bcondrey
Posted: Thu Mar 15, 2007 11:18 am Post subject: Do the plastic brake lines leak? |
To reinforce Tim's comments - I used to follow the Lancair mail lists
daily (before I got some learnin') and the issue of plastic brake lines
is a frequently discussed item there. Apparently they run the plastic
lines all the way to the calipers and there have been at least a couple
of fires as a result of brakes heating up. Since it may be sometime in
2019 before John actually gets to that point in his kit, it's possible
that he didn't know that the RVs have aluminum lines except for the
reservoir plumbing. Of course, he knows now...
Bob #40105
LloydDR(at)wernerco.com Guest
Posted: Thu Mar 15, 2007 11:49 am Post subject: Do the plastic brake lines leak? |
And I could see this being a problem down low on the gear leg,
especially since they stall about 15% higher speed than a 10 and have to
dissipate that much more energy as heat.
Dan
N289DT
VHMUM(at)bigpond.com Guest
Posted: Thu Mar 15, 2007 1:34 pm Post subject: Do the plastic brake lines leak? |
RV6 VH-MUM 500++ hours plastic lines and loving them. No need to waist money
here. Just install like the plans say.
chris
rvbuilder(at)sausen.net Guest
Posted: Thu Mar 15, 2007 1:37 pm Post subject: Do the plastic brake lines leak? |
Ah, but if you do not view the problem directly it is both there and not there at the same time.
Sorry, couldn't help it. As Dan says, if it ain't broke, don't fix it. Anyone actually look at what the burst pressure is of that line and what the maximum pressure of the cylinders are?
Michael
speckter(at)comcast.net Guest
Posted: Thu Mar 15, 2007 3:39 pm Post subject: Do the plastic brake lines leak? |
One of the largest problems in the homebuilding circles IMHO is that of
solving problems that do not exist. Having built a few myself and being a
Technical counselor I see it over and over. Much time and energy spent on
thing that are not an issue. Wait until there are reports of a problem
before you spend the time and $$ to fix it.
Just my $.02
Gary
40274
Posted: Thu Mar 15, 2007 4:09 pm Post subject: Do the plastic brake lines leak? |
I agree completely. A perfect example is the axle extender buy that Tim
orchestrated.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
wcurtis(at)nerv10.com Guest
Posted: Thu Mar 15, 2007 5:35 pm Post subject: Do the plastic brake lines leak? |
Amen!Or fixes that make things worse than the perceived problem they are trying to avoid. The AFP fuel servo with purge valve that is suppose to make hot starts easier comes to mind. People install them and then do not safety wire the set screws on the stops which leads to engine failure.Do not archive.Williamhttp://wcurtis.nerv10.com/ --> RV10-List message posted by: "gary" One of the largest problems in the homebuilding circles IMHO is that ofsolving problems that do not exist. Having built a few myself and being aTechnical counselor I see it over and over. Much time and energy spent onthing that are not an issue. Wait until there are reports of a problembefore you spend the time and $$ to fix it.Just my $.02Gary40274--
CJohnston(at)popsound.com Guest
Posted: Thu Mar 15, 2007 5:53 pm Post subject: Do the plastic brake lines leak? |
hi guys -
I believe I started all this plastic brake line business by asking the simple question: do any of you out there have experience with these lines leaking. apparently the answer has been mostly "nope". That's good to hear. From many, the answer is "nope, but they might someday". Then there's the "nope, and why fix something that isn't broken". I thought since I began this discussion, I might sum up the responses a bit, and point out that the constant in all the answers is that "nope. they don't leak". And just to be clear, it's only lines under the forward fuse deck, not lines going down to the wheels (which apparently catch fire).
I was mostly asking about leaks because it kind of seems like passengers could kick and kind of beat up the lines, and create a problem. Also if it gets warm down there next to the firewall, I thought the compression fittings might do something weird. I don't really have any experience with this type of fitting, but I have a ton of experience with braided steel and AN type fittings. Hence the question. I haven't decided if I'll have some lines made, or if I'll just build em like it says in the plans, but it's nice to know they work as designed. I'd just be bummed not to have brakes in a non-steerable nosewheel plane. i think... it's not like i've ever flown one before...
thanks for all the input guys!
cj
#40410
wings/fuse/finishing
Posted: Fri Mar 16, 2007 6:05 am Post subject: Do the plastic brake lines leak? |
You can find a boogy man behind every fitting and every rivet if you want
to. Relax and have fun building. It is a well designed plane. There was
an excellent article in one of the last AOPA Pilot magazines by Rod Machado
about this very subject.
Gary
40274
Dick Sipp
Posted: Sat Mar 17, 2007 6:38 am Post subject: Do the plastic brake lines leak? |
