Larlaeb
Joined: 02 Apr 2013 Posts: 75 Location: League City, Texas United States
Posted: Thu Aug 22, 2013 7:07 am Post subject: Light Frame Rust |
Hi All,
I have some places on the frame where some rust stain is showing through the paint. The paint in most areas isn't chipping off and this looks almost like a stain on the paint. See attached picture. I'm curious about the best way to deal with this. I'd obviously like to avoid any radical stripping until I'm ready to replace the fabric which is still in good shape.
Locally I've been told everything from a light sanding and repaint with a rust resistant paint to treating it with a 'rust converter' and then repaint with an epoxy based paint. If this has been discussed before I can do a more through search of the list.
Allan
Kolb MKIII
50 Hours
1.77 MB |
9551 Time(s) |
Mike Welch
Posted: Thu Aug 22, 2013 8:07 am Post subject: Light Frame Rust |
Allen,
From what I understand, the proper way to deal with "light" rust corrosion is with a quality
rust converter. There are many brands available.
See:
http://www.corrosion-doctors.org/MetalCoatings/rust-converter.htm
I have seen A&P's use them at annual inspections on rust spots exactly like yours. The
stuff works extremely well.
Mike Welch
On Aug 22, 2013, at 10:07 AM, Larlaeb <larlaeb(at)gmail.com> wrote:
Hi All,
I have some places on the frame where a some rust stain is showing through the paint. The paint isn't chipping off and this looks almost like a stain on the paint. See attached picture. I'm curious about the best way to deal with this. I'd obviously like to avoid any radical stripping until I'm ready to replace the fabric which is still in good shape.
Allan
Kolb MKIII
50 Hours
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Fri Aug 23, 2013 4:10 am Post subject: Re: Light Frame Rust |
CURIOUS - Is this rust underneath EPOXY primer?
_________________ Jerry King |
Larlaeb
Posted: Fri Aug 23, 2013 7:55 am Post subject: Re: Light Frame Rust |
My understanding is it was powder coated then primed and painted but I don't know what kind of paint. (Not my build). I'm trying to find out though.
rickofudall
Posted: Fri Aug 23, 2013 4:35 pm Post subject: Light Frame Rust |
If it was powder coated it is unlikely that it would be painted, too. Powder coating steel typically involves a phosphoric acid cleaning, the powder is applied by electrostatic deposition and then baked to fuse the powder into a continuous plastic coating. Therein lies the problem, once the coating is pierced in any way, or if the phosphoric acid dip is eliminated or too long a time passes between the dip and the coating operation corrosion is sealed under the coating and the staining shown in your pictures results.
Up to you as to how you repair it but AC 43-13 1b is a good place to start.
Rick Girard
On Fri, Aug 23, 2013 at 10:55 AM, Larlaeb <larlaeb(at)gmail.com (larlaeb(at)gmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: "Larlaeb" <larlaeb(at)gmail.com (larlaeb(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=407353#407353
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Rick Lewis
Joined: 03 Jul 2007 Posts: 122 Location: Kingston, Tn.
Posted: Sat Aug 24, 2013 1:25 pm Post subject: Re: Light Frame Rust |
I have seen a few spots of rusts also at the weld joints on my powder coated cage, I mean crap what do I do now. I was told the tubes were oil filled to prevent corrosion, at least that's what Donnie told me before I bought my kit... Donnie's gone now from Kolb.....
_________________ Rick Lewis
(VW Watercooled Engine) |
ceengland7(at)gmail.com Guest
Posted: Sat Aug 24, 2013 1:53 pm Post subject: Light Frame Rust |
On 08/24/2013 04:25 PM, Rick Lewis wrote:
Rick Lewis
If the rust has made it through to the powder coat from inside the tube,
you've got more serious issues than what paint to use.
The acro guys treat the interior of the tubes with linseed oil, weld the
entire structure shut, & weld in an inflation valve & air gauge. If the
gauge drops to nothing, they know that the fuselage has cracked somewhere.
Charlie
beauford173(at)tampabay.r Guest
Posted: Sat Aug 24, 2013 2:17 pm Post subject: Light Frame Rust |
Brother Lewis:
To the best of my limited knowledge, there is only one way to tell whether
the tubes in your cage are filled with oil, or not. Each discrete tube
segment of your cage
would have a sealing rivet plugging the drilled hole where someone injected
the Tube Seal, linseed oil, or whatever. There is no other method I know of
to get oil inside the cage tubes... As far as I know, no drilled holes, no
plug rivets, no oil inside. Houdini remains dead.
If this is not accurate, I am sure some of our fellow Kolbers will set me
straight... sans delay...
Worth what ye paid fer it...
Riveted, soggy, beauford
FF-076
Brandon, FL
"...please, more rain, Drill Sergeant..."
Posted: Sat Aug 24, 2013 4:38 pm Post subject: Light Frame Rust |
to tell whether the tubes in your cage are filled with oil,
or not. Each discrete tube segment of your cage would have
injected the Tube Seal, linseed oil, or whatever. There is
drilled holes, no
Kolbers will set me straight... sans delay...
FF-076
Brandon, FL
Beauford T/Kolbers:
Having had the opportunity of inspecting several Kolb
airframes that were not tube sealed, prior to completion of
my first Kolb, an Ultrastar, in 1984, I decided to by a
quart of Ray Stitt's Tube Seal and pickup a hypodermic
needle and syringe from my local veterinarian. All three of
my Kolbs have been tube sealed. 1/8" holes were sealed with
sealed end pop rivets.
BTW, there was considerable rust inside most of the 4130
tubes in both airframes we cut up.
Still have some tube seal left after treating three
airframes.
Almost impossible to make a perfectly sealed weld joint on
an airframe. If there is a pin hole or a crack, the tube
seal will work its way out and seal the problem. There will
also be a tell tale black sign where the problem is.
My airframe is nearly 23 years old and has more than 3,200
flight hours on it. No cracks, but have had a pin hole or
two in the welds.
Butte, MT
_________________ John Hauck
Titus, Alabama |
Posted: Sat Aug 24, 2013 4:50 pm Post subject: Light Frame Rust |
Gang:
Should have proof read this one before I hit the send
button.
Forget the paragraph above. Should have read:
"Tube seal will indicate a pin hole and/or a crack. It will
seal a pin hole, but not a crack. There will be a tell tale
black residue to indicate there is a problem."
Butte, MT
Titus, Alabama |
Ducati SS
Posted: Sun Aug 25, 2013 6:52 am Post subject: Re: Light Frame Rust |
After seeing a Firestar cage with the lower rear tubes rusted thru I decided to drill all the lower tubes in my Firefly and treat them with Corrosion X. When I inserted the aerosol tube in the 3/32 hole and pressurized the 2 lower rear tubes I could hear pressure escaping out the rear of the tube. The area that is flattened for the boom thru bolt is not sealed and I would think that any Kolb washed or exposed to rain would slowly take on water in the lower rear tubes.
