4rcsimmons(at)comcast.net Guest
Posted: Thu Sep 26, 2013 5:59 am Post subject: 601XL B 3300 carb / left - right bank temp differential |
For the record I am building a 601XL (B) with the Jabiru 3300!
Over the past years of building my plane and reading the Matronics list for the Jabiru 3300 Engine and the Zenith list there has been a lot of conversation on Left/Right Bank Temp differential due to the sharp bend of the intake hose joining the Air box to Carb. I have read on the forums simply twisting the Carb a bit in its couplings and this improves the condition. Others may also add veins in the intake tube to straighten out the airflow a bit. For a While, the Cobra tube was offered but that source has moved on to other things in life so they say.
My thoughts are to rotate the tube on the Carb 90 degrees and then plumb my way back to the air box and also moving the coupling on the air box.
So with my above statements, what is the better way to attack this problem before my targeted first flight next spring since I am still in the wiring and final installation mode?
I know this will draw many opinions but I consider learning from what others did and listening to wise old owls is probably a good thing!
Thanks for sharing your opinion and what you did yourself.
Rich Simmons
Murfreesboro, TN
- Rich
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
