ronko(at)att.net Guest
Posted: Sun Aug 11, 2013 2:45 pm Post subject: Bad Rotax 582 Stator Coil Removed |
Pulsar People,
I am making progress with my Rotax 582 ignition problem. I just got the stator coil removed and fortunately the open 6 inches before the firewall, I did not need to remove or slide the engine from its mounts.
I found one of the white (ground) magneto charging wires was broken right at the 2 prong rubber connector (shouldn't have had to remove the coil to discover that). But both green wires of this magneto charging source are open and as I am told they should read 230 ohms to ground. I wiggled wires to see if there was a loose connection or intermittent, but they always showed open. The wires and physical condition of the stator coil look perfectly fine, no scuffing, cracks, just looks solid.
I anticipate ordering a replacement coil ($713, Ouch! one seventh the cost of a whole new engine). But, it scares me a bit that both mag charging coils are bad. In a way not a surprise, because during my most recent trouble shooting, I could not get spark from either ignition circuit. Earlier, there was a time, when one ignition circuit was working, where I found that the engine would not run on "L" mag switch, swapped mags, still would not runt on "L" mag switch, so both mags seem okay. But now I am wondering, can a mag have a fault condition that burns up a stator coil? I doubt it, but it could be costly to replace the stator coil and fry it. From the looks of the 4 mag charging coils, they must have a significantly thinner wire, and allot more turns (230 ohms worth) than the regulator/battery charging coils, so they would be more susceptible to failure.
The Quicksilver owner that I got the stator flywheel puller from, said he went through the same problem and replaced a stator coil on his Rotax 503.
I plan on calling LEAF and talking to a tech, but any other thoughts from the Pulsar group out there is much appreciated.
Gotta get this Pulsar safely flying for the Pulsar convention.
Best regards,
Ronko
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
MyronTruex(at)comcast.net Guest
Posted: Mon Aug 12, 2013 7:55 am Post subject: Bad Rotax 582 Stator Coil Removed |
I cannot imagine a Stator causing any damage. As for the connections and not being able to examine them, can you repair them. Heat, vibration, and overzealous use of plastic ties can put pressure on connections. The use of shrink tubing can cause similiar issues. Use a magnyfying glass to look for hairline cracks in any solder connections.
One other issue. Didn't someone come up with a water craft part number that is the same but a fraction of the price?
From: owner-pulsar-list-server(at)matronics.com [mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of Ron Koval
Sent: Sunday, August 11, 2013 3:43 PM
To: Pulsar Builders; Pulsar-Aviators(at)yahoogroups.com
Subject: Bad Rotax 582 Stator Coil Removed
Pulsar People,
Best regards,
Ronko
href="http://www.matronics.com/Navigator?Pulsar-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
alan99gill(at)yahoo.co.uk Guest
Posted: Mon Aug 12, 2013 9:45 am Post subject: Bad Rotax 582 Stator Coil Removed |
Hi Ronko
Hints from my Rotax (503 and 582) file.
Transducer supply windings on stator ... Green to White (or ground) ... 230 - 330 ohms
Auxiliary windings ................................. Yellow to Yellow ................... 0.1 to 0.2 ohms
Pickups on triggers .................................. Red to White (or ground) .... 60 ohms
Trigger to flywheel gap ... 20 thou
Alan Gill
UK Pulsar Support
To: Pulsar Builders <Pulsar-List(at)matronics.com>; "Pulsar-Aviators(at)yahoogroups.com" <Pulsar-Aviators(at)yahoogroups.com>
Sent: Sunday, 11 August 2013, 23:42
Subject: Pulsar-List: Bad Rotax 582 Stator Coil Removed
Pulsar People,
Best regards,
Ronko
[quote]ht; http://www.matronics.com/contri===============
Posted: Mon Aug 12, 2013 6:59 pm Post subject: Bad Rotax 582 Stator Coil Removed |
Allen,
Thanks for your response of items that I can check.
I talked to an engine tech (actually he was one of the mechanics that installed my Blue Head engine) at Leading Edge Air Foils and he sent me also the attached document he provides to check the ignition system. It seems there have been some suttle design changes in the system over the years.
Thanks again.
Ron
To: "pulsar-list(at)matronics.com" <pulsar-list(at)matronics.com>
Sent: Monday, August 12, 2013 12:42 PM
Subject: Re: Bad Rotax 582 Stator Coil Removed
Hi Ronko
Auxiliary windings .................................. Yellow to Yellow .................... 0.1 to 0.2 ohms
Alan Gill
UK Pulsar Support
Pulsar People,
Best regards,
Ronko
Ignition_Inspection_Write-up_(Ducati).doc |
22.5 KB |
479 Time(s) |
