		rholder(at)avnet.co.uk Guest
				 Posted: Sat Jan 28, 2006 10:53 am    Post subject: Rotax regulator |
				Gilles Thesee wrote:
  	  | Quote: | 	 		  > Do you think it is right if the alternator needs to
 > be switched off manually for any reason that it
 > should be done through the C terminal (switching an
 > amp or two) rather than the B+/R terminal which is
 > perhaps pushing out 15 - 20 amps.
  	  | Quote: | 	 		   The Rotax regulator will normally shut down when the C
  terminal is grounded (zero volt). Can't predict what it
  does when just disconnected. What if it doesn't tame
  the regulator output ?
 Is there some way of checking this ? Perhaps on your
 student's test rig ?
  	  | Quote: | 	 		   Have you considered including a relay in the B/R to bus
  circuit ? Bob Nuckolls' Aeroelectric figure Z 16 could
  be of interest. My design is a variation on Bob's
  theme, with small changes due to the different
  regulator.
 I just didn't want to use a physical switch/cb/relay to go
 from an overvolt situation of maybe 30 A to nothing. It
 would not be good for the switch/cb/relay, IF
 disconnecting the C terminal turns off the regulator then
 there will be no actual disconnection spark anywhere, it
 will be in the electronics.
  	  | Quote: | 	 		   The C wire is a sense wire, so AWG 22 and 5 amps is
  about right.
 5 amps actual seems like a lot for a sense wire. That
 means that the regulator B+/R terminals produce up to 24A
 of which 5A goes back into the regulator ?
 I have seen your fine pictures of the cleaned out
 regulator. It appears that B+ and R are connected together
 inside anyway !
 Could you send me the schematic of the circuit inside there ?
 I have a friend who dabbles in obscure components. He
 looked up TP154E. It is a Thrystor 800 volt 25 A 40mA and
 an alternative would be 2N6509 which in my catalogue is
 about 1 GBP - say 2 euros !
 It does and I hope I have helped in return.
				 Posted: Sat Jan 28, 2006 1:43 pm    Post subject: Rotax regulator |
				Hi Richard,
  	  | Quote: | 	 		  > What if it doesn't tame
 Hmm, remember that was two years ago. I'm afraid the alternator might
 now lie on a forgotten shelf...
  	  | Quote: | 	 		  >Have you considered including a relay in the B/R to bus
 >regulator.
  It
 Grounding the C wire will shut down the regulator. That is, IF it is
 working properly. But then where does that OV condition come from ?
  	  | Quote: | 	 		  >The C wire is a sense wire, so AWG 22 and 5 amps is
 >about right.
 5 amps is the usual CB rating for AWG 22 wire. And for mechanical
 reasons, AWG 22 is about the smallest wire used for wiring light aircraft.
 Remember, if your crowbar fires, the current will flow from the bus bar
 via the OV CB, to the ground, tripping the CB in the process.
  	  | Quote: | 	 		  I have seen your fine pictures of the cleaned out
 inside anyway !
 Yes
  	  | Quote: | 	 		  Could you send me the schematic of the circuit inside there ?
 Will do. Just give me some time to sort the 40+ MB of data Jerome just
 sent me. I would like to publish something really up to date.
  	  | Quote: | 	 		  I have a friend who dabbles in obscure components. He
 Great !
 Thank you,
 Gilles
 http://contrails.free.fr
				 Posted: Sun Jan 29, 2006 2:34 pm    Post subject: Rotax regulator |
 Richard an all,
 I just posted a schematic of the Rotax regulator.
 Please note that I redrew it from sketches two years old, and I'll check
 with a dismantled unit, well er...later
 FWIW
 Gilles Thesee
 Grenoble, France
		william(at)wrmills.plus.c Guest
				 Posted: Mon Jan 30, 2006 11:35 pm    Post subject: Rotax regulator |
				Hi Gilles,
 Do you consider the Rotax regulator could develop an intermittent fault so
 that it is not always charging at full capacity?  I have noticed in flight
 that sometimes the voltmeter drops to about 13 V and other times it stays at
 14 V (13.8, I presume).  Last time I brought the aircraft home the battery
 was not full charged and needed some time on the charger to top it up.  The
 battery is an Odyssey PC680 and is only one year old.
 Many thanks,
 William
				 Posted: Tue Jan 31, 2006 10:02 am    Post subject: Rotax regulator |
				William Mills a crit :
  	  | Quote: | 	 		  Do you consider the Rotax regulator could develop an intermittent fault so
 Many thanks,
 Richard and all,
 It would be interesting to study what electrical devices are on, and
 what the engine RPM are, versus voltmeter readings. It is normal to see
 the bus voltage drop when the current draw is high. It also depends on
 the battery state of charge.
 Now, if there is a problem, yes the regulator could be the culprit, but
 there are so many other causes to investigate.
 Frequent problems are faulty wiring, especially the connection between
 the regulator case and the ship's ground. Remember your 14-18 charging
 amps flow through this connection.
 Every connection in the circuit should be checked for tightness, absence
 of corrosion, correct wire gauge, etc.
 Also, you need a thorough load analysis in order to be sure your
 permanent draw does not exceed 10-12 amps. And remember the alternator
 delivers power when RPM is sufficient, that is around 5000 RPM.
 Do you have a schematic of your aircraft circuit ?
 Gilles Thesee
 Grenoble, France
				 Posted: Tue Jan 31, 2006 3:05 pm    Post subject: Rotax regulator |
				I checked the C terminal. Disconnecting it does eventually
 kill the charging but not very quickly, so disconnecting
 the C connection via a crowbar won't work.
 At about 5000 rpm the C terminal was taking 0.04 A.
 Not-a-lot !
 Gilles - I notice you say that earthing the C terminal
 will kill the output. But your own wiring diagram shows
 that the C terminal is connected directly to a diode which
 would not allow any current to run to earth from inside
 the regulator ! So I suspect your "earthing" of the C
 terminal was really just disconnecting it.
 I replaced my original (intermittent fault) rectifier
 today and it worked. So the replacement (which flicked the
 ammeter needle between 1 - 10 amps 5 times a second over
 5000 rpm) was faulty and it will be on its way back to the
 supplier tomorrow !
 I actually looked at the circuit board of my original (now
 re-installed) regulator and saw three possible sites for
 dry-joints. So I applied my soldering iron. The regulator
 still works so I didn't bu**er it up; I will wait for a
 few flights before I proclaim that I have fixed the
 intermittent failure to charge !
 Richard with positive engineering news about the
 electrics. So now to continue to determine why the oil
 thermostat doesn't work the way I expected.
 G-OWWW High Cross
				 Posted: Tue Jan 31, 2006 3:27 pm    Post subject: Rotax regulator |
				Hi Richard and all,
 In our circuit, the crow bar connects the C wire to ground, so it sees
 zero volt. At the same time, it trips the alternator disconnect CB,
 opening the line relay. So the alternator is totally disconnected from
 the ship's circuit.
  	  | Quote: | 	 		  At about 5000 rpm the C terminal was taking 0.04 A.
 Not-a-lot !
 the regulator !
 Correct. The C terminal is a sense connection to provide a reference
 voltage to the command circuit. When you ground it, the reference
 voltage is zero volt.
 No current is intended to flow out of it. C voltage is always greater
 than or equal to zero volt.
  	  | Quote: | 	 		  So I suspect your "earthing" of the C
 What voltage does C teminal see when it is left dangling "in the air" ?
  	  | Quote: | 	 		  I replaced my original (intermittent fault) rectifier
 supplier tomorrow !
 electrics.
 Great news.
  	  | Quote: | 	 		   So now to continue to determine why the oil
 Maybe I missed previous messages, but how should it work, and how does
 it behave ?
 We shunned the thermostat thing, and went the duct and cowl flap route,
 with great satisfaction.
 Gilles Thesee
 Grenoble, France
				 Posted: Tue Jan 31, 2006 10:33 pm    Post subject: Rotax regulator |
				Thanks John and Gilles,
 I'm afraid I don't have a schematic, but I have several hundred hours with
 the same loading regime and I have noticed a change in the readings on the
 VDO voltmeter over the past 3 months or so.  It is also intermittent.  I
 will check all my connections, however.  Would a smear of grease help to
 maintain a good connection?
 B w,
 William
		n3eu(at)comcast.net Guest
				 Posted: Wed Feb 01, 2006 7:17 am    Post subject: Rotax regulator |
				Richard Holder wrote:
  eventually kill the charging but not very quickly, so
  disconnecting the C connection via a crowbar won't work.
 The delay is because a capcitor has to first discharge internally;
 grounding won't do that..
 Thus correct, because of that blcking diode. What grounding will do is
 prevent spurious noise from triggering the sense circuit, which is a
 hair-trigger "Darlington amplifier,"  though a rather low input
 impedance for that sort of problem.
  	  | Quote: | 	 		   I actually looked at the circuit board of my original
  (now re-installed) regulator and saw three possible
  sites for dry-joints.
 Anything's possible.  It looks hand-soldered, but by someone "on a
 mission."  And apparently still did a poor job where it really mattered!
 Reg,
 Fred F.
		hansjd(at)online.no Guest
				 Posted: Thu Feb 02, 2006 2:08 pm    Post subject: Rotax regulator |
				Hi William
 It might be a good idea - if you havn't done so already - to check the
 grounding wire(s) and connections from the rectifier housing. Poor
 connections in this area will certainly ruin your day!
 Best wishes, Hans - hansjd(at)online.no
				 Posted: Fri Feb 03, 2006 2:10 am    Post subject: Rotax regulator |
				Many thanks, Hans,
 I will certainly do that.
 I was hoping one of the experts would comment on my suggestion to put a
 smear of grease on all the earthing terminals to improve contact and prevent
 corrosion.
 Best wishes,
 William
		Brian Davies
				 Posted: Fri Feb 03, 2006 2:48 am    Post subject: Rotax regulator |
				Hi William,
 A smear of grease might be Ok after you have connected the earth terminals
 but not before.  You want the best possible electrical contact and this
 requires a chemically clean joint- grease on the contact face is not good.
 Brian Davies kit 454
				 Posted: Fri Feb 03, 2006 7:34 am    Post subject: Rotax regulator |
				Hi! William
 My experiences indicate that the grease you need is electrical silicone
 grease and is mostly available now in an aerosol can dispenser.
 Of course you knew this anyway !!!!
 Bob Harrison G-PTAG Europa MKI/Jabiru 3300
 Robt.C.Harrison
				 Posted: Sat Feb 04, 2006 4:29 pm    Post subject: Rotax regulator |
				Many thanks Brian and Richard; message taken.  What about switch or contact
 cleaner in the aerosol cans?
 B w
 W
		Brian Davies
				 Posted: Sun Feb 05, 2006 12:43 am    Post subject: Rotax regulator |
				William,
 It depends what you are trying to achieve.  If the contact/connection is
 just dirty or greasy the contact cleaner will be fine.  It evaporates very
 quickly leaving no residue.  If the contact/connection is corroded it will
 not help. You need to mechanically remove all corrosion before making the
 connection.
 If you are worried about future contamination or corrosion after having made
 a good connection, Richard's suggestion of using a small smear of Vaseline
 or silicone grease will work. If you want to seal the connection permanently
 from the elements you could cover it in RTV/ silicone bath sealant.
 Hope this helps
 Brian
				 Posted: Sun Feb 05, 2006 10:52 pm    Post subject: Rotax regulator |
				Many thanks, Brian,
 I have had some cold weather starting probs plus the intermittent no
 charging (I think), so while it is at home I thought I would do as much as
 possible to improve whatever I can.
 Best wishes,
 William
