schmoboy
Posted: Mon Sep 16, 2013 8:00 am Post subject: Flatbed Tow Truck To Hangar |
I'm getting ready to take the fuselage to the hangar and I wanted to
check on a couple things first.
I am bit worried about the wench on the tow truck hooking to the nose
gear to get it on the truck. Not sure the weld on the front is meant to
take stresses in that direction? Is that fine or are there other options?
Anyone with a parking break, did you put fluid in the system and set the
parking break when on the truck?
I know the tilt of the truck when loading has the potential to rub the
tail when loading and unloading. I have grades at pickup and delivery
that would probably help that, but I assume you just have to be aware
and watch for that.
-Sean #40303 (last 90% to go)
davidsoutpost(at)comcast. Guest
Posted: Mon Sep 16, 2013 8:23 am Post subject: Flatbed Tow Truck To Hangar |
There a different sizes of flatbeds available. You want one with a roll down bed and you also want one with a totally flat bed with the tie down rails flush with the deck, not up as the wheels may not clear especially if you have the axle extensions on for the wheel fairings. My driver arrived with the smaller flatbed and had to go get the larger one. The deck needs to be long and fully extended before tilting down to the ground. I had no problem getting up and on with plenty of ground clearance at the tail. I have parking brakes and used them. The operator had a tow strap that we wrapped around the nose strut twice then hooked to the winch cable hook. It worked great and the strut was not stressed at all. I purchased 4 HD ratcheting 12' straps and good thing I had them. I put a bolt through the spars at the bottom outboard holes on each side. I used one strap per side hooking on the bolt and the flush strapping/tie-down rail. Tightened just enough to full the tires down about 3/4". Then I strapped the other two tie-downs to the tail tie-down ring and out to the aft corners of the deck. Tightened up just enough to pull the tail down a couple inches and equal tension on the nose strut strap/winch. I then set the parking brake. I followed behind the flatbed and the plane was rock solid to the deck all the way to the hanger partially on a 2 mile pot hole filled dirt road. He made two trips. One for the plane and another for the wings. It was the best $200 I ever spent renting that flatbed wrecker and driver IMHO.
Sent: Monday, September 16, 2013 11:59:49 AM
Subject: Flatbed Tow Truck To Hangar
--> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com>
and watch for that.
rnewman(at)tcwtech.com Guest
Posted: Mon Sep 16, 2013 8:30 am Post subject: Flatbed Tow Truck To Hangar |
Although I used a flatbed trailer instead of a tow truck I considered the same issues. I decided to put a 2" nylon strap around the main gear and use that to pull on with a winch. Also I put the fuselage on tail first
Bob Newman
N541RV
On Sep 16, 2013, at 11:59 AM, Sean Stephens <sean(at)stephensville.com> wrote:
I'm getting ready to take the fuselage to the hangar and I wanted to check on a couple things first.
I am bit worried about the wench on the tow truck hooking to the nose gear to get it on the truck. Not sure the weld on the front is meant to take stresses in that direction? Is that fine or are there other options?
Anyone with a parking break, did you put fluid in the system and set the parking break when on the truck?
I know the tilt of the truck when loading has the potential to rub the tail when loading and unloading. I have grades at pickup and delivery that would probably help that, but I assume you just have to be aware and watch for that.
Posted: Mon Sep 16, 2013 8:37 am Post subject: Flatbed Tow Truck To Hangar |
On 9/16/2013 11:59 AM, Sean Stephens wrote:
You have wenches on your tow trucks????? Wish we had them here. All we
have is unshaven guys with pot bellies!!!!
| Quote: | hooking to the nose gear to get it on the truck. Not sure the weld on
If you have a tow bar then use that to pull the airplane. Strap the tow
bar so it doesn't come unhooked. Barring that a strap just above the
nosewheel fork will do just fine. There really isn't much stress
pulling it up an incline.
| Quote: | Anyone with a parking break, did you put fluid in the system and set
That wouldn't be a bad idea, but when it's strapped down to the bed of
the tow truck it won't (or shouldn't) go anywhere.
| Quote: | I know the tilt of the truck when loading has the potential to rub the
and watch for that.
The tow truck should have ramps (only two though) or you could borrow
... three .... to make the angle with the ground less severe.
Take lots of pictures!!!!
Linn
Checked by AVG - www.avg.com
kearney
Posted: Mon Sep 16, 2013 8:53 am Post subject: Flatbed Tow Truck To Hangar |
Sean
With a small ramp, I was able to put my fuse on a flat bed by have someone push on each side - pushing on the gear leg and wing spar. It was actually very easy. I also had a winch on the nose gear but the load was spread evenly between the push and pull.
Cheers
Les
On 2013-09-16, at 10:29 AM, Tcwtech <rnewman(at)tcwtech.com> wrote:
Bob Newman
N541RV
Posted: Mon Sep 16, 2013 9:13 am Post subject: Flatbed Tow Truck To Hangar |
Oh, And while the driver slowly winched the plane up, I had the Bogi Bar hooked up and helped steer the nose wheel.
Sent: Monday, September 16, 2013 12:23:25 PM
Subject: Re: Flatbed Tow Truck To Hangar
and watch for that.
get="_blank">http://www.matronics.com/Navigator?RV10-List
tp://forums.matronics.com
schmoboy
Posted: Mon Sep 16, 2013 9:35 am Post subject: Flatbed Tow Truck To Hangar |
Thanks all. And yes, we have wenches on our tow trucks here. You pay
extra for it, but it is worth it. Wench, winch, they both pull.
DO NOT ARCHIVE
On 9/16/13 11:36 AM, Linn Walters wrote:
| Quote: | You have wenches on your tow trucks????? Wish we had them here. All
we have is unshaven guys with pot bellies!!!!
Bob Turner
Posted: Mon Sep 16, 2013 11:02 am Post subject: Re: Flatbed Tow Truck To Hangar |
I rented a roll down bed truck and drove it myself. Earlier I visited the rental place with a tape measure. Only one of their trucks had a wide enough bed.
I did not have the engine on so it was easy to winch up backwards, using the tail tie down.
I used rope to tie down the wheels, which only had an inch or so to spare from the edge of the bed. Good thing: I also chocked the wheels but after 15 miles of pot holed CA freeway, the chocks got lost somewhere along the way.
I also rented a pallet jack, and made a second trip for the engine (still in Lycoming box, on a pallet), prop, and wings (still on their wing stands but lots of rope).
I bought overpriced builder's insurance only because it covered this trip.
_________________ Bob Turner
RV-10 QB |
Phil White
Joined: 10 Jan 2006 Posts: 45 Location: Downers Grove, IL
Posted: Tue Sep 17, 2013 8:22 am Post subject: Re: Flatbed Tow Truck To Hangar |
Moved my -10 a week ago about 4 miles from rented hangar to garage, so I would work on it more often (only been at it 9+ years, with the auto engine conversion!). Rented a SNOW MOBILE trailer, which had a 8.5' wide x 10' long tilt-bed.
Worked great. Rear tie-down ring did drag a bit with the angle when loading, but that's why I had it in place. Wings in a cradle on casters went on the second trip. We hot-rodded it all of 17 mph max on paved streets, to baby my baby.
Rental cost was only $50 for the day, and I could control the whole process. Used a ratchet pull winch for the loading and unloading, to a rope around the nose gear. That too worked well, if slowly.
schmoboy
Posted: Tue Sep 17, 2013 10:32 am Post subject: Flatbed Tow Truck To Hangar |
Snow Mobile trailer. Didn't think of that. There's one close by for
$60/day. Thanks.
On 9/17/13 11:22 AM, Phil White wrote:
http://forums.matronics.com/viewtopic.php?p=408748#408748
Tim Olson
Posted: Tue Sep 17, 2013 10:49 am Post subject: Flatbed Tow Truck To Hangar |
That's what I used, too. The catch was, I have a wide trailer, I think
100" or something
near that side. Some of the older, narrower ones won't quite do it.
Tim
On 9/17/2013 1:32 PM, Sean Stephens wrote:
$60/day. Thanks.
bwestfall
Joined: 22 Oct 2008 Posts: 131 Location: Portland, OR
Posted: Tue Sep 17, 2013 11:38 am Post subject: Flatbed Tow Truck To Hangar |
As yet another method...
Sometimes you can make a narrower flatbed trailer work w/o too much effort.
I helped move Mark Cooper's RV-10 with Paul Grimstad and his flatbed trailer
that is a bit too narrow for the RV-10 wheelbase. You can see pictures of
the required lumber additions to his tilt deck flatbed to "widen" it a bit.
Worked well but did take $50 or so in boards and a screws and about 30 min
work in the Oregon rainshine that day.
Mark's blog w/photos:
http://myrv10factory.wordpress.com/2013/03/18/the-big-move/
-Ben Westfall
Jim Berry
Posted: Tue Sep 17, 2013 7:00 pm Post subject: Re: Flatbed Tow Truck To Hangar |
| schmoboy wrote: | Thanks all. And yes, we have wenches on our tow trucks here. You pay
DO NOT ARCHIVE
I also hired a roll down bed truck. Turns out the wench driving it was a former A&P. She was being more careful with the fuselage than I was. A real Renaissance woman.
Jim Berry
Jackm
Posted: Tue Sep 17, 2013 7:48 pm Post subject: Re: Flatbed Tow Truck To Hangar |
This is how we moved to paint shop for four hour drive. Very secure and easy to move. This skid will be available to anyone to use after it returns back.....only problem is it weighs half as much as complete plane.
75.44 KB |
21903 Time(s) |
_________________ Jackm
schmoboy
Posted: Mon Sep 30, 2013 1:59 pm Post subject: Re: Flatbed Tow Truck To Hangar |
Well it made it safely to its new home. Thanks for all the suggestions. Found a company with a slide down tilt bed so had no issues with the tail dragging. I put bolts through the spars to be used as strap downs. And no... driver was not a wench.
Funny thing is that I seem to have separation anxiety this afternoon. The baby is no longer a few steps away out in the garage, but a half hour drive.
123.19 KB |
22052 Time(s) |
153.86 KB |
22052 Time(s) |
165.73 KB |
22051 Time(s) |
Bill Strahan
Posted: Sat Oct 05, 2013 7:07 am Post subject: Re: Flatbed Tow Truck To Hangar |
| Jackm wrote: | | This is how we moved to paint shop for four hour drive. Very secure and easy to move. This skid will be available to anyone to use after it returns back.....only problem is it weighs half as much as complete plane. |
Jack,
Would you be willing to share any information you have on the design of that skid? Materials, wall thicknesses, etc.
Thanks!
Bill
Jackm
Posted: Sun Oct 06, 2013 8:09 pm Post subject: Re: Flatbed Tow Truck To Hangar |
Bill,
Two forklift supports was 3 x 5 x .188" Across rear was 4 x 4 x.188" . Slid in each side was 3.5 x 3.5 x188" tube that was welded to 18" of heavy 8" c chan. Center front was 24" 8" c chan. 1" pipe weld on each rear skid for handles and also round support for straps to pull down on landing gear. Flat bar welded for and aft of each tire to gain extra wedge for tires to ride in.
When I get it back from paint shop I can send you better pictures and dimensions. It took about a hour to weld up and about $300 of metal but I was not going to chance rolling all that work up a ramp and end up upside down during unload at paint shop. This was quick and secure and can be used by others once we are done with it.
Hope this helps and let me know what else you need.
_________________ Jackm |
johngoodman
Posted: Wed Oct 09, 2013 9:10 am Post subject: Re: Flatbed Tow Truck To Hangar |
Guys,
Size down those photos! It's hard to scroll to the right to read one line of text.
John
_________________ #40572 Phase One complete in 2011 |
Bill Strahan
Posted: Wed Oct 09, 2013 2:30 pm Post subject: Re: Flatbed Tow Truck To Hangar |
Perfect! Just hang on ti it, keep a forklift in the hanger, and you can lift it up enough to keep two planes in there!
| Jackm wrote: | Bill,
Hope this helps and let me know what else you need. |
