VE3LVO(at)rac.ca Guest
Posted: Wed Jun 14, 2006 6:13 am Post subject: Airspeed and ATP |
Hello,
Taken in order, two points:
(1) "From: "richard titsworth" <rtitsworth(at)mindspring.com>
Subject: RE: Re: IFR Requirements (required vs. good to
have)
One small pet peeve of mine - the 196 shows GROUND SPEED (not airspeed). A
simple point - but add some tailwind and/or density altitude and the
differences can be disastrous - especially in an emergency when mental
workload is high. Do yourself a favor and repeat it ten times so you don't
forget. It shows ground speed not IAS."
.......Amen to that - AND that goes for confusing 'heading' for 'track made
good' as well.
(2) I see some increasing use of the term 'ATP' to perhaps designate the
usefulness of advice from an airline pilot. That is a topic ripe for
fisticuffs since two of them stalled and killed themselves in a trainer I
helped build. Most "ATPs" will admit that their airline experience is great
for weather, communications and international trade, but useless in
operating little one-seaters in the countryside. I think we would all be
surprised at the number of ATPs reading this, so advice is as you find it,
not how it's presented.
Ferg Kyle
Europa A064 914 Classic
nuckollsr(at)cox.net Guest
Posted: Thu Jun 15, 2006 6:09 am Post subject: Airspeed and ATP |
At 10:09 AM 6/14/2006 -0400, you wrote:
Hello,
have)
Yeah, GPS is for global issues, i.e. navigation. The sensing
and display of air flow over wings and controls is for
aviating and gps receivers are remarkably ignorant of airflow.
| Quote: | ........Amen to that - AND that goes for confusing 'heading' for 'track made
good' as well.
This is an excellent example of the pollution of meaning when
two mini-cultures come together. The roots of many features in
aviation come from the marine world where the supporting medium
and external forces acting on the vehicle were currents within
fluids - water and air instead of just air. In both boats and airplanes
the vehicle's path is seldom defined by the direction in which
the vehicle is pointed, hence a need to separate heading (pointing)
course (direction of travel) and track (path over the surface of
the earth).
When the folks building GPS receivers for the world market really
began to take off, the vast majority of their customers were
going to be operating over a non-fluid surface were course and
heading were tied together due to lack of drift. The general
public was more likely to understand and latch on to a word like
'heading' (that's where I want to go) as opposed to 'course'
(what . . . are we playing golf?) so the three digits that
quantified direction of travel got labeled heading. Where they
really blew it was when they described the course vector to your
next way point as "bearing".
Our water-borne brothers defined bearing as a vector referenced
from heading. I.e., a change in heading from 30 degrees to 75
degrees was to point the vehicle at some location with a bearing
of 45 degrees to the right of present heading. This says nothing
about course since a change of heading by 45 degrees may not
result in a course change of 45 degrees. The drift equation
may calculate a course change other than 45 degrees when heading,
wind and currents were considered together.
| Quote: | (2) I see some increasing use of the term 'ATP' to perhaps designate the
You betcha! And it happens in every venue when the scale, complexity
and environment spread over a wide range of missions. Rules-of-the-road,
operating techniques and skills for operating a VW on a trip to
the store for bread are widely separated from those governing the
movement of a large piece of machinery over the highways on a 50-
wheeled tractor-trailer. The physics for both situations are
identical . . . simple-ideas that are inviolate. But the manner
in which they are stacked produces systems where the drivers
of each would need intensive re-orientation should their
respective skills and experience be limited to only one of the
situations. Even when a driver has extensive skill and experience
in both, there's a little re-training event that happens when
making a transition from one vehicle to the other. For example,
I'm always taken with the change of focus and profound changes
of environment as I pull onto the highway from the airport after
having just spent hours concentrating on the operation of the airplane.
