Remote AHARS??
tonyrenshaw268(at)gmail.c
PostPosted: Tue Oct 22, 2013 4:25 am    Post subject: Remote AHARS?? Reply with quote
Gidday,
There was a thread recently I believe regarding a system that used a remote sensor mounted mid ships somewhere that fed the Flight Displays........some thing like Lievel ?. If anyone can help,with what this was all about, with such limited information, I'd appreciate being pointed in the right direction.
Thanks.
Tony Renshaw
peterz(at)zutrasoft.com
PostPosted: Tue Oct 22, 2013 5:03 am    Post subject: Remote AHARS?? Reply with quote
Many of the EFIS's use remote AHRS units (Grandrapids for example), others do not (Dynon?).  I had posted about the Leviltechnologies AHRSG-mini with air-data which is a wireless (Wifi), battery powered (can be hard wired to ship power) remote unit which displays on the IPAD using a variety of available apps.  I had made a remote pitot-pod which I clamped on the strut of a  a certified tube&rag Canuck to get a six-pack in a plane where half the instruments were inop (!).  Now I`m using it hardwired in the fuse behind the seat of a tiny HummelBird (until my Europa eventually gets into formation).
I find it works well, and is stable. The refresh rate could be better (at about 2hz), but for the price and versatility I can`t complain.
http://www.aviation.levil.com/AHRS_mini.htm
On Tue, Oct 22, 2013 at 8:24 AM, Tony Renshaw <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)> wrote:
[quote]--> Europa-List message posted by: Tony Renshaw <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)>
Gidday,
Thanks.
Tony Renshaw
target="_blank">http://www.matronics.com/Navigator?Europa-List
http://forums.matronics.com
le, List Admin.
PostPosted: Tue Oct 22, 2013 1:51 pm    Post subject: Remote AHARS?? Reply with quote
Great.Thanks for that. Look fwd to the vid. At a similar stage it seems with our panels. I am going to have the two standard removable panels. Here is how I shaped my templates.
Next I am going to use
http://www.onlinemetals.com/merchant.cfm?id=1264&step=2&top_cat=181
for my panel.
[img]cid:3FDE00D5-ECC6-4234-B58C-03142BEC94EC(at)optusnet.com.au[/img][img]cid:34DD9B1E-FC1D-454B-BC0F-4E16427181C4(at)optusnet.com.au[/img][img]cid:84F9A6FB-AF84-4D74-86DE-6798E31C6284(at)optusnet.com.au[/img]
On 23/10/2013, at 12:02 AM, Peter Zutrauen <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
Gidday,
Thanks.
Tony Renshaw
le, List Admin.
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
 Filesize:  89.33 KB
 Viewed:  5840 Time(s)
 Filesize:  82.84 KB
 Filesize:  89.97 KB
