Essential tips to build a space shuttle - instalment two
carlossa52(at)gmail.com
PostPosted: Mon Oct 07, 2013 5:30 am    Post subject: Essential tips to build a space shuttle - instalment two Reply with quote
How making tape can help:
In situations where it is necessary to mark rivet locations for drilling, and the area is of difficult access, one can draw the rivet locations/pattern on a piece of masking tape and carefully apply the tape to the target part.
Sharpie lines on UHMW (UHMWPE, Ultra-high-molecular-weight polyethylene) are easily erased while handling it. Pre-covering the area where one needs to write with masking tape solves this problem.
UHMW is very slippery, what makes it difficult to keep it aligned when clamping the material.
Covering (all or part of) the contact surfaces with masking tape helps.
When painting, cover areas that are not supposed to be painted with masking tape (I heard this was the original use of masking tape, imagine that! Smile  )
Next installment: how to make a space suit out of duct tape.
Cheers
Carlos
jaybannist(at)cs.com
PostPosted: Mon Oct 07, 2013 12:53 pm    Post subject: Essential tips to build a space shuttle - instalment two Reply with quote
Carlos,
Careful -- you may have Bombardier breathing down your neck for revealing trade secrets
Jay
DaveG601XL
PostPosted: Wed Oct 09, 2013 6:40 am    Post subject: Re: Essential tips to build a space shuttle - instalment two Reply with quote
Carlos,
In the spirit of space shuttle building, make sure to follow these instructions when getting ready for a work session on your airplane. Only following successful completion of step #12, you will you be in the position to work on an aerospace product such as the Zenith 601. Smile You would certainly look the part of an aerospace professional!
I wish you good luck and many hours of safe flying,
Dave
 Filesize:  85.61 KB
 Viewed:  7200 Time(s)
David Gallagher
Cincinnati, OH area
paulrod36(at)msn.com
PostPosted: Wed Oct 09, 2013 1:45 pm    Post subject: Essential tips to build a space shuttle - instalment two Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Very interesting--however, anyone who can accomplish Step 7, can do any damn thing they want, for theirs is a superpower!!
PaulR
