wdaniell(at)etb.net.co Guest
Posted: Sat Mar 17, 2007 4:03 pm Post subject: fuel hose |
I see rather belatedly that the fabric co vered fuel hose is not recommended for installation. Is this so?
If so what is recommended? What is the most durable stuff (for trigear)? I plan to run on AVGAS.
Will
Posted: Sun Mar 18, 2007 2:29 am Post subject: fuel hose |
Will
the best solution is either solid aluminum or teflon lined. The latter
is more expensive.
Graham
William Daniell wrote:
Posted: Sun Mar 18, 2007 4:17 am Post subject: fuel hose |
Solid aluminum sounds somewhat of a challenge - bending and all that. Is
it?
Teflon lined...what would be a typical brand?
Posted: Sun Mar 18, 2007 6:41 am Post subject: fuel hose |
Will
n0ot really difficult at all, except that you need a flaring tool for
the joints. Best to beg or borrow one. I have one but that's in
Derbyshire. Bending is done by hand, the 3003 Versatube from Spruce is
cheap and very soft.
Graham
it?
jodel(at)nildram.co.uk Guest
topglock(at)cox.net Guest
Posted: Sun Mar 18, 2007 7:52 am Post subject: fuel hose |
Will,
I used standard metal break line in the fuse and automotive fuel injection hose to make up the connections, firewall forward and to the pumps, valves and filters. No problems in 260+ hours. Under the cowl, I ran the hoses through heat shielding used for race cars...
Jeff - Baby Blue
William Daniell wrote: [quote]
Will
rlborger(at)mac.com Guest
Posted: Sun Mar 18, 2007 7:53 am Post subject: fuel hose |
Will,
Aeroquip 666 is the industry standard in carbon-lined, teflon hose. It isn't cheep. And is isn't particularly light. But it's forever stuff, you only put it in once. And it's a lot tougher than anything else out there.
See Aircraft Spruce for details.
BTW, the teflon hose used in fuel systems MUST be carbon lined or the static electricity generated by the fuel flowing through the line will eventually burn tiny pin-hole leaks in the hose.
Good building and great flying,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
(85%) tail kit done, wings closed, cockpit module installed, pitch system in, landing gear frame in, rudder system in, outrigger mod in, Fuselage Top on, lift/drag/flap pins in, wing incidence set, tie bar in, flap drive in, Mod 70 done. Baggage bay in. Flaps & Main Gear complete. Mod 72 complete. Working in - 24 Instrument Panel, 25 Electrical, 30 Fuel System, 32 Tail, 34 Door Latches & 35 Doors, 37 Finishing. Airmaster arrived 29 Sep 05. Seat arrived from Oregon Aero. E04 interior kit has arrived and is being installed. Installing the ROTAX 914, again.
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
Posted: Sun Mar 18, 2007 8:53 am Post subject: fuel hose |
Is that avgas or mo gas – I understand it makes a differece
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Jeff B
Sent: Sunday, March 18, 2007 10:51
Subject: Re: FW: fuel hose
Will,
Jeff - Baby Blue
Will 01234567890
Ok ok I get it
Posted: Sun Mar 18, 2007 8:59 am Post subject: fuel hose |
thanks for pointing that out, I learnt something new today!
Graham
rlborger wrote:
| Quote: | Will,
Bob Borger
Graham Singleton
Tel: +441629820187
Mob: +447739582005
rehn(at)rockisland.com Guest
Posted: Sun Mar 18, 2007 9:21 am Post subject: fuel hose |
Automotive fuel injection hose works well. It is compatible with auto fuel and is very tough.Many others have used this including myself. I believe Europa when it had its location in Florida used it when they built up the quick build cockpit modules. Bob Berupe could confirm this.
Jerry
Posted: Sun Mar 18, 2007 9:22 am Post subject: fuel hose |
I run both. No problems, yet. The drag racing guys use the same hose with Avgas all the time, without problems...
Jeff
William Daniell wrote: [quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of Jeff B
Will,
Jeff - Baby Blue
Will 0 1 2 3 4 5
6 7 [b]
Posted: Sun Mar 18, 2007 9:24 am Post subject: fuel hose |
How about teflon lined water hoses for high temp. Will pin holes form there
as well?
Jerry
rparigor(at)suffolk.lib.n Guest
Posted: Sun Mar 18, 2007 9:59 am Post subject: fuel hose |
Here is an article on static and teflon hose used in aircraft.
www.sacskyranch.com/statichose.htm
"How about teflon lined water hoses for high temp. Will pin holes form
there as well?"
I would use conductive teflon in airplanes if there is a reasonable flow
happening.
I will be using unlined teflon for the fuel side of differential pressure
sender on 914 and remote oil sender on same.
There will be little flow in these lines.
Just a side note, I will fill the fuel line with 100LL, so when it turns
20 years old hopeful it is not all varnish.
Will also fill oil line with oil so when pressure happens there is not air
in there that will be squeezed and have water come out and do nothing good
to sender.
Ron Parigoris
johnwigney(at)alltel.net Guest
Posted: Sun Mar 18, 2007 3:37 pm Post subject: Fuel Hose |
Hi Will,
You are correct. The factory supplied fuel hose with fabric cover is not
recommended. I have had 3 instances now where the hose has cracked under
a hose clamp with resultant leak. With the fabric cover, a small leak is
difficult to find since the fuel wicks into the cover and evaporates.
I have had no problems since I replaced mine with SAE 30R7 fuel hose
designed for carburettor systems and which has mid-wall reinforcement.
This hose is available in the US at stores such as NAPA or Autozone in
1/4 in.(6.3 mm) and 5/16 in. (8 mm) sizes. I use 100LL Avgas.
Be aware that if you use auto fuel, the fuel can contain a wide range of
aromatics, additives, etc. which can affect the hose life. Therefore, it
would probably be wise to use 'fuel injection' SAE 30R9 hose which has
an elastomer liner to minimise permeation and deterioration. See
http://www.gates.com/common/downloads/files/Gates/brochure/TechTipsForm.pdf
for more information. As you might expect, the SAE 30R9 hose is more
expensive.
Cheers, John
N262WF, mono XS, 912S
Mooresville, North Carolina
Subject: FW: fuel hose
plan to run on AVGAS. Will
bberube(at)tampabay.rr.co Guest
Posted: Sun Mar 18, 2007 3:47 pm Post subject: fuel hose |
We did use the fuel injection hose exclusively on the 914's due to higher fuel pressures but it does provide extra benefits being compatible with all fuels, good abrasion resistance and ability to make small radius without kinking. Certainly aluminum lines are the industry standard and preferable IMHO but require a bit of extra patience on installation. Teflon lines are great but difficult to work with in tight places. Choosing any of the above will make a safe and reliable fuel system.
Bob Berube
Flight Crafters
5048 Airport Rd.
Zephyrhills, FL. 33542
813 779-1156
813 695-1120 cell
ward.t(at)xtra.co.nz Guest
Posted: Sun Mar 18, 2007 5:24 pm Post subject: Fuel Hose |
I used Trident "Barrier Lined" Type A1 Marine Fuel Hose #365
Look at
http://www.tridentmarine.com/stage/fuel.htm
I had many problems with the fabric covered Europa supplied fuel hose. Fuel
smell number one!!
Trident Barrier Lined A1 Fuel Hose (Distribution, Return, Vent, and
Transfer) for both gasoline (petrol) and diesel (including alcohol blends).
Exceeds ABYC H-24 & H-33, SAE J1527, ISO 7840, & USCG Type A1; and is NMMA
Type Accepted & CE certified. Built with best fuel, fire and age resistant
formulation, 2 spiral reinforcement and unique "Barrier Liner" on inside
surface of tube so fuel is not in direct contact with rubber. Provides
extraordinary resistance to fuel permeation and aging, as well as fire,
heat, cold, and ozone. Also good
Bend-ability.
5 YEAR WARRANTY
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Ph +64 3 3515166
Mobile 021 0640221
Posted: Mon Mar 19, 2007 3:00 am Post subject: fuel hose |
Is it compatible with AvGas as well?
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Jerry Rehn
Sent: Sunday, March 18, 2007 12:21
Jerry
Posted: Mon Mar 19, 2007 3:09 am Post subject: Fuel Hose |
As usual the range of knowledge astounds me
Thanks everyone.
Will
Posted: Mon Mar 19, 2007 3:12 am Post subject: Fuel Hose |
Tim is this significantly heavier than ac stuff?
Will
