tonyrenshaw268(at)gmail.c Guest
Posted: Sun Jul 28, 2013 4:12 pm Post subject: Tri-gear Flap Cross Tube Slot Length |
Gidday,
Building a taildragger version I am not constrained by gear/flap geometry to determine the flap I can deploy, since they will be electric. I feel I recall the tricycle undercarriage versions can deploy 30 degrees of flap and I was wondering if someone with that amount could measure the length of their slots as a guide whilst I remove the fuse material. I don't have the cross tube connected to the flap motor as yet, and am doing it by sanding the slots incrementally as I lower the flaps, as I didn't trust myself with the jig I made up. (I'm getting tired of fixing my mistakes).
Thanks in advance.
Tony Renshaw
Sydney Aussie
rparigoris
Posted: Sun Jul 28, 2013 4:53 pm Post subject: Re: Tri-gear Flap Cross Tube Slot Length |
Hi Tony
I just did this job on my Mono and will explain the way I did it, which seems to be a good way to do it, but first:
I have read that if you drop the flaps more than the book value of 27 degrees (target is 26-27, do not exceed 27), that yes you will produce a little more lift (and drag), but you can become airborne with ailerons that are less than effective. I think the factory mentioned this in older Tech Talk. Check with others. I am only speaking from what I read, not someone who has flown with more. For me no more than 27 degrees.
Now for flap cross tube slot, I took a 1/2"steel rod, about 6" long and bored a hole in it the precise diameter of the flap drive pin. I then made a slot 3/4" in diameter to allow 27 degrees of flap travel with the 1/2" rod on the flap drive pin sticking inside the fuse.
Then I turned a piece of aluminium that's the diameter of the flap cross tube, about 1.25" long (plus two thicknesses of 80 grit sandpaper), with one side cut at a 30 degree angle and then bored a 1/2" hole in the center where this is now a nice slip fit onto my 1/2" rod.
Now with a helper, I threw the flap from retracted to 27 degrees with the 1/2" rod on the flap drive pin and with the 30 degree angle of the aluminium rod set on the 1/2" rod, just used the point of the tip of the 30 degree angle pushed against the fuse and traced with a pencil the needed slot.
Mind you this is not a perfect slot because the flap drive pin is not perpendicular with the fuse, but close enough to allow full throw without going "too much".
It ends up that a closet wood pole is the same diameter as the flap cross tube, so I just stuck some 80 grit and had a terrific sanding bar.
Once I have everything set up exactly as I want and can cycle the gear, or in your case actuate the motor, I will just take a carpenters pencil, cut down to about an inch long and sharpened to give desired clearance, and mark the fuse by resting the pencil on the flap cross tube, using the flap cross tube as a guide. By using the flap cross tube as a guide, this will make the perfect mark to follow.
Ron Parigoris
Posted: Mon Jul 29, 2013 1:26 am Post subject: Tri-gear Flap Cross Tube Slot Length |
Tony
don't use 30 degree flap, Europa tested it and found you are starting to lose aileron control at the low speeds achieved in ground effect.
Graham
To: "europa-list(at)matronics.com" <europa-list(at)matronics.com>
Sent: Monday, 29 July 2013, 1:11
Subject: Tri-gear Flap Cross Tube Slot Length
--> Europa-List message posted by: Tony Renshaw <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)>
Gidday,
Thanks //www.matronics.com/Navigator?Europa-List" target="_blank">http://www.mat= --> [quote][b]
frans(at)privatepilots.nl Guest
Posted: Tue Jul 30, 2013 1:24 am Post subject: Tri-gear Flap Cross Tube Slot Length |
On 07/29/2013 11:25 AM, GRAHAM SINGLETON wrote:
| Quote: | don't use 30 degree flap, Europa tested it and found you are starting to
I have some trouble believing this (and even when it is true it is
questionable whether this is still a valid reason for the XS with the
increased aileron span and with more powerfull engines).
With higher flap settings you are getting more drag than additional
lift. With 10% more flap (30 degree instead of 27) you will get maybe
just 5% more lift. If the ailerons are inadequate for this tiny bit of
extra lift I think they would have difficulties handling 27 degrees as
well. Furthermore, in the XS the ailerons are substantially increased in
lenght, significantly more than 5%, and should have much more control
power at low speeds! Even if control problems were the limiting factor,
than it is questionable whether the same limit would still be needed for
the XS.
I thought that the limitation in flap was because of the 80hp engine
used for the certification, which might have lacked sufficient power to
exercise a go around with full flaps under full load (which is, if I
remember correctly, a certification requirement. For the same reason the
older Cessna's have 40 degree flaps, where the newer ones have 30 degree
which was instantly rewarded with a 30Kg higher MTOW without any
structural changes).
Furthermore, in the tri gear the fact that you have the option to use 30
degree flaps doesn't mean that you will have to use this all the time.
There are situations where more flap would be welcome, and there might
be situations where using less flap would be better. I can't see the
benefit of the 26 degree limit. Of course for the mono you have no other
option than to land with full flaps, so maybe in this case the
limitation is justified.
I know folks having drilled a new hole in the lugs on the flap control
tube, so that the actuator can drive the flap further (and faster). No
control difficulties are observed even in quite a few nasty situations
with 30 knots wind and lots of turbulence. Instead the short field
capabilities are somewhat improved.
Frans
Posted: Tue Jul 30, 2013 1:29 am Post subject: Tri-gear Flap Cross Tube Slot Length |
Frans
I was talking about monowheel in ground effect.
Graham
Sent: Tuesday, 30 July 2013, 10:23
Subject: Re: Tri-gear Flap Cross Tube Slot Length
--> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)>
the XS.
capabili//www.matronics.com/Navigator?Europa-List" ="http://forums.matronics.com/" target="_blank">http://forums.matronics  tronics.com/contribution" target="_blank">http://www.matronics.com/contri================
ivanshaw(at)btinternet.co Guest
Posted: Tue Jul 30, 2013 4:19 am Post subject: Tri-gear Flap Cross Tube Slot Length |
I tested the flaps down to 40 degrees, ailerons worked just fine.
Ivan
Posted: Tue Jul 30, 2013 5:15 am Post subject: Tri-gear Flap Cross Tube Slot Length |
Not what you told me re the monowheel!
G
Sent: Tuesday, 30 July 2013, 13:18
Subject: RE: Tri-gear Flap Cross Tube Slot Length
--> Europa-List message posted by: "Ivan Shaw" <ivanshaw(at)btinternet.com (ivanshaw(at)btinternet.com)>
Ivan
nigel_graham(at)m-tecque. Guest
Posted: Wed Jul 31, 2013 4:42 am Post subject: Tri-gear Flap Cross Tube Slot Length |
A fascinating insight into the reasoning behind the recommendation for
the optimum flap setting can be found on page three of this early
factory newsletter, dated March 1994.
This did of course relate to the first prototype, G-YURO, which was
powered by the 80 horse 912 driving a fixed pitch Warp Drive prop.
Happy days. The enthusiasm and excitement was palpable. Isn't it time
somebody developed a new homebuild?
Nigel
On 30/07/2013 10:23, Frans Veldman wrote:
the XS.
Frans
1994_-_Q1_-_Issue_7.pdf |
19.51 KB |
568 Time(s) |
Posted: Wed Jul 31, 2013 5:22 am Post subject: Tri-gear Flap Cross Tube Slot Length |
Thanks for that Nigel
As you say, fascinating! I'm glad my memory is not so innacuarate after all!
Graham
From: "nigel_graham(at)m-tecque.co.uk" <nigel_graham(at)m-tecque.co.uk>
Sent: Wednesday, 31 July 2013, 13:42
Nigel
| Quote: | --> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)>
the XS.
Frans
Posted: Wed Jul 31, 2013 5:27 am Post subject: Tri-gear Flap Cross Tube Slot Length |
Looks like mine is!!
Ivan
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON
Sent: 31 July 2013 14:22
Graham
From: "nigel_graham(at)m-tecque.co.uk (nigel_graham(at)m-tecque.co.uk)" <nigel_graham(at)m-tecque.co.uk (nigel_graham(at)m-tecque.co.uk)>
Nigel
the XS.
Frans
| Quote: | | http://www.matronics.com/Navigator?Europa-List | 01234567
Posted: Wed Jul 31, 2013 5:28 am Post subject: Tri-gear Flap Cross Tube Slot Length |
I felt you needed a bit of support
N
On 31/07/2013 14:22, GRAHAM SINGLETON wrote:
[quote] Thanks for that Nigel
Graham
From: "nigel_graham(at)m-tecque.co.uk" (nigel_graham(at)m-tecque.co.uk) <nigel_graham(at)m-tecque.co.uk> (nigel_graham(at)m-tecque.co.uk)
Nigel
> the XS.
> Regards,
> Frans
Posted: Wed Jul 31, 2013 5:30 am Post subject: Tri-gear Flap Cross Tube Slot Length |
Old age I guess! {{ now you know how I feel!
G
Sent: Wednesday, 31 July 2013, 14:27
Ivan
Graham
Nigel
the XS.
Frans
| 01234567
8
