De-Slumpifier, Voltage Buffer to Prevent Brownout
Eric M. Jones
PostPosted: Sun Sep 08, 2013 11:41 am    Post subject: De-Slumpifier, Voltage Buffer to Prevent Brownout Reply with quote
I built and tested the 12V De-Slumpifier and it behaves very well with no surprises. I don't have a publishable test protocol, but for general purposes this is a good design that can be used for many anti-slump applications. If there is sufficient interest, I will make a PCB and maybe a kit of parts.
Note how much space remains inside the box. The 35W resistor and heatsink and one diode is under the perf board.
I added an optional LED indicator. The supercaps behave almost exactly like a 250,000 uF/20V capacitor bank which used to fit into a suitcase.
Prototype De-Slumpifier
 Filesize:  163.93 KB
 Viewed:  3128 Time(s)
De-Slumpifier
 Filesize:  99.03 KB
Slumpless 12V Buffer.pdf
Schematic and Parts List
 Filename:  Slumpless 12V Buffer.pdf
 Filesize:  82.48 KB
 Downloaded:  491 Time(s)
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
