NDB Let downs
gholland(at)content-strea
PostPosted: Sun Oct 13, 2013 11:24 am    Post subject: NDB Let downs Reply with quote
A local Ryan Air Captain here tells me that he does NDB letdowns regularly as some of their destinations are not ILS equipped.I'm presuming it's probably the same with EasyJet.
The young lad in my Hangar just gone professional and now has his CPL/IR (self funded!) and the IR certainly involved NDB letdowns.
Gerry
Gerry Holland
gholland(at)content-stream.co.uk (gholland(at)content-stream.co.uk)
+44 (0)7808 402404
[img]cid:4C0DBE17-4DEB-411D-BF75-8C8AFF101B75[/img]White Ox Mead Airstrip, Bath. England
 Filesize:  7.92 KB
 Viewed:  3435 Time(s)
stranfaer(at)btinternet.c
PostPosted: Sun Oct 13, 2013 11:31 am    Post subject: NDB Let downs Reply with quote
NDB usage is certainly part of the UK IMC test and training. VOR is also of course part of it.
And to finalise this discussion it is not legal to fly in IMC or train on our LAA permit Europa aircraft! which are cleared for daylight VFR use only.
rgds
David Joyce
The other one....
Sent to you from David Joyce
www.eastmidsspas.com
From: Gerry Holland <gholland(at)content-stream.co.uk>
Sent: Sunday, 13 October 2013, 21:24
Subject: Europa-List: NDB Let downs
Gerry
Gerry Holland
+44 (0)7808 402404
[img]cid:1.763002741(at)web87403.mail.ir2.yahoo.com[/img]White Ox Mead Airstrip, Bath. England
 Filesize:  7.92 KB
 Viewed:  3434 Time(s)
houlihan(at)blueyonder.co
PostPosted: Sun Oct 13, 2013 11:38 am    Post subject: NDB Let downs Reply with quote
Hi Gerry.
I bet you will find that his Ryanair bomber has a simulated ADF derived from INS and GPS systems I doubt they have an ADF receiver fitted.
Knowing Ryanair I bet they charge the crew to use the equipment installed.
Tim
On 13 October 2013 21:24, Gerry Holland <gholland(at)content-stream.co.uk (gholland(at)content-stream.co.uk)> wrote:
A local Ryan Air Captain here tells me that he does NDB letdowns regularly as some of their destinations are not ILS equipped. I'm presuming it's probably the same with EasyJet.
Gerry
Gerry Holland
+44 (0)7808 402404
 Filesize:  7.92 KB
 Viewed:  3433 Time(s)
Alan Carter
PostPosted: Sun Oct 13, 2013 11:40 am    Post subject: Re: NDB Let downs Reply with quote
Hi.
No problem with NDB approaches, a higher minima in ALT and Vis are used.
Sometimes it VFR only landing, with an instrument approach with a break off height, then circle to land, often in mountainous terrain.
Alan
PostPosted: Sun Oct 13, 2013 11:56 am    Post subject: NDB Let downs Reply with quote
Tim Hi!
You could be right on all counts!
They seem to be fitted with Honeywell Quantum Line which does have VOR and ADF in the range somehow.
Gerry
