bernard.wilder2(at)gmail. Guest
Posted: Fri Oct 18, 2013 6:19 am Post subject: Cement Paint |
Go to :www.rhinolinings.com and get the data sheet for " Rhino 9700
" (( ex Jeffco 9700 )) and you will find that the product is an epoxy
cement paint.
Their test found that after three weeks immersion in ethyl alcohol it
had gained 6.9% of its weight. At least that is the explanation I
received from them as to what the data reported meant.
Question: Is ethenol an ethyl alcohol ? ? ? (( There was no test for
ethenol. ))
I have already purchased a gallon of 9700 from Lancair's parts
division for $169.00. Not much different from Aircraft Spruce's per
gallon price,,, but I didn't have to buy three gallons.
I suspect that Home Depot's cement paint would have done just as well
and if the gallon of m9700 I have purchased is not enough to do my
fuel cells I will test my suspicion.
Bernie Wilder
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pulsar-List |
Posted: Fri Oct 18, 2013 5:36 pm Post subject: Cement Paint |
Just learned why Home Depot's epoxy cement paint is so inexpensive - -
- it is water based.
Two part epoxy cement paint at our local paint store is almost as
expensive as Rjhino 9700.
Bernie Wilder
