B-lead protection
aaaron(at)tvp.com.au
PostPosted: Wed Jul 31, 2013 5:43 am    Post subject: B-lead protection Reply with quote
I'm finishing the wiring in my safari helicopter and need some advice re B-lead ANL or fuse. I'm using the skytec starter with built in solenoid with about 3 feet of number 2 wire going from the starter to the master contactor. I'm using a tractor style push-button starter switch and an externally regulated 40a alternator. Since I have no external starter contactor, do I need to run the B-lead from the alternator via a fuse to the master contactor or can I run it the much shorter length between the alternator and starter? If the former, I could mount the ANL holder on the firewall but I would have three fat wires (starter, B-lead and main bus) bolted to the master contactor. If I can just connect the alternator to the starter lead I can use an inline fuse holder. My questions are:
1. Where do I put the B-lead and fuse/ANL?
2. What size wire for the B-lead?
3. What size fuse/ANL?
4. Do I need to put a diode across the starter button and if so, which one and in what direction?
Thanks!
Allan
PostPosted: Wed Jul 31, 2013 6:49 am    Post subject: B-lead protection Reply with quote
#2 is possibly overkill, #4 would certainly suffice
for your battery/starter wiring.
Take it to the starter.
As close as practical to the starter but if
the fuse ends up in the middle of the wire run,
it's no big deal.
8AWG is fine for 40A alternator.
I see Walmart is offering this fuse
in a 30A, which is plenty robust for
your alternator.
http://tinyurl.com/l6qbxsc
This is a miniature fuse for which you
can fabricate your own holder from a piece
of phenolic and some screws, nuts and washers
from the hardware store.
Not ACROSS the button but from contactor side
of button to ground. Cathode connected to pushbutton,
anode to ground. Any of the 1N5400 series diodes
from Radio Shack are find. See:
http://tinyurl.com/l65nqnw
There was an AD issued against the ACS key-switch
some years back that put a diode across the switch . . .
completely ineffective.
Diode needs to wire across
the solenoid coil either at the switch as described
or on the contactor (probably not as convenient but
if you can put it there, that's good too.)
PostPosted: Wed Jul 31, 2013 12:11 pm    Post subject: B-lead protection Reply with quote
Here's a 40A MIDI style stocked by Digikey
http://tinyurl.com/mpudgxu
and a holder like this
[img]cid:7.1.0.9.0.20130731150249.020c51e0(at)aeroelectric.com.0[/img]
To mount it can be found here . . .
http://tinyurl.com/kcbyc79
 Filesize:  47.84 KB
 Viewed:  6458 Time(s)
donjohnston
PostPosted: Thu Aug 01, 2013 5:26 am    Post subject: Re: B-lead protection Reply with quote
How do these compare with the ANLs that B&C sells? Other than being a LOT less money? Smile
Do they have a greater tolerance? Slower speed (of reaction)? Don't last in a harsh enviroment?
PostPosted: Thu Aug 01, 2013 6:01 am    Post subject: B-lead protection Reply with quote
Here's the data sheet on MIDI fuses
http://tinyurl.com/l985dtj
Here's the data on ANL . .
http://tinyurl.com/k7o3l3q
The ANL has been around for about 80 years
and is still used in new design. Premier
was the last airplane we designed with a
majority DC power system in it. The distribution
panel contains a goodly number of the ANL style
limiters.
The MIDI's have roots in the automotive industries
where we have witnessed a continuous evolution of
designs. For example, cartridge glass fusses
got replaced by ATC plastics which in turn have
been superceded by the ATR micro fuses. All three
generations perform to their manufacturer's specs
and have been found suited to task in billions of
applications.
The ANL and MIDI are not drop-in replacements
for each other as you can deduce from their
performance curves. But the differences are
insignificant to our task. The advantage of
the more modern design is that they are made
in relatively large quantities on automated
machines for markets much larger than the
markets which nurtured the ANL devices.
Until recently (last 10 years or so) the
modern replacements for the ANL were not
as convenient to acquire. You could find
the fuses as after market service parts but
holders were more of an OEM item. But now
that Digikey has partnered with Bussmann
and Littlefuse to distribute them, procurement
is much easier.
