bunch to work with.
Again
Thanks for the input.
Dr Fred.
apilot2(at)gmail.com
PostPosted: Thu Mar 22, 2007 11:53 am    Post subject: OAT probe Reply with quote
I also think you want it at least a couple feet out from the wing root
and fuselage, better 4-5 ft. And the top of the wing doesn't separate
it from engine heat, beside getting sun effect. You want to know when
the wing leading edges approach freezing temp. Besides, you already
have access panels on the underside.
> Fred Williams
