david steade
Posted: Tue Oct 01, 2013 9:38 am Post subject: Window sizeWindow size |
Hi All
Thanks for all the info on the windows. I am trying as far as possible to reproduce the windows to the original Mk4 size so if anyone does have the dimensions handy then that would be useful.
David
_________________ David Steade |
lcfitt(at)sbcglobal.net Guest
Posted: Tue Oct 01, 2013 12:58 pm Post subject: Window sizeWindow size |
David,
David,
Sorry to take your question in other directions. I wonder if you will be able to find what you are looking for. When I was building my 93 kit, the side windows had an option that consisted of a triangular piece of fabric with the window sewn in. It was then glued to the area between the tubing. I had seen it and didn't like the looks. I glued my window to the fabric using a piece of lexan that came with the kit. I think what you would need is someone to come forward with the original sewn in window and measure that. Otherwise, I don't think there was a standard size as my feeling is that most builders pretty much just eyeballed it as to size.
Then after writing the preceding, I thought to look at the original construction manual pages. I will send them to you direct - to avid copyright issues - as a PDF file. There is one photograph that you could use to create ratios for a rough dimension.
Lowell
Sent: Tuesday, October 01, 2013 10:37 AM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Subject: Re: Window sizeWindow size
Hi All
David
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Posted: Tue Oct 01, 2013 1:04 pm Post subject: Window sizeWindow size |
David,
Attached are the two pages of instructions for the side window installation.
Lowell
Hi All
David
Scan0035.pdf |
728.28 KB |
587 Time(s) |
