rparigor(at)SUFFOLK.LIB.N Guest
Posted: Sun Mar 18, 2007 8:22 pm Post subject: Will steel affect antenna operation? |
We are doing battle with filling pinholes and small sand marks in Europa
fiberglass fuse. After trying several methods, Dolphin Glaze thick and
thin, Expancel and Aeropoxy (plastic micro) and Q-Cel and Aeropoxy (glass
micro), I tried JB Weld Kwik.
Seems the JB Weld Kwik is the hands down winner. It is very thick (thicker
than JB Weld) and very sticky. Can squeegee it in place with a razor
blade, and get off 99% and it fills everything and does not shrink or
allow trapped air to force it into a pimple. Sets up in 4 minutes, full
cured pretty hard.
JB Kwik uses steel as a filler. I don't think it is conductive. I tried
putting a magnet on cured sample and tubes and it does not appear to be
conductive.
I will have a Com, a Nav/Com and a Transponder Antenna in the fuse and
rudder.
Think there is a chance that JB Kwik filling small pinholes and very fine
scratches, and lets say some areas with one or 2 ten/thousands" skim on it
will degrade antenna performance to the point that I should not consider
using it?
Thanking in advance
Ron Parigoris
mprather(at)spro.net Guest
Posted: Sun Mar 18, 2007 9:00 pm Post subject: Will steel affect antenna operation? |
My WAG is that the amount/coverage of JB Weld left on the skin will not
have any effect on antenna performance.
I do, however, wonder about your problems with using epoxy for filling
pinholes. I know the EZ builders have had good success filling everything
with micro, sanding to 36 grit contour, and then using pure resin to fill
pinholes and sanding scratches - squeegee'ed on in multiple coats without
sanding between. I could imagine that cabosil might be used used to make
the resin less runny, which might help the resin fill better.
Cory Bird's description of the process is here:
http://www.sportsmanpilot.com/AL/articles/spr2003/Spring2003.htm
"Next came what Cory calls a resin wipe. After going over the surfaces
with 36 grit sandpaper he spread on a coat of pure resin, then immediately
began squeegeeing it all off. With a little time for cure between
applications, this process was repeated five times, leaving just a film of
resin maybe two or three thousandths thick, filling every 36 grit scratch
and all the pin holes. That was followed by wet sanding with 150 grit,
then a coat of DP-48 epoxy primer and a guide coat of some color - just
enough to see when
it is sanded off."
Matt-
cured pretty hard.
conductive.
rudder.
using it?
Thanking in advance
Ron Parigoris
nuckollsr(at)cox.net Guest
Posted: Mon Mar 19, 2007 4:41 am Post subject: Will steel affect antenna operation? |
At 04:21 AM 3/19/2007 +0000, you wrote:
cured pretty hard.
conductive.
rudder.
using it?
The filler will have no effect upon your embedded atennas.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
jaybrinkmeyer(at)yahoo.co Guest
Posted: Tue Mar 20, 2007 7:00 am Post subject: Will steel affect antenna operation? |
| Quote: | JB Kwik uses steel as a filler. I don't think it is conductive. I tried
conductive.
It’s been a while since my days as a struggling student… How do magnetic
properties of a material intersect with the desired electrical conductivity
characteristics of antenna operation? Maybe I missed something?
Jay
Get your own web address.
http://smallbusiness.yahoo.com/domains/?p=BESTDEAL
Posted: Tue Mar 20, 2007 10:23 am Post subject: Will steel affect antenna operation? |
At 08:00 AM 3/20/2007 -0700, you wrote:
<jaybrinkmeyer(at)yahoo.com>
>conductive.
Jay
Influence due to magnetic properties is not so strong
as conductivity, i.e. sheet resistance of the material
in question. For single, relatively thin conductors
like antenna elements, resistive losses of say stainless
steel versus copper can be easily measured but not
terribly significant in terms of overall performance
on airplanes (we talk line-of-sight and can tolerate
rather poor antenna performance).
For ground planes, you have an infinite number of
radials all operating in parallel such that effects
of sheet resistance variability for copper versus aluminum
versus stainless under the antenna would be exceedingly
difficult to measure in the lab.
I can't think of any reason that magnetic properties
of the material being considered would offer an effect
worth considering beyond that of it's heating losses due
to inability to perfectly conduct a current.
( EVERY day . . . )
Posted: Tue Mar 20, 2007 11:29 am Post subject: Will steel affect antenna operation? |
"I can't think of any reason that magnetic properties of the material
being considered would offer an effect worth considering beyond that of
it's heating losses due to inability to perfectly conduct a current."
I was trying to beat up use, and putting something magnetic near remote
magnetometer for Dynon D10A was a passing thought.
When the extra turbulence on the right side of the aeroplane due to
P-Factor temporarily were to put a magnetic charge on the JB Weld, then
slip to landing took it off................. White elephant attack I know,
but I mentioned that if it is magnetic, I could not detect any force
change with a powerful magnet. I figured I would mention in case someone
had same thought that it mat interfere with compass/s
Ron Parigoris
