jpkarnes
Posted: Mon Aug 12, 2013 3:26 pm Post subject: Alt field ckt breaker tripping |
My 5 amp alternator field circuit breaker is tripping after the engine runs for about a minute. I removed the alternator and had it evaluated (at) the local auto parts store and it checked out OK. What other causes other than an overvoltage condition could cause this to happen? The alternator is a Mitsubishi internally regulated variety. The system is fashioned on the "general aviation" schematic in the Aeroelectric appendix. I just completed an upgrade to include a secondary ignition setup with a switch to select the primary/secondary ignition. The engine is an EA-81 Stratus Subaru engine on a Zenith 601 HDS.
Posted: Mon Aug 12, 2013 7:33 pm Post subject: Alt field ckt breaker tripping |
At 06:25 PM 8/12/2013, you wrote:
| Quote: | My 5 amp alternator field circuit breaker is tripping after the
Has the airplane flown? Has the system operated as
expected in the past but shows a new symptom?
Most alternators with built in regulators are not
strictly compatible with the crowbar ov module
sold by B&C and myself.
The 5A field breaker needs to have ABSOLUTE control
over field excitation voltage. This generally
accomplished by some modification of the alternator's
internal wiring . . . like a PlanePower, or modified
for external regulation like B&C.
This does not explain the symptoms you're seeing.
I didn't fine your email address in my sales records
which suggests you got the OVM from B&C.
If you like, you can send me the OVM and I'll make
sure it's calibrated correctly. This is the first
step toward understanding root cause for the trips.
How old is your battery and what size?
Joined: 28 Mar 2008 Posts: 1967 Location: Riley TWP Michigan
Posted: Tue Aug 13, 2013 5:32 am Post subject: Re: Alt field ckt breaker tripping |
| Quote: | | My 5 amp alternator field circuit breaker is tripping after the engine runs for about a minute. I removed the alternator and had it evaluated (at) the local auto parts store and it checked out OK. What other causes other than an overvoltage condition could cause this to happen? |
1. A wire shorting to ground could trip the breaker.
2. The overvoltage module might be set for the wrong voltage, thus tripping the circuit breaker at normal voltages.
3. There could be high resistance in the alternator field circuit. This makes the voltage regulator see a lower voltage than exists on the main bus. The voltage regulator then puts out higher current in order to increase the alternator output voltage.
4. The voltage regulator could be defective.
5. The circuit breaker could be getting warm from a bad connection.
6. The circuit breaker could be defective.
Number 3 above is the most likely cause of the problem. Every switch and terminal connection is suspect. A combination of borderline connections can add up their resistances to cause a lower voltage at the regulator.
Joe
_________________ Joe Gores |
mrspudandcompany(at)veriz Guest
Posted: Tue Aug 13, 2013 6:58 am Post subject: Alt field ckt breaker tripping |
| Quote: | > My 5 amp alternator field circuit breaker is tripping after the engine
This line was in the original post:
" The alternator is a Mitsubishi internally regulated
variety."
This may have a substantial effect on the operation,
as per Bob's previous posting.
Roger
Do you have a slow PC? Try a Free scan http://www.spamfighter.com/SLOW-PCfighter?cid=sigen
jpkarnes
Posted: Tue Aug 13, 2013 9:42 am Post subject: Alt field ckt breaker tripping |
Hi all,
The engine and its electrical system has flown for over 100 hours. The battery is a brand new 12V 18AH gel battery. The plane has not flown for over a year while some modifications/upgrades have been undertaken. The only difference is the installation of a secondary ignition system ala Paul Messenger's dual dizzy setup. I really doubt that there is a short to ground that is causing this problem. Do you recommend installing an external voltage regulator and if so, which one? Clearing this latest hurdle is the only thing keeping me from getting airborne again. )
John Karnes
Suquamish, WA
Posted: Wed Aug 14, 2013 8:23 am Post subject: Alt field ckt breaker tripping |
At 12:40 PM 8/13/2013, you wrote:
| Quote: | Hi all,
Okay, good data. We know this is a change from previously
satisfactory operation. The battery is relatively new
and not likely to be 'soggy' such that it contributes
to system instability.
A automotive shop has pronounced the alternator as
righteous so it seems there is little probability
of internal regulator failure. You can confirm by
running the airplane with a voltmeter on the bus
(preferably an analog meter with a needle) and
see that the voltage is not only in the ballpark
but not 'jumpy'. Of course, you need to disconnect
the OV module.
Once you have confidence in alternator performance
then attention turns to the ov module. It may well
be out of calibration. You can test it on the bench
with an adjustable power supply. If a current limited
supply, set for about 1A, if not, put an automotive tail
light bulb in series with the ov module.
Increase voltage very slowly until the voltage drops and/or
light bulb lights. The module should trip at more than 16.0
and less than 16.5 volts.
I wouldn't worry about flying without it. Using the crowbar
OV module on an internally regulated alternator offers
a false sense of security. There are failures internal
to the regulator that cannot be externally address
except with techniques like . . .
http://tinyurl.com/7z6yzv9
There are dozens of suitable regulators for external
control of an alternator. The problem is that you need
to open your alternator, ground one field brush, bring
other brush to outside world.
Let's get your airplane flying first and then talk
about how you're going to address over-voltage
events.
jpkarnes
Posted: Wed Aug 14, 2013 8:27 am Post subject: Alt field ckt breaker tripping |
How do I achieve the state you describe above "ABSOLUTE control over field excitation voltage."
I think I purchased the OVM from you; it was probably over 10 years ago...
Battery is 12V 18AH gel battery...
Thanks so much for your help!!
John K.
Zenith 601HDS with Stratus Subaru engine
jpkarnes
Posted: Wed Aug 14, 2013 10:56 am Post subject: Alt field ckt breaker tripping |
Bob, you made my day. The engine has never run better and I have adhered to just about every recommendation you gave in your manual. I am an electrical neophyte and your input has been invaluable. I owe you a debt of gratitude!!
John K.
Suquamish, WA
Zenith 601HDS w/Stratus Subaru/Ram heads
Posted: Wed Aug 14, 2013 3:08 pm Post subject: Alt field ckt breaker tripping |
At 01:55 PM 8/14/2013, you wrote:
| Quote: | Bob, you made my day. The engine has never run better and I have
Pleased to be of service. Fly comfortably . . .
