nico(at)cybersuperstore.c Guest
Posted: Fri Jan 03, 2014 5:03 pm Post subject: AC90/95 single pilot operation |
Folks,
I had a request from an AC90/95 operator who wants to know what in the FAA regulations determine which aircraft and under what circumstances may be flown with a single pilot and which and under which circumstances require a co-pilot.
Ordinarily the AC90/95 series Commanders can be legally operated with only one crew member, but are there circumstances under which a second crew member is required?
Your response would be very much appreciated.
nico
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
cloudcraft(at)aol.com Guest
Posted: Mon Jan 06, 2014 11:43 am Post subject: AC90/95 single pilot operation |
Nico,
All Commanders are type certificated (in the U.S.) as one pilot.
Under FAR 135, IFR qualifications, an autopilot can serve instead of a second in command. The pilot under FAR 135 will have to qualify with autopilot and it must be in the operator's OpSpecs.
Keith S Gordon
Wing Commander Gordon
Life is not simple anywhere. Probably less so elsewhere.KHND RNAV Lead
NBAA Access Committee
Las Vegas Airspace Users' Council, NBAA Rep
Las Vegas RNAV Optimization Work Group, NBAA Rep
Las Vegas Class B Redesign Committee, NBAA Rep
aquadiver99(at)yahoo.com Guest
Posted: Mon Jan 06, 2014 2:10 pm Post subject: AC90/95 single pilot operation |
True
On Jan 6, 2014, at 1:42 PM, "Keith S. Gordon" <cloudcraft(at)aol.com (cloudcraft(at)aol.com)> wrote:
[quote]Nico,
Keith S Gordon
Posted: Mon Jan 06, 2014 2:49 pm Post subject: AC90/95 single pilot operation |
Nico, All,
I was on the fly earlier when I posted about single pilot / s.i.c. requirements. Here's the source of my answer.
§135.101 Second in command required under IFR. Except as provided in §135.105, no person may operate an aircraft carrying passengers under IFR unless there is a second in command in the aircraft.
§135.105 Exception to second in command requirement: Approval for use of autopilot system. (a) Except as provided in §§135.99 and 135.111, unless two pilots are required by this chapter for operations under VFR, a person may operate an aircraft without a second in command, if it is equipped with an operative approved autopilot system and the use of that system is authorized by appropriate operations specifications. No certificate holder may use any person, nor may any person serve, as a pilot in command under this section of an aircraft operated in a commuter operation, as defined in part 119 of this chapter unless that person has at least 100 hours pilot in command flight time in the make and model of aircraft to be flown and has met all other applicable requirements of this part.
(b) The certificate holder may apply for an amendment of its operations specifications to authorize the use of an autopilot system in place of a second in command.
(c) The Administrator issues an amendment to the operations specifications authorizing the use of an autopilot system, in place of a second in command, if—
(1) The autopilot is capable of operating the aircraft controls to maintain flight and maneuver it about the three axes; and
(2) The certificate holder shows, to the satisfaction of the Administrator, that operations using the autopilot system can be conducted safely and in compliance with this part.
The amendment contains any conditions or limitations on the use of the autopilot system that the Administrator determines are needed in the interest of safety.
~KG~
Sub22
Posted: Mon Feb 10, 2014 2:34 pm Post subject: Re: AC90/95 single pilot operation |
Are you flying passengers or cargo?
_________________ JS Bennett |
