mcdevitt(at)sympatico.ca Guest
Posted: Sat Feb 04, 2006 2:35 pm Post subject: Certified Aircraft Rewiring |
I am in the middle of an engine overhaul and I thought this might be a good
time to do some rewireing.
My question is: The lead from the alternator goes into the cabin to a 50 amp
circuit breaker
The battery lead goes to the ammeter shunt and then into the bus. I'm
thinking I should eliminate the 50 amp circuit breaker and connect the
alternator to the battery at the ammeter shunt.
This is a certified aircraft, Aeronca Sedan, 1948 vintage and the wiring
bears no relationship to the factory drawings because the engine has been
changed to a 0-360 and the gererator replaced with an alternator.
Am I still legal if I do this, and is it worth while? At present I get a
small amount of noise/interference, certainly liveable.
Thanks for your help.
Bob
khorton01(at)rogers.com Guest
Posted: Sat Feb 04, 2006 3:21 pm Post subject: Certified Aircraft Rewiring |
On 4 Feb 2006, at 17:15, Bob McDevitt wrote:
<mcdevitt(at)sympatico.ca>
be a good
a 50 amp
circuit breaker
wiring
has been
get a
Bob,
I assume by your e-mail address that you live in Canada, and that
this is a Canadian registered aircraft. I also assume that you have
not put it into the Owner Maintenance category.
Removing the circuit protection for the alternator lead is a
significant design change. This design change would need to be
approved via an STC, in my opinion. If you were intending to keep
the 50 amp CB, and simply change the wire routing, perhaps an AME
would be prepared to sign off on it as a repair, completed in
accordance with "specified data". Specified data, as defined in the
Airworthiness Manual 571.06 includes FAA AC 43.13-1.
http://www.tc.gc.ca/civilaviation/RegServ/Affairs/cars/Part5/
Standards/571s.htm#571_06
If this is a US registered aircraft, you possibly could do it under a
337 Field Approval, but there is no similar process in Canada.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
BobsV35B(at)aol.com Guest
Posted: Sat Feb 04, 2006 3:48 pm Post subject: Certified Aircraft Rewiring |
Good Afternoon Bob,
The type certificate for the 15AC is now held by some folks up in Alaska.
The engine you have is not mentioned in the TCDS. Therefore, there must be an
STC that was used for the installation. That STC, or another one for the
alternator installation, should include data as to how your airplane should be
wired. If the change you want to make differs from the way it was done for
the STC involved, you might check with whoever has been doing the annual on
your airplane. It is possible that the change could be considered a minor
alteration. If that is the case, the change could be made and a log book entry
made by a properly certificated mechanic. If your IA agrees that the change is
minor, you are home free. If your IA does not agree that the change is minor,
you could shop for another IA or consider applying for a local approval for
your change.
Any help at all?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
In a message dated 2/4/2006 4:36:32 P.M. Central Standard Time,
mcdevitt(at)sympatico.ca writes:
changed to a 0-360 and the generator replaced with an alternator.
