Mike.Hayes(at)denco.co.uk Guest
Posted: Wed Jun 28, 2006 1:26 am Post subject: A65-8 Piston Rings |
I have an A65-8, which has recently had a top end overhaul. Each piston has
two compression rings, and a third oil scraper ring. At the bottom of each
piston is a fourth oil scraper ring. The only difference I can see between
the compression rings and the oil scraper rings is that the scraper rings
have had one of the outside corners removed, leaving a very small square
channel, or step. I believe that the top oil scraper ring should have this
step facing downwards, and the bottom one should have it facing upwards. Can
you please confirm if this is correct?
I also need a spare scraper ring because I have broken one, but one source
of information suggests I "will be alright" just using an old compression
ring in its place. Doesn't sound right to me - but would appreciate any
input.
Anybody know where I could get some spare scraper rings?
Thanks and regards,
Mike Hayes
Pietenpol G-BKVO
This message and any associated files sent by Denco Limited are
confidential, and intended only for the addressee named above.
If you are not the intended recipient, please notify the IT Helpdesk
by telephone immediately on 01432 377368 (UK) or +(44) 1432 377 368
(international) or return it to us by e-mail quoting the name of the
sender and the address. Please also be advised that you have received
this email in error and that any disclosure and/or use of the information
contained within this email or attachments is strictly prohibited.
Any views or opinions expressed in this e-mail are solely those of the
sender and do not necessarily represent those of Denco Limited, its
divisions and/or subsidiaries, unless otherwise specifically stated.
Please note that this e-mail and any attachments have not been encrypted.
They may therefore be liable to be compromised. This is an inherent
risk in relation to e-mail. Denco Holdings Limited its divisions
subsidiaries and divisions of subsidiaries do not, to the extent
permitted by law, accept any liability (whether in contract, negligence
or otherwise) for any changes made to this e-mail after it has been
sent by the original sender, any external compromises of security and/or
breaches of confidentiality in relation to transmissions sent by e-mail.
We cannot to the extent permitted by law accept any liability (whether
in contract, negligence or otherwise) for any damage sustained as a
result of any software viruses and it is therefore your responsibility
to scan the attachments (if any) and carry out your own virus check before
opening any attachments.
| | - The Matronics Continental-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
