user9253
Joined: 28 Mar 2008 Posts: 1942 Location: Riley TWP Michigan
Posted: Thu Aug 15, 2013 7:36 am Post subject: Failed brownout battery experiment |
The backup battery died for my Dynon D-180. My RV-12 is used for day VFR only. A backup battery is not a necessity. Instead of paying Dynon $130 every couple of years for a new backup battery, I thought of an alternative brownout circuit to prevent the D-180 from rebooting during engine start. Not wanting to add the weight of a 7ah lead acid battery, I decided to use a couple of AA batteries. I tapped into the load side of the start switch and connected to an AA battery holder, then to the External Backup Power input pin 15 on the back of the Dynon. I figured that 3 volts from the AA batteries in series with the aricraft's 8 volts during engine start would provide the Dynon with 11 volts, one volt above the minimum required. As you might have guessed, the experiment failed. The Dynon still reboots during engine start. Evidently the AA cells are unable to maintain their voltage and supply 1.5 amps for a couple of seconds during engine start. Should I repeat the experiment using "D" cells? Or is the whole idea flawed?
Comments and suggestions appreciated.
Joe
_________________ Joe Gores |
ceengland7(at)gmail.com Guest
Posted: Thu Aug 15, 2013 8:28 am Post subject: Failed brownout battery experiment |
On 08/15/2013 10:36 AM, user9253 wrote:
Quote: | Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com> (fransew(at)gmail.com)
The backup battery died for my Dynon D-180. My RV-12 is used for day VFR only. A backup battery is not a necessity. Instead of paying Dynon $130 every couple of years for a new backup battery, I thought of an alternative brownout circuit to prevent the D-180 from rebooting during engine start. Not wanting to add the weight of a 7ah lead acid battery, I decided to use a couple of AA batteries. I tapped into the load side of the start switch and connected to an AA battery holder, then to the External Backup Power input pin 15 on the back of the Dynon. I figured that 3 volts from the AA batteries in series with the aricraft's 8 volts during engine start would provide the Dynon with 11 volts, one volt above the minimum required. As you might have guessed, the experiment failed. The Dynon still reboots during engine start. Evidently the AA cells are unable to maintain their voltage and supply 1.5 amps for a couple of seconds during engine start. Should I repeat the expe!
Joe
Joe Gores
| | Short answer: that (series connection of the AA's) won't work.
You could insert them in place of the original backup battery, but the Dynon backup is recharged constantly by the plane's supply during normal operation.
http://www.dynonavionics.com/docs/D180_Feature_Battery.html
This means that the AA's will have charging voltage applied to them constantly, & you'll likely have an acidic mess in the D-180 fairly quickly.
How about bringing the backup power terminals outside the unit, & making up a Ni-MH battery pack with the same voltage/AH rating as the Li-ion pack? It would be a bit larger & heavier, but nothing like a lead-acid battery. And really inexpensive.
Charlie
[url=http://www.dynonavionics.com/docs/D180_Feature_Battery.html][/url] [quote][b]
Posted: Thu Aug 15, 2013 8:39 am Post subject: Failed brownout battery experiment |
Joe
The 'brown out' event is just a few hundred milliseconds
long. Also, without the knowledge afforded by schematics
and/or design goals for performance of the back-up battery
power input pin, the precise cause for the failure is
unknown.
How low can the battery back up pin go and still support
the dynon over the duration of a brown-out transient?
Does the back up battery pin draw any current when the
ship's power is OFF? In other words, what conditions
must exist to relieve the back-up battery pin of any
load?
What is the load current demand on a back-up battery?
You can explore these questions with an adjustable
power supply hooked to the back-up battery pin.
Posted: Thu Aug 15, 2013 9:05 am Post subject: Failed brownout battery experiment |
long.
See http://tinyurl.com/pyszrmf
decaclops(at)gmail.com Guest
Posted: Thu Aug 15, 2013 9:52 am Post subject: Failed brownout battery experiment |
Or just pull the breaker, (if you have one), for the Dynon and close it
after engine start. That's what I've been doing with a D-10 for years.
Ed Holyoke
On 8/15/2013 9:27 AM, Charlie England wrote:
pe!
> Joe
> Joe Gores
normal operation.
quickly.
Charlie
<http://www.dynonavionics.com/docs/D180_Feature_Battery.html>
Posted: Thu Aug 15, 2013 10:00 am Post subject: Failed brownout battery experiment |
Quote: | Short answer: that (series connection of the AA's) won't work.
http://www.dynonavionics.com/docs/D180_Feature_Battery.html This means that the AA's will have charging voltage applied to them constantly, & you'll likely have an acidic mess in the D-180 fairly quickly.
How about bringing the backup power terminals outside the unit, & making up a Ni-MH battery pack with the same voltage/AH rating as the Li-ion pack? It would be a bit larger & heavier, but nothing like a lead-acid battery. And really inexpensive. |
Good input Charlie,
If it's a lithium battery that's being replaced,
then an array of 4 lithium cells could be fabricated
to put in place of the factory product. In fact,
if one tears a Dynon battery apart, the picture
on the website suggests that the cell pack is
made form four of these guys . . .
http://tinyurl.com/krgpjtx
So it seems that for about $16 you could refurbish
the original pack . . .
Referring to the D180_IM we read:
[backup battery] Will operate the FlightDEK-D180 only if Master
Power is not present. The transition from Master
Power to External Backup Power will bring up a
warning, requiring you to press ACK within 30
seconds to keep the unit operating. This warning will
also display when transitioning from either Master or
External Backup to Internal Battery power.
This sounds like a free floating input from an
external power source that is not intended to be charged
from within the D180 nor is it loaded unless
main power is missing and limited to 30 seconds
of loading unless acknowledged by pilot input.
So an external battery on the order of 10-14
volts will probably secure satisfactory brown-out
performance. If a DIY refurb of internal battery
using off the shelf, tabbed cells is not a option,
then an external pak of cells tied to the
bus through a series diode and perhaps a 200
ohms (limit charging current to very low value)
would take care of brown-out events. This external
pack might be 4 lithium cells or maybe 8 Ni-Mh
cells intended to be (1) used hundreds of milliseconds
per flight and (2) very lightly charged from
the bus.
Bob . . . [quote][b]
email(at)jaredyates.com Guest
Posted: Thu Aug 15, 2013 10:40 am Post subject: Failed brownout battery experiment |
Posted: Thu Aug 15, 2013 12:27 pm Post subject: Failed brownout battery experiment |
On 08/15/2013 01:00 PM, Robert L. Nuckolls, III wrote:
Quote: | Quote: | Short answer: that (series connection of the AA's) won't work.
Good input Charlie,
the bus.
| From the same web page:
Quote: | The battery and charging circuitry are conveniently encased within the EFIS itself and automatically charge that battery anytime external power is applied. |
Charlie
Posted: Thu Aug 15, 2013 12:36 pm Post subject: Failed brownout battery experiment |
Well, maybe the little circuit does something else... Charging was
just a logical guess on my part.
On Thu, Aug 15, 2013 at 4:25 PM, Charlie England <ceengland7(at)gmail.com> wrote:
operation.
really inexpensive.
Good input Charlie,
the bus.
applied.
Charlie
Posted: Thu Aug 15, 2013 3:10 pm Post subject: Failed brownout battery experiment |
Charlie
The opening thought for this thread was to search out
an alternative to the expensive, built-in battery.
If it can be cloned from stock cells, then that
would be the obvious $low$ move.
If not, then an external battery from li-ion or
ni-mh with a trickle charge circuit would be a
second choice.
Doing the system integration to pin 15 was the
unknown task . . .
user9253
Posted: Thu Aug 15, 2013 5:28 pm Post subject: Re: Failed brownout battery experiment |
The Dynon D-180 has 3 power inputs, the Master Power input on pin 1, External Backup Power on pin 15, and internal backup power using Dynon's proprietary Li-Ion $130 battery. Pins 1 and 15 require between 10 and 30 volts. The D-180 draws about 1.5 amps. If voltage is available on pin 1, then the D-180 will not use power from pin 15. No power is used from either input when the unit is turned off. There is an alarm if power fails on pin 1. But the alarm will silence automatically when power is restored on pin 1. During engine start, the pilot never sees that alarm because it is only there for a millisecond.
After the internal battery failed, I thought the same as Bob suggested: Buy 4 Li-Ion cells off eBay to replace the original ones. It seemed like a simple and inexpensive solution until the new cells arrived in the mail and I tried replacing the old ones. There is more to the battery pack than just batteries. There is a circuit board about 1/2" x 2" that is glued to the batteries. Evidently this circuit board monitors the voltage on each cell and charges each cell individually rather then treating all 4 cells as a single battery. After all, these are Li-Ion cells that could cause a fire if not charged properly. Normally I would never work on an electronic circuit with the power turned on. But one can not turn off a battery. Who knows if I damaged the circuit board by soldering live wires onto it in random sequence? Another problem is that the battery compartment opening is just barely big enough to slide Dynon's battery pack in. Just a few extra thousandths and the battery will not slide into the opening. Of course my battery pack was too high to go in. I took off some of the electrical tape and did manage to force it in. But being worried about cells shorting out to the metal enclosure, I took my batteries out and abandoned the idea. Why take a chance on a fire caused by my homemade Li-Ion battery pack? Running the internal battery wires and plug outside of the case is not an option because the battery compartment door is on the side of the case and blocked by the D-180 mounting tray.
As Charlie pointed out, the internal battery cable puts out a charging voltage. I did not want to connect another type of battery to that. So I decided to use pin 15, the External Battery input which does not receive a charging voltage from the D-180. And it is accessible on the back of the case.
I could just leave the D-180 turned off during engine start as Ed suggested. But I like having it on to give the altimeter time to stabilize. And monitoring electric fuel pump pressure is part of the pre-start checklist.
I will continue to experiment and post my results.
Joe
Posted: Thu Aug 15, 2013 7:03 pm Post subject: Failed brownout battery experiment |
Okay, this means that 1 and 15 feed a switchmode power
supply. This will be a constant wattage input of 14w
max according to the manual. So an 18-pack of AA alkaline
cells as a backup battery would offer a backup supply of
27 volts which would be loaded to the tune of 0.5A max
for the few milliseconds of brownout.
This figure is well within the capability of an AA
alkaline. Given that the pak is loaded for hundreds
of milliseconds once each flight, the battery pack
service life should be measurable in years.
Since it's only intended to provide brown-out
mitigation, then you have no risk of latent failure
going unnoticed before flight.
single battery.
Yup, just about everybody is doing smart batteries
when populated with li-ion cells. Given that you
never plan to run these things down, they'll only
need to support the brown-out transient. So a
series array trickle charged through a resistor
is not even going to warm up. In fact, you'd
probably want to use only 3 cells so that you can
produce a nearly constant current through a resistor.
Say the cranking transient draws 1.5A at 11 volts
from a string of 3 cells for 500 milliseconds. That's
about 7J of energy max. Okay, assume 80% charging
efficiency so over the next hour, you'll want to
stuff about 10J back into the cells. 10J at 10v
for in 1 second is about 1 amp of recharge current.
For one hour, it's 1/3600 or 277 microamps!
I suspect these cells would not be seriously
insulted with say, 1 milliamp of 100% duty
cycle trickle charge, so a 5K resistor with
a diode in series to prevent back feed would
offer a top-off-trickle charge to the array.
A similar approach could be considered for
ni-mh array. Problem is the self-discharge
rate of these cells would probably disqualify
them. So a free standing AA alkaline pak or
drip-charged li-ion pak seem the most viable
battery options.
How about an active option? A step up module
like this one
http://tinyurl.com/m7t78eh
could be set up to supply say 19 volts to
pin 15 of the Dynon, but would certainly
support 14 watts for 500 milliseconds during
a brown-out.
You might have some RFI issues with this
necessitating some filters and perhaps
a metallic enclosure . . . but it's
small and the price is right.
klehman(at)albedo.net Guest
Posted: Thu Aug 15, 2013 7:30 pm Post subject: Failed brownout battery experiment |
FWIW I have a similar dc to dc converter in a plastic box running a 28v
Turn & Bank instrument off 12 volts and have no RFI issues.
Ken
On 15/08/2013 10:58 PM, Robert L. Nuckolls, III wrote:
Quote: |
<nuckolls.bob(at)aeroelectric.com>
single battery.
battery options.
like this one
a brown-out.
Posted: Thu Aug 15, 2013 7:57 pm Post subject: Failed brownout battery experiment |
At 10:20 PM 8/15/2013, you wrote:
28v Turn & Bank instrument off 12 volts and have no RFI issues.
Ken
Good data . . . thank you.
uuccio(at)gmail.com Guest
Posted: Fri Aug 16, 2013 12:40 pm Post subject: Failed brownout battery experiment |
Quote: | How about an active option? A step up module
like this one
a brown-out.
Did you mean 14 *volts*?
How can you tell that it would support that for a half a second brownout?
user9253
Posted: Fri Aug 16, 2013 1:34 pm Post subject: Re: Failed brownout battery experiment |
Today I tried using 2 "D" cells to boost the voltage during engine start. But the Dynon D-180 still rebooted.
Next I tried 4 AA cells. Success!
With the ignition off, I cranked the engine. The D-180 did NOT reboot.
Now if I could only find some CR14505 3 volt AA batteries to go into my 2 cell panel mounted battery holder.
I might take Bob's suggestion and use a DC to DC booster.
Schematic attached.
Joe
Description: |
 Download |
Filename: |
Brownout Batt.pdf |
Filesize: |
122.17 KB |
Downloaded: |
400 Time(s) |
Eric M. Jones
Posted: Fri Aug 16, 2013 3:16 pm Post subject: Re: Failed brownout battery experiment |
Any electronic device that fails during engine start is not well designed for the environment it is sold for.
An old Car Talk line: Ask the manufacture to fix it. If they say 'they're all like that', just say 'fine; fix them all. Start with this one'.
Slumping voltage on power lines is easy to fix. Dynon certainly knows how to design the circuit. It's a good place to use a supercapacitor if the slump is low enough and long enough to warrant it, otherwise a capacitor will do.
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
rickofudall
Posted: Fri Aug 16, 2013 4:43 pm Post subject: Failed brownout battery experiment |
Eric, Dang it! I was feeling like the kid at the back of the room who waves his arm valiantly even though he's not entirely sure he has an answer. Good to know I might have been learning something while I've been hanging out here. My question would have been, why not a capacitor to do the job rather than a battery? Would not a capacitor be able to take a charge from the system and then patiently wait to give it back when needed?
Rick Girard
On Fri, Aug 16, 2013 at 6:16 PM, Eric M. Jones <emjones(at)charter.net (emjones(at)charter.net)> wrote:
Quote: | --> AeroElectric-List message posted by: "Eric M. Jones" <emjones(at)charter.net (emjones(at)charter.net)>
Eric M. Jones
113 Brentwood Drive
[url=tel:%28508%29%20764-2072](508) 764-2072[/url]
http://forums.matronics.com/viewtopic.php?p=406889#406889
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
user9253
Posted: Fri Aug 16, 2013 5:10 pm Post subject: Re: Failed brownout battery experiment |
I had thought about a capacitor. It would have to be isolated with a diode or resistor or relay so that it does not give its energy to the starter motor. And it would have to maintain at least 10 volts for 1/4 second. What amount of capacitance is required? Super capacitors are expensive.
Joe
nuckollsr
Joined: 24 Mar 2009 Posts: 95 Location: Medicine Lodge, KS
Posted: Fri Aug 16, 2013 6:23 pm Post subject: Re: Failed brownout battery experiment |
Okay, it's pretty easy to run the numbers from the perspective of the transfer of energy from a capacitor to some load. The energy stored on a capacitor is (C*E^2)/2 = Joules. We deduced a need for 7 Joules to be available to the D180 at 10V or greater.
The charging source is the battery. A fully charged battery would rest at about 13.0 volts. So energy stored at 13 volts minus remaining energy at 10 volts must be 7Joules or more.
(C*13^2)/2 - (C*10^2)/2 = 7
169C/2 - 100C/2 = 7
69C/2 = 7
34.5C = 7
C = 7/34.5 = 0.2 Farads
The capacitor should be good for at least 15 volts unless you're going to disconnect it with the alternator running. As you've noted, it would also need to be diode or switch isolated from the bus to prevent back-feed. A diode would offer significant impact to the e-squared nature of energy stored . . . so perhaps relay or switch contacts should be used to unhook the capacitor from the bus milliseconds before starter is engaged.
AA cells are not well suited to 1+ amp discharge situations but as you've discovered, D-cells took the hit nicely. A d-cell array is certainly cost attractive but gives you another battery to maintain. But it gets pre-flight tested every start-up. I suspect service life on a d-cell array would be quite long. A super-cap is maintenance free but not cheap and pretty hefty in size. The DC to DC converter is small, maintenance free and the price is certainly right.
It appears you have a constellation of options to consider.
