scott(at)s-f-x.com Guest
Posted: Tue Sep 17, 2013 12:29 am Post subject: Engine mount bolts |
Hi
Has anyone else got engine mount bolts glassed in at the front ? I understand there should be nuts under the cross-member and the bolts go in, at angles, from above to allow removal ! Mine prevent removal as they bind when trying to lift the mount off (due to the angle) so we are going to cut them out and replace in a more sensible manner. Can't believe the rubber mounts could be replaced in this configuration - otherwise it's a 1 hour job - not 16 which is where we seem to be at the moment.
Scott MacIntyre
G-BUZB
UK +44 7860 208432
US +1 (818) 397 0666
scott(at)s-f-x.com
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
paqs345(at)gmail.com Guest
Posted: Tue Sep 17, 2013 7:00 am Post subject: Engine mount bolts |
My bolts go in from the bottom. There are holes in the cowling for
access. The nuts in front are on top.
Sonja
On 9/17/13, Scott - Special Effects Armourer <scott(at)s-f-x.com> wrote:
Hi
Scott MacIntyre
G-BUZB
UK +44 7860 208432
scott(at)s-f-x.com
Mi
Posted: Tue Sep 17, 2013 7:14 am Post subject: Engine mount bolts |
Holes in the cowling ! That's one of my options - I have a drill...
Scott MacIntyre
UK +44 7860 208432
scott(at)s-f-x.com
On 17 Sep 2013, at 15:57, Sonja Englert <paqs345(at)gmail.com> wrote:
Sonja
> Hi
> Scott MacIntyre
> G-BUZB
> UK +44 7860 208432
> scott(at)s-f-x.com
Mi
bernard.wilder2(at)gmail. Guest
Posted: Tue Sep 17, 2013 8:37 am Post subject: Engine mount bolts |
My bolts are not glassed in and go in from the top. Access holes in
cowl to tiighten the nuts, which, if they fall off, I still have the
bolts in place. I was taugh that in any installation on anything that
the nuts always go on the bottom.
When re-installing engine, I lower the engine down on the engine bed,
wiggle it around a bit to line things up and the bolts fall down in
place.
Bernie Wilder
On Tue, Sep 17, 2013 at 10:57 AM, Sonja Englert <paqs345(at)gmail.com> wrote:
Sonja
> Hi
> Scott MacIntyre
> G-BUZB
> UK +44 7860 208432
> scott(at)s-f-x.com
Mi
ccoulter(at)wavecable.com Guest
Posted: Tue Sep 17, 2013 11:29 am Post subject: Engine mount bolts |
When I built my Pulsar I cut out plugs under the front
motor mounts so I insert the bolts from the bottom. After
the bolts are in place the plugs go back in.
Clarke
On Tue, 17 Sep 2013 09:27:06 +0100
wrote:
Hi
Scott MacIntyre
G-BUZB
UK +44 7860 208432
scott(at)s-f-x.com
Un/Subscription,
Forums!
Admin.
