dave.saylor.aircrafters(a Guest
Posted: Fri Sep 13, 2013 1:38 pm Post subject: Bad Crimp? |
Bob,
Can you tell from the photo if this is this a poor crimp? It was overheating on the back of a strobe switch. I recall Bill Watson had a crimp fail on a strobe switch recently as well. The strobes were occasionally intermittent but the wire near the terminal was always very hot to the touch. The insulation was discolored too.
I changed the terminal and the last few inches of wire, and now all is well. Nice and cool.
Any comments on the crimp would be much appreciated.
Dave Saylor
831-750-0284 CL
416.4 KB |
6933 Time(s) |
nuckollsr
Joined: 24 Mar 2009 Posts: 95 Location: Medicine Lodge, KS
Posted: Fri Sep 13, 2013 5:58 pm Post subject: Re: Bad Crimp? |
I think the evidence is pretty conclusive. ANY terminal that gets hot is victim to heat dissipated in some resistance between wire and terminal or terminal and installation surface . . . or both.
Compare the appearance of cross section for the terminal you replaces versus a terminal I sectioned for this article:
http://tinyurl.com/kfk6jss
The terminal you removed was definitely not INTIMATELY mated with the wire strands. There are voids between strands and a large void in the cavity adjacent to captured strands. In the "golden-crush", wires become indistinguishable from the terminal's wire grip barrel.
Was the terminal the right size for the wire? If it was installed with a tool from your shop, an investigation is warranted. You don't want to install a bunch of terminals like that!
104.36 KB |
6921 Time(s) |
Posted: Sat Sep 14, 2013 8:39 am Post subject: Bad Crimp? |
Yep, I have a few tools to take a look at. Hopefully it's a case of using the wrong crimper slot. It's a 20AWG in a red PIDG terminal.
FWIW, the wire felt very slightly loose in the connector, but it didn't pull out. Just kind of worked back and forth.
Dave Saylor
831-750-0284 CL
On Fri, Sep 13, 2013 at 6:58 PM, nuckollsr <bob.nuckolls(at)aeroelectric.com (bob.nuckolls(at)aeroelectric.com)> wrote:
[quote] --> AeroElectric-List message posted by: "nuckollsr" <bob.nuckolls(at)aeroelectric.com (bob.nuckolls(at)aeroelectric.com)>
http://forums.matronics.com/viewtopic.php?p=408569#408569
http://forums.matronics.com//files/photo_135_164.jpg
ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
MS -
e -
sprocket(at)vx-aviation.c Guest
Posted: Sun Sep 15, 2013 2:28 pm Post subject: Bad Crimp? |
A few years ago, I had a strobe switch failure, and the terminals charred. The root cause is thermal runaway:
A strobe power supply is a constant-power device. This means that if there is resistance in the switch circuit, it will draw more current to make up the different. This increased current makes the switch get hotter, increasing resistance, and so on. Eventually everything gets toasty and fails.
The root cause of this was found (and reviewed by Bob) to be loose rivets on the Carling switches used in this application. After I switched to Honeywell switches (and changed the charred fast-ons), I’ve had no problems. This loose rivet failure also occurred in my landing light circuit and master switch.
Vern
From: Dave Saylor (dave.saylor.aircrafters(at)gmail.com)
Sent: Friday, September 13, 2013 2:36 PM
Subject: Bad Crimp?
Bob,
Dave Saylor
831-750-0284 CL
Checked by AVG - www.avg.com
Version: 2013.0.3408 / Virus Database: 3222/6663 - Release Date: 09/13/13
Posted: Wed Sep 18, 2013 4:41 pm Post subject: Bad Crimp? |
Good memory there Dave. I did replace the crimp and all seemed well with the original installation.
However, during my problem determination and fell back on the good 'ol swap the box solution. That is, I bought a new strobe unit to replace the "Avi-Pak" unit from CreativAir. I picked up the "XPAK604X" unit from Nova Electronics. It is a non-aviation unit but it mounts in the same mount and looks like it is from the same manufacturer.
However, this unit keeps the switch out of the main power circuit. That is, the XPAK604X has a power circuit that in the '10 can be run directly from the rear mounted battery to the strobe power unit - a run of less than 2 feet. Then the panel switch is wired on a separate control circuit. Notably, the panel switch no longer is warm to the touch.
I've been running this for about a year and all is good.
Can't do it now but I can supply more information if needed.
Bill
On 9/13/2013 5:36 PM, Dave Saylor wrote:
[quote] Bob,
Dave Saylor
831-750-0284 CL
09/18/13 [b]
Posted: Thu Sep 19, 2013 9:04 am Post subject: Bad Crimp? |
In case there are some out there considering strobe power supplies for their RV10, here are some diagrams that may be of interest.
Here is (hopefully) a link to a page of the instructions for the old CreativAir Avi-pak strobe power supply. I don't think these are sold any longer but I'm sure a number of older RV10s have them.
https://www.dropbox.com/s/2mz34v7tidnmbah/AVI-PAK%20from%20CreativAir.jpg
Here is a link to a page from the non-aviation supply from Nova Electronics where the switch is in some kind of control circuit.
https://www.dropbox.com/s/vfsm8htq7e82upx/XPAK604X%20scan.jpg
Given the typical locations in the RV10, Wiring the main power line to a power bus location that is local to the battery seems preferable to running the same power line up to the panel and back.
Bill
On 9/18/2013 11:48 PM, Dave Saylor wrote:
[quote] I did some tests with our crimper. As long as it's used correctly, it still makes good crimps. Whew!
I made some poor crimps on purpose, and they looked like the the one that failed. But I really had to abuse it. Musta had a bad day.
Bill, I like the idea of having the switch as a control. The strobe pack powered by the failed crimp is the certified Whelen version with regular strobes and LED nav lights. Personally, I have an automotive Whelen version in my plane. I haven't looked at it lately but I recall it has a blade fuse in the case, as you mentioned only a few inches from the master relay, and it switches to ground. But I don't think the switch is a control as you described since it's the only ground in the system.
Dave Saylor
831-750-0284 CL
On Wed, Sep 18, 2013 at 5:41 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
| Quote: | Good memory there Dave. I did replace the crimp and all seemed well with the original installation.
Bill
| Quote: | Bob,
Dave Saylor
[url=tel:831-750-0284]831-750-0284[/url] CL
09/18/13
09/18/13 [b]
