Paint
jkreidler
PostPosted: Mon Aug 26, 2013 7:43 am    Post subject: Paint Reply with quote
We are getting ready to have the airplane painted at Watertown in Wisconsin. Any strong opinions / reasons for a single stage top coat versus a base coat / clear coat system? In both cases we will use aviation finishes.
Jason
Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617
Deems Davis
PostPosted: Mon Aug 26, 2013 8:03 am    Post subject: Paint Reply with quote
Jason,
It is really a matter or opinion. The 2 finishes are different in appearance, To some people the difference matters and to some it doesn't. So the 1st question is to figure out if the difference matter. I don't believe that there are any differences in how well one protects vs the other. aA lot of that has to do with the painter and the prep. I believe that a base/clear is going to cost more than a single stage for obvious reasons (more labor). The next item would be to find your painter, some painters will only work with single stage paint.
On Mon, Aug 26, 2013 at 8:43 AM, jkreidler <jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)> wrote:
[quote]--> RV10-List message posted by: "jkreidler" <jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)>
Jason
Jason Kreidler
http://forums.matronics.com/viewtopic.php?p=407507#407507
le, List Admin.
Bob Turner
PostPosted: Mon Aug 26, 2013 9:11 am    Post subject: Re: Paint Reply with quote
It sounds like you have selected your painter. As Deems said, ask him. He's the one who will have to stand by his work.
Bob Turner
RV-10 QB
flying-nut(at)cfl.rr.com
PostPosted: Mon Aug 26, 2013 9:22 am    Post subject: Paint Reply with quote
I'm going single stage ..... just look at all the cars on the road with
clear coat problems. Done by professional robots. Wink
However using clear coat does make spot repairs easier and hides base
coat imperfections. I'm no expert painter (nor do I play one on TV) but
I doubt there's much difference between 'aviation' and 'automotive'
finishes in this day and age. I do know the present day Imron (used to
be my favorite) is formulated differently than the old stuff .... thanks
to the EPA ...... and scratches easier.
Haven't really looked, but I think you'll have far more colors to choose
from with automotive paint. I really love the Dodge Viper Red!!!!
Linn
Jason
Jason Kreidler
Checked by AVG - www.avg.com
carl.froehlich(at)verizon
PostPosted: Mon Aug 26, 2013 9:47 am    Post subject: Paint Reply with quote
The main issue is the thickness of your wallet.
For multiple colors and complex design, a couple of coats of clear over
everything is the way to go. For a good paint job that won't break the bank
and is easy to fix, single coat. On the RV-10 I did three color PPG base
and clear and I worked my ass off. Then a neighbor did one color single
stage PPG on a Lancair 4 and added vinyl stripes and N numbers. His plane
was a third the work of the RV-10, looks show plane good and you can't tell
the stripes are vinyl even an inch away.
Get some quotes from your painter - and if you want any checkers be ready
for a real big number.
Carl
Lew Gallagher
PostPosted: Mon Aug 26, 2013 10:22 am    Post subject: Paint Reply with quote
Hey Jason/Linn,
I paint, not an expert. Base/clear is very slick and provides great
protection, but is more expensive, heavier, AND harder to touch up, not
easier. If you get a chip in base/clear that goes through color, you have
to match/touch up the base color first, then put the clear back on, then if
you want it perfect you have to fine sand the clear flat to match and then
buff. Single coat, just dab the chip and go -- buff if it needs it.
I have doubts about those who paint multiple colors then clear it all. As I
understand it, the early cars with base/clear peeled because the clear
wasn't applied soon enough after the base was shot. Now it is recommended
to clear within 30-40 minutes after base so that it bonds. Otherwise the
base color is to be scuffed before clearing -- I've never done that. You
see the problem if you have multiple colors. If multiple colors are shot at
different times, then cleared days/weeks later -- you could probably get
away with it if your plane is constantly hangared (the cars that peel don't
spend most of their lives in a garage -- notice it is the horizontal
surfaces that peel), but then the single stage paint with "wet look"
hardener would look just as good and last just as long.
Later, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
Tim Olson
PostPosted: Mon Aug 26, 2013 10:41 am    Post subject: Paint Reply with quote
The guy who helped me paint my plane, has a son who was with DuPont
at the time. He said that Imron actually doesn't seem to fill the gaps
around
the rivet head to skin seam and flow in there as well as some other paints.
Tim
with clear coat problems. Done by professional robots. Wink
but I doubt there's much difference between 'aviation' and
'automotive' finishes in this day and age. I do know the present day
Imron (used to be my favorite) is formulated differently than the old
stuff .... thanks to the EPA ...... and scratches easier.
choose from with automotive paint. I really love the Dodge Viper Red!!!!
Linn
> <jason.kreidler(at)regalbeloit.com>
> aviation finishes.
> Jason
> Jason Kreidler
> No virus found in this message.
PostPosted: Mon Aug 26, 2013 11:22 am    Post subject: Paint Reply with quote
Lew is correct on minding times. With PPG you have 24 hours from base to
clear coat (tech sheet attached as example). On my plane I did paint with
wings off, control surfaces and tail feathers removed. This piecemeal
approach enabled me to manage times so I could always get the clear coat on
in the allotted time. Simple jigs to hold the wings so they can be rotated
for paint greatly simplified the work.
I also agree with Lew on the merits of single coat.
Carl
P175+DBC-DBI+10+12.pdf
 Filename:  P175+DBC-DBI+10+12.pdf
 Filesize:  270.07 KB
 Downloaded:  8342 Time(s)
jkreidler
PostPosted: Mon Aug 26, 2013 11:24 am    Post subject: Re: Paint Reply with quote
I wonder if that is why Imron comes in a formula made for riveted airplanes (AF400), they also have a version (AF3500) which they claim is more Skydrol resistant. I am not sure how long the AF400 formula has been around, maybe in response to your comment. Both single stage top coats - sometimes I enjoy speculating....
Our painter is an Imron guy who prefers single stage, but will do clear coats for the money. His feedback mirrors some of what has been said here.
- Jason
[quote="Tim Olson"]The guy who helped me paint my plane, has a son who was with DuPont
around
Tim
Jason Kreidler
robin(at)PaintTheWeb.com
PostPosted: Mon Aug 26, 2013 11:39 am    Post subject: Paint Reply with quote
We can all knock the EPA if we want but those are the same people that got rid of DDT, Benzene Hexachloride & Ethyl Mercury Chloride etc.... What pricks, now our kids are born with both their arms & legs. But don't worry industry still has power to grow our strawberries in Ethylene Dibromide. I mean how bad can something like that be for the environment? As much as I prefer high VOC paints and the smell of fresh mimeograph paper I also like drinking water that you can actually drink.
Robin Smile
wgreenley
PostPosted: Mon Aug 26, 2013 12:23 pm    Post subject: Paint Reply with quote
Sorry, I know this is off topic. But getting rid of DDT killed a million
people a year. I worked in Africa and malaria was almost history, it came
roaring back with tragic consequences I saw in my hospital on a daily basis.
If used properly it was safe and inexpensive, the first world could afford
more expensive alternatives, but the third world could not. I agree that DDT
was dangerous to the environment if misused, but that is true of many
products.
Bill Greenley
michaelrorth
PostPosted: Mon Aug 26, 2013 2:18 pm    Post subject: Paint Reply with quote
Hear! Hear!
Many Greenies are extremely under-educated.
Thanks for the truth.
One amplification, though.
Not only has the lack of DDT resulted in the deaths of millions in the past,
the deaths continue today.
This is why the mosquito is often referred to as "the deadliest animal on
earth".
Michael
Mauledriver(at)nc.rr.com
PostPosted: Mon Aug 26, 2013 2:34 pm    Post subject: Paint Reply with quote
I did my own paint and used a single stage Imron against the advice of a
few local, non aircraft paint shops. I think I made the right decision.
For the DIY painter, single stage is less work. But fixing mistakes can
be harder. The paint pros explained that you can just sand out 2 stage
mistakes and cover everything with clear coat for the A1 final finish.
I see how 2 stage is required for a show winning finish but the single
stage stuff is really nice. Get a nice flake color for your '10 in
single stage and I think you'll be very happy. If your shop recommends
it, then I know you'll be happy if they are any good at all.
My advice for the DIY painter is to find a local paint distributor you
want to work with and shoot one of the brands and lines that he
carries. I started with the idea of using aviation lines from Dupont or
PPG, but I ended up with a non-aviation line of Imron single stage
because the distributor was closer to me than the PPG shop. And only a
few places deal in the aviation lines. That turned out to be an inspired
decision. I made almost daily trips there during my paint process -
prices were good and while the advice was limited it was valuable for
this first time painter.
My guess is that that advice can be applied to paint selection by a
paint shop - use what they like to use. I think skills are surprisingly
product specific. Paints/coatings is very high tech stuff. Experience
and manufacturers technical support are invaluable.
Re regulations and their impact on paint; seems like almost everyone I
met at the local paint depot, who had been shooting polyurethanes over
the last decade was impaired. The guy who ran the place admitted that
he was impaired, not that it wasn't apparent. His paint booth had sat
idle for many years as a result. Many of his customers were impaired -
it only took a short conversation to experience the impairment. Very
scary indeed.
The modern polyurethane paints are fantastic - single or 2 stage - but
toxic as hell. Fresh air breather mandatory. My objective for each
mix, shoot and cure was to never even catch a whiff of it. I mostly
succeeded. I had befriended a neighbor who ran a local paint shop
specializing in trucks, RVs and other big things. They were painting
the hull of a big sailing ship which was too big for even their oversize
booths. They shot it outside and I came by to watch along with a few
others. I quickly ran out of there when I realized I was getting more
exposure to Imron single stage standing 100 feet away than I was going
to get in my own shop. I'm scared of the stuff. It's very bad.
Aviation or non-aviation paints? For our purposes, I don't think it
matters. I have no intention of dousing the plane in Skydrol. Rain is
like sandpaper at 400knots but even in a dive, I just can't flog the
horses that hard. 100knot rain erodes the old lacquers but good quality
poly seems impervious to 200knot rain. I think the sweet spot is a top
of the line Dupont Imron or PPG non-aviation paint. The lower priced
automotive lines are less durable but the industrial grade top of the
line stuff is "EAB aviation certified" in my unqualified opinion and
just a little cheaper than the aviation lines - and certainly more
available for the DIY painter.
Bill "I didn't plan to paint but it turned out to be one of the most
enjoyable challenges of the build" Watson
Jason
Jason Kreidler
jkreidler
PostPosted: Mon Aug 26, 2013 2:44 pm    Post subject: Re: Paint Reply with quote
I am not sure I would ever call anyone on this forum under-educated, much less throw that response at a single individual. Not what I come to this forum for and I think I can safely say I speak for more than myself. I appreciate the information, not the insults.
michaelrorth wrote:
Hear! Hear!
earth".
Michael
Jason Kreidler
PostPosted: Mon Aug 26, 2013 2:46 pm    Post subject: Paint Reply with quote
This is extremely under-educated me not taking the bait...
Robin
jkreidler
PostPosted: Mon Aug 26, 2013 2:48 pm    Post subject: Re: Paint Reply with quote
Thanks Bill, I wish I had a place to spray. I think after doing the entire build to get to the end and say I am not capable of painting is a bit deflating, after all the best thing about the process is the education and experience. Thanks for the feedback. - Jason
scary indeed.
Jason
Jason Kreidler
Jason Kreidler
PostPosted: Mon Aug 26, 2013 4:38 pm    Post subject: Paint Reply with quote
If you have a place to build then I think you have a place to paint.
This is what works for me. YMMV.
I made a 'tent' from 1/2" EMT and sheet plastic. My first booth was 9'
X 9' X 20'. I use PVC fittings to attach the EMT together. Cut schedule
80 'rings and cut the side so it makes a 'c' tube and slip them in the
PVC fittings to hold the EMT. I used the large 'butterfly clips' to
hold the plastic to the EMT. The 9' was because I could only get 10'
wide plastic at the time. There is 20' wide available now. A large
squirrel cage fan exhausted outside and fiberfill on the other end was
my filter. I paid good money for a paint mask because (at the time) the
fresh air hose was too cumbersome. Hang lots of flourescent fixtures so
you get plenty of light. I get good results (remember I'm not a
professional painter) with a HF HVLP gun.
I use a leaf blower to clean the dust out and wet down the floor before
I move the parts in and spray.
I also add some extra reducer to thin the paint, spray a light cross
coat, wait 1/2 hour and spray another light cross coat. Repeat until I
get good coverage and then quit. I wait 2 hours and then pull off any
masking paper/tape. I only use blue and green 3M tape.
For me, there is one really hard part. When you get finished with your
'wet coat(s)' and still have paint in the pot ..... throw it out and
clean up the gun. It's just so hard for me to pitch all those $$$ in my
paint recovery can. My paint recovery can is a coffee can that all the
excess paint, reducer, etc. ends up in. It goes to the hazardous waste
collector along with the empty paint cans.
Good, thorough, prep will make a world of difference in the final
paint. Poor prep and a professional painter will still get you a poor
paint job. IMHO!!!
Linn
michaelrorth
PostPosted: Tue Aug 27, 2013 4:36 am    Post subject: Paint Reply with quote
Mr. Kreidler,
If your name is "Many Greenies" I apologize for insulting you.
If your name is NOT "Many Greenies", I stand by my original post.
Never forget:
50% of Greenies are, by definition, below average.
Michael
arplnplt(at)gmail.com
PostPosted: Tue Aug 27, 2013 5:24 am    Post subject: Paint Reply with quote
Jason,
Having been in the car wash/auto detailing business for almost 30 years I can tell you I am very happy with the imron Watertown put on my plane. The stuff seems to be very tough. 95% of auto vehicles we detail have clear coat and it is very soft in my opinion. It is easy to polish out light scratches and blemishes, but clear coat also is very prone to them whenever you touch it. Clear coat in my opinion is like the plastic lens over your speedometer.
I have about 250 hours on my plane now and detail it often with a non-polish, spray on liquid detailing wax. Takes all the bugs off easily, cleans the plane and I have yet to see any wash rash in the paint. Normal automotive clear coat on the other hand would require a polish type wax to keep it shiny.
Dave Leikam
On Aug 26, 2013, at 5:48 PM, jkreidler <jason.kreidler(at)regalbeloit.com> wrote:
> scary indeed.
>> Jason
>> Jason Kreidler
Jason Kreidler
http://forums.matronics.com/viewtopic.php?p=407542#407542
