kheindl(at)msn.com Guest
Posted: Thu Mar 15, 2007 12:13 am Post subject: MGS epoxy |
Would you have any idea who the importer is in Canada ? Would it be Diamond
Aircraft ?
| Quote: | From: D Wysong <hdwysong(at)gmail.com>
Reply-To: europa-list(at)matronics.com
Subject: Re: What epoxy should I be using
Date: Thu, 15 Mar 2007 02:48:54 -0600
>Epoxy mixes are not interchangeable. Different brands have different
>modulus of elasticity and other mechanical and thermal properties.
>Aeropoxy is what the designers of the Europa chose and validated.
>Use something else and you are totally on your own.
True, but the 200 series of MGS resins/hardeners are a very safe choice for
any experimental aircraft.
The properties for MGS 2XX resin/hardener are actually a bit better than
the Aeropoxy spec'd for the Europa. As Graham pointed out, MGS is used on
several certified and experimental aircraft. It is less viscous than most
systems, too, so wet out is much easier.
There was recently a HUGE problem getting MGS into the states due to hazmat
classification, though. Everything got held up in Canada (all US bound MGS
comes through Canada), and Spruce shipments were running 6+ months late in
some instances. All should be well by now, but it's worth a check before
you order.
D
Txt a lot? Get Messenger FREE on your mobile.
https://livemessenger.mobile.uk.msn.com/
hdwysong(at)gmail.com Guest
Posted: Thu Mar 15, 2007 11:55 am Post subject: MGS epoxy |
> Would you have any idea who the importer is in Canada?
> Would it be Diamond Aircraft ?
> do not archive
Sure, here's the link to the NA distributor for MGS:
http://www.airheart.on.ca/index.html
D
