Posted: Wed Mar 21, 2007 8:48 am Post subject: Hauck Landing Gear Mods |
Hi Gang:
I mentioned the bridge work that carries my modified mkIII landing
gear a few days ago. Here are a couple photos of the bridgework
inside the cockpit.
185.5 KB |
328 Time(s) |
181.88 KB |
363 Time(s) |
_________________ John Hauck
Titus, Alabama |
planecrazzzy Guest
Posted: Wed Mar 21, 2007 1:10 pm Post subject: Re: Hauck Landing Gear Mods |
ut oh, looks like the airplane parts have reached the living room.....
Quite a structure you've got under the seat..... are you able to store stuff
under there on yer cross countrys...?
Gotta Fly...
Mike & "Jaz" in MN
Posted: Wed Mar 21, 2007 1:44 pm Post subject: Hauck Landing Gear Mods |
Hi Mike:
room.....
This is what happens when you got more "stuff" than room. Migrate to
an area big enough to lay stuff out. One of the advantages of being
single again is I can build an airplane in the living room if I want
to.
store stuff
Yes, I store my extra shoes and flip flops under the seat. Also, the
survival rifle, and long tie down stakes and rope will fit under
there.
I still have to do the cutouts for the parachute, which mounts in the
front center of the center section, fuel filler, and an inspection
plate to stick my hand through to tighten up the clamp on the fuel
fill hose after the center section is in place.
The old center section was a combination of lexan and sheet metal.
This one is going to be entirely of sheet metal. The old one lasted
15 years. This one should last a little longer. Can't wait to get it
finished and painted. Think it will look cool. The original was made
for the 582, so I left the sheet metal under the left rear side bare.
This was right under the muffler. When I went to the 912 engines, I
never got around to painting that portion. Always generated questions
why I did not paint that part.
Take care,
Titus, Alabama |
