ron.mcgann(at)baesystems. Guest
Posted: Wed Mar 21, 2007 2:39 pm Post subject: Tip for Trimming the doors |
I trimmed the return flange of the cabin cover to the scribe lines as directed by the plans and ended up taking off too much. I may need to build up the over trimmed areas with glass/epoxy. The trim lines were straight as a dog's hind leg and very inaccurate.
I was not about to trust the trim lines on the doors. I trimmed the doors yesterday for a pretty darn good fit. After trimming to 1/8" of the scribe line per plans, the trick was to notch the door perimeter down to the scribe line (notches about 1/8" wide) at 6-12" intervals. When clecoed to the deck/fuse, use a fine sharpie to mark the position of the notch on the deck/fuse to check how far away a cut to the scribe line would be from the deck/fuse edge. Adjust the depth of the notches to match the edges of the deck/fuse, then trim to the notches. If a notch is too deep and extends past the edge of the deck/fuse, it is much easier to fill the 1/8" notch than to try and build up an overtrimmed door edge.
YMMV, but it worked a treat for me.
Cheers,
Ron
187 finishing [quote][b]
jhasbrouck(at)woh.rr.com Guest
Posted: Wed Mar 21, 2007 3:09 pm Post subject: Tip for Trimming the doors |
Ron,
Great tip, thanks!
John Hasbrouck #40264
