Europa-List Digest: 0 Msgs - 08/02/13
tonyrenshaw268(at)gmail.c
PostPosted: Tue Aug 06, 2013 2:11 pm    Post subject: Europa-List Digest: 0 Msgs - 08/02/13 Reply with quote
Gidday,
On my 1370 lb weight increase mod I have a piece of foam "Euro 49", and I haven't come across instructions yet on what it is for. Its 265x60x2.5 mm. Any ideas?
Tony Renshaw
Sydney Aussie
richard collings
PostPosted: Wed Aug 07, 2013 1:30 am    Post subject: Europa-List Digest: 0 Msgs - 08/02/13 Reply with quote
Hi Tony
My guess is that its to re-build the centre tunnel where the tie rod cuts
through it .
Good luck Richard
nigel_graham(at)m-tecque.
PostPosted: Wed Aug 07, 2013 2:53 am    Post subject: Europa-List Digest: 0 Msgs - 08/02/13 Reply with quote
Hi Tony.
A bit late getting back to you but attached you should find the Mod 52
instructions. Scroll through to the 14th page to find what you are
after. (As Richard correctly suggested).
Nigel
On 06/08/2013 23:11, Tony Renshaw wrote:
Gidday,
Tony Renshaw
Sydney Aussie
Mod_52_-_130lb_Weight_Increase.pdf
 Filename:  Mod_52_-_130lb_Weight_Increase.pdf
 Filesize:  282.06 KB
 Downloaded:  312 Time(s)
