roll my own transponder antenna?
messydeer
PostPosted: Sun Aug 04, 2013 7:33 pm    Post subject: roll my own transponder antenna? Reply with quote
Hey Smile
I rolled my own comm antenna a couple years ago. Antenna worked okay, but the location caused RFI, so I bought one and mounted it in a different location. This homemade com antenna could be cut down and used for my transponder antenna.
But, how long do I cut it? Also heard about not being able to check swr in the xpdr freq range, so if I mess up, it could ruin my unit. ACS sells the antenna for $18, so if there's any doubt, I'd go that way.
Dan
Dan
messydeer
PostPosted: Mon Aug 05, 2013 6:23 am    Post subject: Re: roll my own transponder antenna? Reply with quote
Well, that cheap TED xpdr antenna is backordered. I came up with a few different lengths, googling. The diagram below shows it's ~2.5" from the ground plane (aluminum skin). Also read on the sequair site it would be 3.1", but that could be for a non-aluminum plane.
http://www.seqair.com/skunkworks/Antennas/TpxAntProbs/TpxAntProbs.html
Dan
PS: Does that 5/16" ball at the end effect the antenna length? Does it reduce drag??
 Filesize:  16.49 KB
 Viewed:  17637 Time(s)
Bob McC
PostPosted: Mon Aug 05, 2013 7:55 am    Post subject: roll my own transponder antenna? Reply with quote
Dan;
I believe the 3.1" dimension on the Sequoia site is the overall length of
the rod not the portion beyond the ground plane, and yes, this is for a
wooden aeroplane with a relatively small ground plane. The article also
speaks to a larger ground plane having some effect on the length.
Bob McC.
[quote] --
Bob McC
Falco #908
(just starting)
PostPosted: Tue Aug 06, 2013 3:34 am    Post subject: roll my own transponder antenna? Reply with quote
At 09:23 AM 8/5/2013, you wrote:
--> AeroElectric-List message posted by: "messydeer" <messydeer(at)yahoo.com>
There's a host of observed effects not all of which
are significant. When you see an SWR plot like this . . .
[img]cid:.0[/img]
all those peaks and valleys are artifacts of effects
OTHER than the antenna itself. The plots achieved
later
[img]cid:.1[/img]
were MUCH smoother and had a a deep 'dip' toward
1:1 SWR at the frequency of interest.
The article properly identifies the need for TIGHT
electrical connection between the various components,
preferably soldered.
The 2.9" figure for overall length above the ground
plane is fine. The article fails to mention that the
'resonant ground plane' has a radius equal to the
height of the antenna or a diameter of 5.8". Alternatively
you go with the non-resonant ground plane (like a belly
skin) were exact dimensions are LARGE compared to
2.9" but operationally insignificant.
The thing about every antenna needing to be tailored
to an installation is bogus. Early transponders used
a one-tube transmitter consisting of an pencil triode
as an oscillator operating at a frequency controlled
by a resonant cavity.
[img]cid:.2[/img]
These transponders could be 'pulled' off-frequency by
the effects of antennas. Modern, solid state transponders
are not so afflicted.
If you're building for a non-metalic airplane, 2.9"
is the magic number for antenna length and radius
of a ground plane. For a metal airplane, go for 2.9"
antenna on an 'infinite' ground plane.
In any case, metallic joints should be electrically
'tight' . . . solder is good. You can pick up one
of these for about $20 shipping included.
[img]cid:.3[/img]
http://tinyurl.com/lulfq5z
You would mount this on a 2.9" radius disk for use
in wood or plastic airplane.
 Filesize:  49.96 KB
 Viewed:  17614 Time(s)
 Filesize:  54.21 KB
 Filesize:  29.55 KB
 Filesize:  54.98 KB
JOHN TIPTON
PostPosted: Tue Aug 06, 2013 3:44 am    Post subject: roll my own transponder antenna? Reply with quote
Would two units be a good idea, as a 'dipole' - one to ground (sleeve) lead
 Filesize:  49.96 KB
 Filesize:  54.21 KB
 Filesize:  29.55 KB
 Filesize:  54.98 KB
PostPosted: Tue Aug 06, 2013 4:01 am    Post subject: roll my own transponder antenna? Reply with quote
Sure, it's been done.
http://tinyurl.com/n5ac7zt
this antenna has limited applicability in
wood/plastic airplanes only and mounted
on the side of the fuselage. Check out
the SWR plot.
The large area, small aspect ratio antenna elements
account for the broad-band performance.
Bob . . . [quote][b]
dee.whittington(at)gmail.
PostPosted: Tue Aug 06, 2013 10:03 am    Post subject: roll my own transponder antenna? Reply with quote
Bob,
We've mounted the Bob Archer transponder antenna you picture just aft of Bulkhead B on the right side of the fuselage in our Sportsman 2+2. We haven't flown yet (gosh, going on 9 1/2 years of building) but we hope it works well. If we buckle down first flight will be this fall.
Dee
N18TA reserved
DeWitt (Dee) Whittington804-677-4849 iPhone
804-358-4333 Home
www.VirginiaFlyIn.org
Building Glasair Sportsman with 3 partners
On Tue, Aug 6, 2013 at 8:00 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  the SWR plot.
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
PostPosted: Tue Aug 06, 2013 11:36 am    Post subject: roll my own transponder antenna? Reply with quote
At 10:33 PM 8/4/2013, you wrote:
Hey Smile
A comm antenna design is generally more robust at
the base to accommodate the wind and vibration loads
of the larger antenna. Further, the value of keeping
VERY short leads outside the coax world is not so
critical. Unless you can measure and trim for low
VSWR in your modified antenna, there is risk of failing
to meet design goals.
messydeer
PostPosted: Tue Aug 06, 2013 2:14 pm    Post subject: Re: roll my own transponder antenna? Reply with quote
Thanks, Bob Smile
I bought one of those $20 ones off ebay yesterday. If I get antsy, get my xpdr installed and want it tested for mode C before it arrives in the mail, I'll cut down my homebuilt antenna to 2.9".
Dan
tim2542(at)sbcglobal.net
PostPosted: Tue Aug 06, 2013 2:44 pm    Post subject: roll my own transponder antenna? Reply with quote
I probably missed part of the discussion but why are we trying to home brew a transponder antenna when you can buy one for $20?
ACS or Steinair both sell one that works great. http://www.steinair.com/store.cfm?tlcatid=45
Tim
On Aug 6, 2013, at 3:15 PM, "messydeer" <messydeer(at)yahoo.com (messydeer(at)yahoo.com)> wrote:
[quote]--> AeroElectric-List message posted by: "messydeer" <messydeer(at)yahoo.com (messydeer(at)yahoo.com)>
Thanks, Bob Smile
Dan
http://forums.matronics.com/viewtopic.php?p=406092#406092
http://www.matronics.com/N====================================================; - MATRONICS WEB FORUMS -http://www.matronics.com/contribution
_-============================================================
messydeer
PostPosted: Tue Aug 06, 2013 7:34 pm    Post subject: Re: roll my own transponder antenna? Reply with quote
I'm disappointed to report that I couldn't solder the coax to the adapter fitting. I got the core soldered okay, but the braid stumped me. Solder would stick to the braid, but not the fitting. Think it's such a big heat sink. I was afraid to hold the iron on the braid too long for fear of melting the insulation. But I guess if it's not hot enough for the solder to stick to the fitting, it's not going to melt the plastic?
Dan
PostPosted: Wed Aug 07, 2013 5:46 am    Post subject: roll my own transponder antenna? Reply with quote
melt the plastic?
If you're using a modern coax (RG-141/142/400) then
soldering temperatures will not harm the insulation.
Sounds like your soldering iron is too small.
