Couple question
funnyb0nz
PostPosted: Sat Sep 07, 2013 6:53 am    Post subject: Couple question Reply with quote
Hey guys, I see a lot of Kolb Firestar II's for sale on Barnstormers. I plan on picking up a KXP. There are a couple others that are newer, however don't have current annual and there was one with no N number. Is it best to stay clear from them if they are not current?
I currently fly out of airport, so thinking its best to stay with something that has current annual, and also N numbered?
What are your thoughts? Get older KOLB KXP that is current? or get a 2003 that is year passed annual and cost a couple grand more?
herbgh(at)nctc.com
PostPosted: Sat Sep 07, 2013 7:00 am    Post subject: Couple question Reply with quote
I have a friend who swears that his 7 rib Firestar with a 377 is UL
legal....So..would not discount that possibility.... Herb
http://forums.matronics.com/viewtopic.php?p=408197#408197
lcottrell
PostPosted: Sat Sep 07, 2013 8:06 am    Post subject: Couple question Reply with quote
I have a Firestar II and I like it. However a friend of mine has a KXP with a 7 rib wing, and the honest truth is that his plane will run circles around mine. Take offs are shorter, landings are shorter, climb is better, and the thing with a 503 will run as fast or faster than mine with a HKS. Of course I get better mileage with the HKS, and my plane is heavier, and I am heavier, but I would have to think long and hard if he wanted to trade. There is no way that I would consider any plane without a N number, it is just trouble that you don't really need.  Larry
On Sat, Sep 7, 2013 at 8:53 AM, funnyb0nz <dan_eshman(at)hotmail.com (dan_eshman(at)hotmail.com)> wrote:
--> Kolb-List message posted by: "funnyb0nz" <dan_eshman(at)hotmail.com (dan_eshman(at)hotmail.com)>
le, List Admin.
rickofudall
PostPosted: Sat Sep 07, 2013 9:42 am    Post subject: Couple question Reply with quote
Dan, If you look at any Firestar that claims to be UL legal make sure your pre buy inspection specifies a weight and balance done by an independent shop that you pay. That way you know what you are getting isn't someone's bright idea of an ultralight. You should also do the AC 103-7 worksheet which should also show that a Firestar is about 25 mph too fast to be an ultralight as well.  If you want to think about getting an unregistered plane "brought in" by getting it registered, talk to your local FSDO or contact a DAR. The official line is that the only option available is Experimental Exhibition, but who knows. My advice is get it in writing if they tell you there's a path to Experimental Amateur Built and make sure they understand that the plane is built and flying, not some kit you're going to complete. Herb, According to Rotax, the 377 actually weighs 2.2 lb. (1 kg) MORE than a 447 (assuming their both using the same gearbox and exhaust). Kolb listed the empty weight of the Firestar as typically 325 lb. I think you're friend has rather generous scales.
Rick Girard
On Sat, Sep 7, 2013 at 5:00 AM, herb <herbgh(at)nctc.com (herbgh(at)nctc.com)> wrote:
--> Kolb-List message posted by: herb <herbgh(at)nctc.com (herbgh(at)nctc.com)>
I have a friend who swears that his 7 rib Firestar with a 377 is UL legal...So..would not discount that possibility.... Herb
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
herbgh(at)nctc.com
PostPosted: Sat Sep 07, 2013 12:12 pm    Post subject: Couple question Reply with quote
I think,early on, the fuselage for some of the smaller Kolbs were built
with .028(029?) cro molly...and I think the early Firestar's were quite
light...Not sure that the factory has specs for pre TNK Firestars....?
Surprised that the 377 weighs more than the 447? How can that be?
Electronic ign. vs points?
Dennis. can you weigh in on this...I am looking for a "light"
Firestar...Herb
going to complete.
Rick Girard
funnyb0nz
PostPosted: Sat Sep 07, 2013 12:29 pm    Post subject: Re: Couple question Reply with quote
Hey guys, thanks for the info. I am taking a road trip about 6 hours away tomorrow to look at the KXP. It has current annual, and also N number which I prefer. I will keep you all updated. If I buy it, I am sure I am going to have lots of questions.
Thanks for feedback!
Ducati SS
PostPosted: Sat Sep 07, 2013 4:20 pm    Post subject: Re: Couple question Reply with quote
A guess on weight....Though I have had them apart I never measured the thickness of a 377 cylinder liner, but it would not be at all unusual for a manufacturer to use a much thicker liner than needed on a new design to allow for a future increase in displacement. That would account for the smaller displacement engines extra weight. The Suzuki TM 100 comes to mind, much heaver cylinder than the otherwise identical TM 125.
R. Hankins
PostPosted: Sat Sep 07, 2013 5:15 pm    Post subject: Re: Couple question Reply with quote
As long as the aircraft has been well maintained, I would go with the older, current KXP. Mine is a 1992 kit that has been flying since 1999. It has 640 hrs on it at the moment. I flew it 291 miles today in just over 4 hrs and burned 15.3 gals of gas. That is 19mpg at an avg of 71mph with a dual carb 503. Do make sure it has 7 main wing ribs. If it has 5, it is not a KXP. The 2 extra ribs were added for the 503 engine.
 Filesize:  1.84 MB
 Viewed:  13969 Time(s)
Roger in Oregon
1992 KXP 503 - N1782C
R. Hankins
 Filesize:  1.84 MB
 Viewed:  13968 Time(s)
Roger in Oregon
funnyb0nz
PostPosted: Mon Sep 09, 2013 5:45 pm    Post subject: Re: Couple question Reply with quote
Hey guys, I am now the new owner of a KXP, it did have 7 ribs, that is one thing the old owner told me. He actually told me about this forum. I am sure I will have many questions. So if anyone has pics of a full enclosure that I could see to get some ideas, that would be greatly appreciated. Want to have it ready for winter flying, but also like to take the doors off for spring/summer flying.
What is best to use to clean the material of the kxp, it needs a nice bath and would like to detail it up so looks really nice before I get trained to fly it.
Thanks!
rowedenny
PostPosted: Tue Sep 10, 2013 1:50 am    Post subject: Couple question Reply with quote
I use dish soap in water and a car cleaning sponge or mitten.
Dennis "Skid" Rowe
Mk3, 690L-70, Leechburg, PA
Thanks!
http://forums.matronics.com/viewtopic.php?p=408316#408316
beauford173(at)tampabay.r
PostPosted: Tue Sep 10, 2013 7:47 am    Post subject: Couple question Reply with quote
Brother Dan:
Have had good luck (no evident aluminum or 4130 corrosion) with a little
common dishwashing
detergent highly diluted in water. FWIW, I would definitely stay away from
any alkaline-based cleaners such as
Simple Green or TSP. Many are reactive with aluminum and if the cleaning
solution gets trapped against tubing, such as under fabric or inside the
wing, they can attack the protective aluminum oxide surface and initiate
corrosion.
Worth about what ye paid fer it...
Enjoy your new Kolb....
beauford
FF-076
Brandon, FL
" Hey guys, I am now the new owner of a KXP> What is best to use to clean
fly it.
Thanks!
