airvair601
				 Posted: Sun Jul 28, 2013 3:02 am    Post subject: Zenith601-List Digest: 1 Msgs - 07/27/13 |
				Wonder if this is an issue? Easy to check.  Need to do it early on!  With our funky exhaust it might be a challenge
 On Jul 28, 2013, at 3:00 AM, Zenith601-List Digest Server <zenith601-list(at)matronics.com> wrote:
  	  | Quote: | 	 		   *
  Today's complete Zenith601-List Digest can also be found in either of the
  two Web Links listed below.  The .html file includes the Digest formatted
  and Message Navigation.  The .txt file includes the plain ASCII version
  of the Zenith601-List Digest and can be viewed with a generic text editor
  HTML Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-07-27&Archive=Zenith601
  Text Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 13-07-27&Archive=Zenith601
                            Zenith601-List Digest Archive
                      Total Messages Posted Sat 07/27/13: 1
  Today's Message Index:
      1. 06:02 AM - CO  (BobbyPaulk(at)comcast.net)
  ________________________________  Message 1  _____________________________________
  Time: 06:02:24 AM PST US
  Subject: CO
  Guys,
  I had posted some time back about CO in the cockpit of my 601XL ( Jabiru ). I had
  circled a friends hangar 3 times at another airport at 80 MPH. ( high angle
  of attack ) When I straightened up to fly home I was nauseous and smelled exhaust
  fumes very strongly. The CO monitor pill was solid black. I opened both cabin
  air vents even though it was about 40 deg. outside. I had a very bad headache
  for the next 4 ~ 5 Hrs.
  I extended my exhaust pipe another 5 or 6 inches with a 45 deg. turn down and it
  seemed to help. I thought I had sealed the firewall completely but one day when
  I had a light in the engine compartment and the hangar was dark I looked in
  the cockpit & found two small leaks in the firewall right behind the lower engine
  mounts. This was on the quick build kit.
  While my engine was running very rich I noticed the black stains on the belly just
  behind the firewall were running forward back toward the low pressure area
  at the firewall. I have tried adding a skirt to the lower cowl with no improvement.
  I also saw the black stains around the belly access panel. Summer seems to be O.K.
  due to the air vents being open and pressurizing the cockpit somewhat, winter
  when the vents are closed is when I experience the worst smells. The cockpit
  on the XL has a strong negative pressure - you can check this by getting your
  shirt sleeve or shop rag close to the canopy rail where it is not sealed.
  The exhaust extension, re-sealing the firewall, and the engine finally running
  correctly have all helped but I still get a whiff of CO particularly at a high
  angle of attack or slow speed.
  I am still trying to find a way to seal the 6 built in leaks in the Jabiru exhaust
  connections.
  Any ideas?? Wraps usually burn away in 4 or 5 hours.
  Bobby ( age 75 )
  Zodiac 601 XL "B"
  Jabiru 3300 S/N 1141
  Sensenich 64" x 51" Prop
  Bing Carb 260 Main & 285 Needle Jet
  Status - Flying 185 hrs.
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Phill Hartig
N325FG
601HDS trigear,
Corvair |
